This is very much a work in progress
The boat needs a mast and rigging, a sailor and a wake!!
The foam on the wave crests is difficult! i'm still working on it any help
would be gratefully received.
Mick
Download 'Rough Water.jpg' (126 KB)
Preview of image 'Rough Water.jpg'
> Mick
That is some rough sailing ahead. Fantastic surface features.
I just had a though you might try for the foam. Take a duplicate of the
image you are using for the HF. In a paint program try to add some black
noise to the image. Keep the noise at a reasonably small scale and spread
it about randomly. Now save this second image to be used as a second HF
object. Give it the exact same scale as the first but use a very high water
level on the second HF.
This will if successful create a HF like the first but only the crests
of the HF will show since the bottom portion will be removed by the water
level setting. The black noise I suggested is to create tiny holes in the
remainder of the HF to help give it that foamy look. You might even add
some white noise along with the black to get some high and low areas that
are different from the height values in the first HF. You may need to combine
the two HF's inside a merge statement so they integrate together seemlessly.
Otherwise with a clear medium you would see obvious artifacts from the over
lapping areas.
Will it work ? Beats me but it's your time and you might just get lucky.
If it does let me know so I can try it.
Ken Tyler
mailto://tylereng@pacbell.net
Good Idea Ken I'll let you know if it works.
Nah, forget the mast and rigging...go for that Winslow Homer painting. Put
some poor dude in the boat, and have a ship and a hurricane looking thing in
the background.
> Mick
> [Image]
Hmm... If you have the superpatch (and haven't already thought of this) I'd
suggest using slope-dependent textures for the foam.
OR, if you're a masochist, and again, in possession of the superpatch, you
might develop an algorithm for sampling the HF and creating appropriate
media containers in appropriate places... Nah. Forget it. Too far-fetched.
Margus
Mick Hazelgrove wrote in message <36e1978e.0@news.povray.org>...
>Mick
It looks like ice maybe you need to soften or smooth it out so it's not so
rough. Maybe add a glass texture to it I don't know. I'm just learning 3D but
been doing 2D art for a long time. Just my opinion though.
Little Moo's Place is at http://members.xoom.com/little_moo/
See my WET images and my web page design sets!
