Subject: Pointlight vs. spotlight media interaction (26kB)
Date: 10 Oct 1999 16:17:03
Message: <3800f43f@news.povray.org>
Here are images which document the difference between pointlight and
spotlight interactions with atmospheric media. If that's the way it's
supposed to be, then so be it. This difference is quite annoying to me
as it goes against my intuition that point and spot lights should be the
same kind of animule, just different in their directional coverage.
(Apologies for earlier claiming it was a problem with the superpatch. I
have seen the same thing happen in 3.1g and sup 3.1e.)
The code allows either a point light or spot light to shine out of a
hole in a hollow sphere...
location <0, 450, -900>
look_at <0, 300, 0>
angle 45
light_source { <0,0,0>
color White*50
//Comment out this line or not to switch between point and spotlight..
// spotlight radius 45 falloff 28 point_at y
//yes, that line just above here, comment it out.
media_interaction on
light_source{<0,5550,0> color White*2 media_interaction off}
difference{
sphere{0,300 pigment {White}}
sphere{0,299 pigment {Green}}
cylinder{<0,0,0>,<0,500,0>,25 pigment {Green}}
pigment {White}
finish {ambient 0.2}
sphere {<0,450,0>,10
pigment {White}
media {
intervals 10
scattering { 2, red 0.05 blue 0.001 green 0.02}
samples 1, 10
confidence 0.9999
variance 1/1000
ratio 0.9
Download 'pointspot.jpg' (26 KB)
Preview of image 'pointspot.jpg'
Subject: Re: Pointlight vs. spotlight media interaction (26kB)
Date: 10 Oct 1999 19:02:36
Message: <38011b0c@news.povray.org>
Is the 'falloff' number right? "28"? Far as I know 'radius' should be
smaller or equal to 'falloff', and if it's larger then the falling off
wouldn't show. Any chance this means you somehow unknowingly raised the
intensity of the spotlight through some quirk in the way it works?
Date: 11 Oct 1999 10:25:56
Message: <3801f374@news.povray.org>
On Sun, 10 Oct 1999 15:43:41 -0400, Greg M. Johnson wrote:
>This is a multi-part message in MIME format.
>--------------0F39FD1270EE228044A619BF
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
Try adding this line at the end of your scene:
cone { 0, 0, 600*y, 50 pigment {rgbt 1} hollow}
See my posting from a couple weeks ago on why this has the effect it
does. (povray.general, I think. Something about media tutorials or
such. Maybe someone could post a more complete reference?)
It started with my question:
publications about media method?
at povray.general
Fri, 17 Sep 1999
Ron gave the answer there!
Greetings,
Marc
Marc Schimmler
Date: 11 Oct 1999 12:54:30
Message: <38021646@news.povray.org>
THANKS.
The key is to leave the media "out of" the interior of the sphere. I had
received advice before but I interpreted it as suggesting that I put the
media INSIDE the hollow object or plane. This didn't look that good with the
scene I was considering at the time. With media inside the hollow object,
there was too much attention drawn to the interface of the object. (BTW, a
sphere, rather than a cone, would be needed for my ultimate project: light
pouring out of a porous 3dnoise isosurface!)
sphere { 0, 400 pigment {rgbt 1} hollow
// comment out the 1st or 2nd line following
//interior{
media {
intervals 10
samples 1, 10
confidence 0.9999
variance 1/1000
ratio 0.9
//uncomment out the next line if you uncomment out the 2nd line above.
Download 'hollow.jpg' (17 KB)
Preview of image 'hollow.jpg'
