Inspired by Peter Warrens Hair-piece I thought I knew a nice alternative
way to do hair. I wanted to cook up a simple demonstration but it turned
into some sort of bushlad.
These are just semi-transparent radial pigments on toruses. It works,
but it is not very flexible and, depending on the 'depth', takes quite
some time to render. The advantage is that you can easily do curly hair
and probably some other stuff. I think if you used isosurfaces for this
it could be a terrific solution.
Remco
Download 'eikeltje7.jpg' (42 KB)
Preview of image 'eikeltje7.jpg'
Remco de Korte <rem### [at] xs4all nl> wrote in message
news:388BA327.6340A869@xs4all.nl...
> Remco
da hell... I see povray mascot written ALL over this one :)
> > Remco
Maybe you should clothe him first...??? :~o
um................ should there be some more hair.............. um..........
Put some clothes on man...!!
>but it is not very flexible and, ....
Geinig kereltje,
for a moment I thought you used a pigment based isosurface for the hair.
Ingo
Pov-Ray : http://members.home.nl/seed7/
Remco de Korte wrote in message <388BA327.6340A869@xs4all.nl>...
I think it's great that one image can inspire another one that
is so different. I must confess that it is a bit ironic for me to
talk about hair because as the old Irish expression goes:
"There is nothing between me and heaven."
I.e., I'm bald(ing).
>takes quite takes quite some time to render.
This seem to be a hair-problem. I remember when
I was working with Blob Man and added some hair
the render times just shot up.
This looks like it has some really good possibilities.
I'm impressed with the hair shadows.
As I said before, your great at caricatures.
BTW, nice unit.
Peter
<badjoke> What makes you so sure it's a he? </badjoke>
And at least if he were to be included with POV!
*inching towards door*
___ ______________________________
| \ |_ <dav### [at] faricy net>
|_/avid |ontaine <ICQ 55354965>
> Geinig kereltje,
Wie, ik? ;)
> hair.
I considered using an isosurface based pigment but I never got beyond a
simple radial with a tiny bit of disturbance and a high frequency. These
two make it easy to change his hair. I'll try out a high disturbance
soon, see if I can get a good Afro-look.
Remco
"Remco de Korte" <rem### [at] xs4all nl> wrote in message
> Remco
Strangly its not the hair that grabs the attention...
ho hum,
