Hi there!
I sat down the last evenings and wrote my first macro. Nothing
incredible, just a little tool to create realistic nuts (see small
example at the bottom).
You find the macro and a small tutorial how to use it at:
http://www.ica.uni-stuttgart.de/~marc/nuts.html
Any comments are welcome!
Marc
Marc Schimmler
On Sat, 08 May 1999 22:38:41 +0200, Marc Schimmler <mar### [at] icauni-stuttgartde>
wrote:
>Hi there!>>I sat down the last evenings and wrote my first macro. Nothing>incredible, just a little tool to create realistic nuts (see small>example at the bottom).>>You find the macro and a small tutorial how to use it at:>>http://www.ica.uni-stuttgart.de/~marc/nuts.html>>Any comments are welcome!>>Marc
Very good Marc. I like the use of simple engineering terms as the macro
parameters. I can understand why you had difficulty with your "slope" term.
The english engineering expression for this quantity is "lead", but it is more
usual in the UK (and I believe in the USA) to use the term "pitch" which is
1/lead.
David
dav### [at] cwcomnet
http://www.hamiltonite.mcmail.com
David Wilkinson wrote:
> > On Sat, 08 May 1999 22:38:41 +0200, Marc Schimmler <mar### [at] icauni-stuttgartde>> wrote:> > >Hi there!> >> >I sat down the last evenings and wrote my first macro. Nothing> >incredible, just a little tool to create realistic nuts (see small> >example at the bottom).> >> >You find the macro and a small tutorial how to use it at:> >> >http://www.ica.uni-stuttgart.de/~marc/nuts.html> >> >Any comments are welcome!> >> >Marc> > Very good Marc. I like the use of simple engineering terms as the macro> parameters. I can understand why you had difficulty with your "slope" term.> The english engineering expression for this quantity is "lead", but it is more> usual in the UK (and I believe in the USA) to use the term "pitch" which is> 1/lead.> David
Thanks David! The book about construction of machines I've got are in
german only. Pitch is actually the term I was looking for. I will change
the term slope to pitch in the documentation and maybe in the macro as
well!
Marc
Marc Schimmler
