it would be a bit easier to tell if you showed te source.
A guess : It can be shadows from your light's. Try setting them as
shadowless
Try also to use an antialias, that will probably help a bit.
And, thanks for NOT sending .bmp files anymore. They are a mess to
download.
Another tip:
add +FN in your command line argument(edit settings/render)
This will make povray output .PNG files, taht are far smaller than a
.BMP.
The .PNG files can be read in any decent image viewer(PaintShopPro,
Photoshop, AcDc, Sea, Graphic workshop and more.)
//Spider
kane wrote:
> does anyone know what causes the cuts in these lines , how to avoid
> having them?
> [Image]
Not sure about the white line down the center but the others can be
improved upon by using a Antialias_Depth=4 or +R4. Antialiasing needs to
be used too. Put a +A0.3 and +R4 on the command-line dialog, or place
Antialiasing=On [on/off] Antialias_Threshold=0.3 (decimal numbers)
Antialias_Depth=4 (integer numbers) into an INI that you use to render
with.
The +R4 (or higher) is slower than default +R3 but can help to "see"
thinner lines or smaller dots.
If you also use +AM2 (Sampling_Method=2) lower the +R back down because
it increases this anyway.
If there is a speckled appearance in a line and you don't want that, add
-J or Jitter=Off so jittering doesn't affect it. You may need to specify
a zero value to get it turned off instead.
> having them?
> [Image]
=Bob
