It's extremely good, don't know how you did it, worked it all
out, but it's really beautiful.
Steve
=?iso-8859-1?Q?J=E9r=E9mie?= Aubouin wrote:
> Hi!
> This is my first post in this group.
> I'm developping an Asteroid macro.
> Here is a first draft.
> Of course, this macro can be greatly improved.
> That's why your comments, advices, etc... are welcomed.
> What do you think of:
> - the texture ?
> - the shape ?
> - the craters ?
> This Asteroide is a blob object made with 600 spheres for the body (positive
> spheres) and 330 spheres for the craters (negative spheres: 30 big crateres and
> 300 small ones).
> ___________________________________________________
> Jrmie Aubouin
> Pour me rpondre, enlever le Z de mon adresse.
> To answer me, remove the Z from my adress.
> [Image]
I don't think any of you actually saw an asteroid, ever...
No, but my mom used to make these oatmeal cookies that had to be as
close to asteroids as you can get.
Bryan Valencia
Software Services
Software Services Home Page http://www.209software.com
Pascal for Delphi Programmers http://www.209software.com/p4dp/Book.html
Resume: Delphi Programmer http://www.209software.com/resume/resume.html
Spider wrote :
> Try to write the blobs into a pre-made .inc file, taht way the parsing should be
> decreaaased to some part.
Simon de Vet wrote :
> BTW, any chance of making something to export to the .blb files? (These are
> supported by Moray, and I think it's a pretty straightforward text format....)
I just made a new version of the macro which can export to moray .blb AND Povray
.inc
files.
Here is the code of the macro :
// Start here
#macro Random(A,B,S)
A+(B-A)*rand(S)
#declare Asteroid_Texture = texture {
bozo
turbulence 1 lambda 2 omega 0.6 octaves 6
color_map {
[ 0 color rgb<127,129,129>/255 ]
[ 1 color rgb<79,81,81>/255 ]
scale 0.25
normal {
average
normal_map {
[ 1
granite 0.6
turbulence 1 lambda 2.5 omega 0.5 octaves 6
scale 2
[ 1
leopard 1
turbulence 0.5 lambda 1.5 omega 0.8 octaves 6
slope_map {
[ 0.00 <1.0,0> ]
[ 0.10 <0.6,1> ]
[ 1.00 <0.0,0> ]
scale 0.2
finish { ambient 0.2 diffuse 1 }
#macro
Asteroid(Nb_Body,Nb_Big_Crater,Nb_Small_Crater,Sca_Ast,Export,file_name,S)
blob {
threshold 0.5
// Output to file
#if ( (Export=1) | (Export=2) )
#fopen file_blob file_name write
#if (Export=2)
#write (file_blob,"[blob1.0]\n")
#write (file_blob,"threshold = 0.5\n")
#else
#write (file_blob,"blob {\n threshold 0.5\n")
// Body
#local Cpt = 0 ;
#while (Cpt<Nb_Body)
#local RotX = Random(0,360,S) ;
#local RotY = Random(0,360,S) ;
#local PosZ = Random(1.5,2.4,S) ;
#local Rad = -PosZ/1.8 + 7/3 ;
#local Position = Sca_Ast*vrotate(<0,0,PosZ>,<RotX,RotY,0>) ;
sphere { Position,Rad,1 }
// Output to file
#if (Export=2)
#write (file_blob,"sphere = ",Position.x," ",Position.z,"
",Position.y," ",Rad," 1\n")
#if (Export=1)
#write (file_blob," sphere { ",Position," , ",Rad," , 1 }\n")
#local Cpt = Cpt + 1 ;
// Big Craters
#local Cpt = 0 ;
#while (Cpt<Nb_Big_Crater)
#local PosZ = Random(2,3,S);
#local Rad = PosZ - 1.5 ;
sphere { Position,Rad,-5 }
// Output to file
#if (Export=2)
",Position.y," ",Rad," -5\n")
#if (Export=1)
#write (file_blob," sphere { ",Position," , ",Rad," , -5 }\n")
// Small Craters
#local Cpt = 0 ;
#while (Cpt<Nb_Small_Crater)
#local PosZ = Random(3,3.5,S) ;
#local Rad = PosZ/2 - 1 ;
sphere { Position,Rad,-1 }
// Output to file
#if (Export=2)
",Position.y," ",Rad," -1\n")
#if (Export=1)
#write (file_blob," sphere { ",Position," , ",Rad," , -1 }\n")
texture { Asteroid_Texture }
// Output to file
#if (Export=1)
#write (file_blob," texture { Asteroid_Texture }\n}\n")
#fclose file_blob
no_shadow
// End of macro
And here is the code for the Asteroid picture I made:
#declare R1 = seed(100) ;
Asteroid(600,30,1200,<1,1,1.5>,0,"",R1)
The parameters:
Asteroid(
Number of components for the body ,
Number of components for the big craters ,
Number of components for the small craters ,
Scale vector: scales the position of each component, not the radius ,
Export parameter: 0=no export / 1=povray .inc export / 2=moray .blb export
Name of the file to export ,
pseudo-random stream
Of course, these parameters will change in the future.
