Let's not start a war on this, but the english pronunciation of "tank" (like
in tanker) is not so bad to mimic "petanque)
Philippe
<372### [at] compuservecom>...
>Ph Gibone wrote:
>> Rather : Pay Tank
>> Philippe
>> <372DD654.473FC149@compuserve.com>...
>> >For info, it's also called "petanque" (pay-tonk, phonetically).
>> >Fabien.
>Oui, si tu le prononce a la francaise !
>Fabien.
Nice texture. Thanks David.
Steve
David Wilkinson wrote:
> On Mon, 03 May 1999 10:39:06 퍭, Jan Schaefer <jan### [at] imiseuni-leipzigde>
> wrote:
> >Hi,
> >this is my first picture I post to this group. I hope it looks not to much like
> >the boring but also famous "mirror-ball-on-checkered-plane-thing" ...
> >It shows a game called Boule. I think they play it mostly in France.
> >I need some help to brighten the shadows and to improve the ground.
> >So feel free to comment. Both types of commenting, positive and negative, are
> >welcome.
> >So long,
> >Jan
> Jan,
> An interesting subject for a first effort. I wish I had thought of it first!
> If, however, you are looking for realism, the boules need to be scratched and
> and the grooves a bit deeper. The ground would be better using a granite
> texture to look more like a coarse sand.
> e.g.
> texture {
> pigment {
> granite
> color_map {
> [0.1 color rgb<3,3,1.5>]
> [0.3 color rgb<2,1.5,1>]
> [1.0 color rgb<1.5,1,0.8> ]
> turbulence 0.5
> scale 0.001
> normal{bumps 1 scale 0.001}
> finish { phong 0.8}
> dav### [at] cwcomnet
> http://www.hamiltonite.mcmail.com
Fine work indeed.
A few suggestions:
a) More interesting sky.
b) Head complete with sunhat looking down to see which ball is
closest
(reflected of balls).
c) A tree behind the camera reflected on the balls and casting a
patchy shadow over the imediate vicinity, (you'll need
Gilless' tree macro for this from:
http://www.mediaport.net/Artichaud/Tran/gtran.en.html
Keep up the good work and let us see the finished product.
Steve
Jan Schaefer wrote:
> Hi,
> welcome.
> So long,
> Jan
> [Image]
