SamuelT. wrote:
> Here's an image of what I would do. You will need the SuperPatch or MegaPov to
> use it, though.
> Here's the code for the ring:
> disc{
> <0,0,0>,<0,1,0>,10,6
> pigment{
> function noise3d( sqrt( x^2+z^2 ), 0, sqrt( x^2+z^2 ) )
> scale .4
> color_map{[0 rgbf 1][1 rgb<1 1 .9>]}
> finish{
> ambient 0
> diffuse 1.5
Hmmm! They look good. I'll try that and Noah's suggestion... touse some Alpha blending
and all
> Steven Pigeon wrote:
> > Have anyone work'd out a good planetary ring texture?
> > Best,
> > S.
> > Steven Pigeon Ph. D. Student.
> > University of Montreal.
> > pig### [at] iroumontrealca Topics: data compression,
> > pig### [at] jspumontrealca signal processing,
> > ste### [at] researchattcom non stationnary signals
> > and wavelets.
> > http://www.iro.umontreal.ca/~pigeon
> > [Image]
> Samuel Benge
> E-Mail: STB### [at] aolcom
> Visit the still unfinished isosurface tutorial: http://members.aol.com/stbenge
> [Image]
and wavelets.
i thought it would have the samme scatter effect..... life aint perfect
nither is 3d
Peter Popov wrote:
> On Tue, 7 Mar 2000 01:19:59 +0000, Mike Williams <mik### [at] nospamplease>
> wrote:
> >Each individual particle might reflect, but those reflections would be
> >in totally random directions because the particles are oriented
> >randomly. Take a look at a pile of iron filings.
> Isn't this precisely how blurred reflection in MegaPOV works?
> Peter Popov
> pet### [at] usanet
> ICQ: 15002700
ooo my toil has been recognised! anyways.... where can i get megapov anyways?
> > use it, though.
> > disc{
> > pigment{
> > scale .4
> > finish{
> > ambient 0
> > diffuse 1.5
blending
> and all
> > > Best,
> > > S.
> > > and wavelets.
> > > [Image]
> > Samuel Benge
> > [Image]
> and wavelets.
In article <38C5AA75.DE8AAC9A@powersurfr.com>, Noah A
> anyways?
http://nathan.kopp.com/patched.htm
Chris Huff
e-mail: chr### [at] yahoocom
Actually, the reflectivity (or albedo) of the earth is a very important
phenomena. Back when I was Atmospheric Chemistry simulation (i.e. solving
an approximation to the 3D multicomponent Navier-Stokes equation), albedo
was one of the most important parameters in understanding the impact of
solar radiation on the thermal characteristics of the planetary atmosphere.
Jim
Check out my web site http://www.kressworks.com/
Steven Pigeon <pig### [at] iroumontrealca> wrote in message
news:38C59F76.A5401909@iro.umontreal.ca...
> > > Best,
> > This isn't bad at all. The rings on "our" planets vary greatly, so I
can't see
> > why these shouldn't be just as possible. Well, I'm not sure if you that
strong
> > highlight is realistic. And ambient should be 0 for planets.
> Actually, it is 0. But on the other hand earth shines quite a lot. It
doesreflect
> ~39% of the light it receives. A ring in low orbit would have a
> good 'earth shine'. If the moon does, after all...
> > I've made a fairly detailed Saturn ring texture, but I don't think you
can use
> > it for anything else. It's in the binaries.scene-files group if you're
> > interested, posted 28.11.99. It's also available from
> > http://www.stud.ntnu.no/~as/down.
> > sig.
> and wavelets.
thanks
> > anyways?
> Chris Huff
> Web page: http://chrishuff.dhs.org/