The macro is still under construction...
With the .blb exporter, I can visualize with Moray where the spheres are. And I
discovered that many are useless. I'll try to decrease this number without
affecting the look of the Asteroid.
I discovered another problem: when I reduce the number of spheres for the body
to 300, the strength of the body is smaller: the holes created by negative
spheres are deeper.
I tried to create more small/sharp craters, but in this case, I need 1200+
components, and many of them are unused (too far from the body).
And I think that many other problems will appear.
Thank you for your suggestions.
I'll try to integrate most of them into a new beta version of the macro.
If you have other ideas, don't hesitate to modify the macro source code.
Talk about weird!
Impressive, I'll have a play with the macro tomorrow.
Thanks
Steve
> .inc
> files.
> // Start here
> A(B-A)*rand(S)
> #end
> pigment {
> bozo
> color_map {
> scale 0.25
> normal {
> average
> normal_map {
> [ 1
> granite 0.6
> scale 2
> [ 1
> leopard 1
> slope_map {
> [ 0.00 <1.0,0> ]
> [ 0.10 <0.6,1> ]
> [ 1.00 <0.0,0> ]
> scale 0.2
> #macro
> blob {
> threshold 0.5
> // Output to file
> #if (Export=2)
> #else
> #end
> #end
> // Body
> #local Cpt = 0 ;
> #local Rad = -PosZ/1.8 7/3 ;
> // Output to file
> #if (Export=2)
> #end
> #if (Export=1)
> #end
> #local Cpt = Cpt 1 ;
> #end
> // Big Craters
> #local Cpt = 0 ;
> // Output to file
> #if (Export=2)
> #end
> #if (Export=1)
> #end
> #end
> // Small Craters
> #local Cpt = 0 ;
> // Output to file
> #if (Export=2)
> #end
> #if (Export=1)
> #end
> #end
> // Output to file
> #if (Export=1)
> #end
> #fclose file_blob
> #end
> no_shadow
> #end
> // End of macro
> The parameters:
> Asteroid(
> spheres are deeper.
> Jrmie Aubouin
I try to think in terms of wearing my glasses or not. Same seems to go
for the difference between the Voyager I and II interplanetary missions
(mostly). I figure everythings bound to be about like that if seen in
person, you know, like Voyager 7 views of space objects were there ever
such a thing to be.
mailto:inv### [at] aolcom?Subject=PoV-News
On Thu, 22 Apr 1999 11:39:16 -0700, Bryan Valencia <sof### [at] gtenet>
How does one get rid of asteroids? Use "Preparation A"!
Alan
povray.org - official home of the Persistence of Vision Ray Tracer
news.povray.org - where POV-Ray enthusiasts from around the world
- get together to exchange ideas and experiences
> Alan
"Alan, Alan, Alan" Ken say's to himself while slowly shaking his head
in disbelief.
What are we going to do about you and your particular form of humor ?
Ken Tyler
mailto://tylereng@pacbell.net
It was funny to me... oh-oh.
> > Alan
> in disbelief.
> Ken Tyler
