This is a re-render of my previous evening clouds post with a visible
sun disk. Other alterations include a modified sky glow, modified
"ground plane", higher sun altitude, and lower camera position (relative
to water surface).
This is still a bit of a hack since distances and proportions are (at
least terrestrialy) inaccurate - note the curve in the horizon.
Some things I'd like to improve on: soften the horizon, ability to
change color or redness of sky, better lighting of clouds, and better
clouds for that matter.
Render time: 2:08 on a 90MHz Pentium
Renderer: MegaPov 0.5a (method 3 media)
Abe
Download 'evening_clouds2.jpg' (147 KB)
Preview of image 'evening_clouds2.jpg'
Hey, is that normal on the water changing from big bumps to little bumps now
and then? If so, that is a more reaslistic attempt at water than most, simply
because there is usually a breeze which affects the surface of the water in
local areas. I guess it could also be the camera angle doing it.
> to water surface).
> Abe
> [Image]
Samuel Benge
E-Mail: STB### [at] aolcom
Visit my isosurface tutorial at http://members.aol.com/stbenge
