Mike Metheny
lon### [at] vtedu
mik### [at] loneshepherdcom
http://www.loneshepherd.com/
"When one's words are no better than silence, one should keep silent."
Download 'fractal1.png' (303 KB)
Preview of image 'fractal1.png'
hey... Cute:-)
hmm, can you all distribut the sources for the fractals ?? It'd be a nice
"fractal archive" in pov... *smiles*
Mike Metheny wrote:
> Mike Metheny
> lon### [at] vtedu
> [Image]
//Spider
[ spi### [at] bahnhofse ]-[ http://www.bahnhof.se/~spider/ ]
"Marian"
By: "Sisters Of Mercy"
Now, that is cool. Borg snowflake? ;-]
KB-
Mike Metheny wrote:
> Mike Metheny
> lon### [at] vtedu
> fractal1.png Type: PNG (image/x-png)
> Encoding: x-uuencode
Fractals and POV really are a wonderful mix, no?
I suspect this is in reality 6 copies of a 2D-fractal forming the cube.
Right?
Margus
Mike Metheny wrote in message <37260582.0@news.povray.org>...
>Mike Metheny
>lon### [at] vtedu
<<Fractals and POV really are a wonderful mix, no?
Right?>>
You are correct sir. actually, I started out with a fractal I used to draw
by hand on occasion, (seen below) and for the cube combined 4 of these per
side; for 24 fractal shapes to create the actual box. Each segment is a
cylinder capped by 2 spheres; the above image took close to 5 hours to
render. . .I wonder if it would be faster to use one box in said instance?
Also I had to make the width of the segments fairly large; they look kinda
funny at lower iterations. . .what was happening is that I thought my code
was faulty cause several segments (pixel wide i guess) were missing in the
render unless the thickness was increased greatly. Anyway, once I clean up
the source for the fractal itself, and turn it into a macro (which was my
original intention, my first try at macros) but right now it's just a while
loop.
Mike Metheny
lon### [at] vtedu
Download 'fractal1(5).jpg' (30 KB)
Preview of image 'fractal1(5).jpg'
Mike Metheny wrote in message <37262e1e.0@news.povray.org>...
At this size, there would be little visible difference. So I suggest you go
with boxes (or just cylinders, because they are easier to position). Should
be a lot faster.
Margus
I like it. What's this one called?
Steve
Mike Metheny wrote:
> Mike Metheny
> lon### [at] vtedu
> [Image]
<<I like it. What's this one called
Hmmmmmm. . .doodles de Mike?
This is just one of the simplest ways to introduce fractals to someone, by
taking a line segment, splitting it up, and using equal size segments to
create a shape, then repeat. I'll do another one along the same lines in
2d that will be a more complicated split up line segment, just for
experimentation.
Mike Metheny
lon### [at] vtedu
