Keeping in the Iso theme. I came up with this by playing with the (new to me
Mega Pov). If used at the right angle it can give a fair facsimile of
diamond tread type flooring. It is very memory friendly (this scene 256k
ram) and if you use the no_shadow keyword for the isosurface is very fast
to render. Well anyway if someone needs it here it is (just adjust scale of
the box and bounding box of the isosuface to meet your needs.
isosurface
function {"mesh1",<0.5,0.5,.5,0.025,1>}
bounded_by{ box {<-100,.05, -100>,<100,.07,100>}}
threshold 0.05
eval
pigment {color Gray50}
/*no_shadow*/ /*just uncomment out to speed things up*/
rotate 45*y
box
<-100,.03, -100>
< 100,.05,100>
rotate 45*y
Buke
Download 'mesh1.jpg' (57 KB)
Preview of image 'mesh1.jpg'
Sigmund would like this for his completely irrelevant image I believe.
___ ______________________________
| \ |_ <dav### [at] faricynet>
|_/avid |ontaine <ICQ 55354965>
Good job. I did something like that a while ago, but it used bump_maps.
> isosurface
> threshold 0.05
> eval
> rotate 45*y
> box
> <-100,.03, -100>
> < 100,.05,100>
> rotate 45*y
> Buke
> [Image]
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial: http://members.aol.com/stbenge
Well, I'll be damned.. I have a LOT to learn about MegaPov.
Although this doesn't look exactly as the corrugated aluminum I've seen,
I think this is as good as any. Memory usage makes it a killer!
I've put it to use already, thank you very much!
sig.
> Homepage: http://www.faricy.net/~davidf/
btw I get a very odd effect with this image scrolling it up and down in a
small window (such as the preview pane in Outlook, although it works in PSP
as well).
The whole thing seems to move towards me and then away again.
