POV-Ray : Newsgroups : povray.binaries.images : Saturday night doodle. - Buddha01c1_.jpg (0/1) Server Time
23 Jul 2026 21:30:50 EDT (-0400)
  Saturday night doodle. - Buddha01c1_.jpg (0/1) (Message 41 to 50 of 97)
Subject: Re: Saturday night doodle. - Buddha01c1_.jpg (1/1)
Date: 1 Nov 2008 16:46:14
Message: <1vfpg4pl49lk4655vgtdeo1q3v6vtsmmel@4ax.com>
Date: 1 Nov 2008 22:37:37
Message: <490d1271@news.povray.org>
Jim Charter nous illumina en ce 2008-11-01 01:45 -->
> Stephen wrote:
>> On Sun, 19 Oct 2008 12:44:19 -0400, Jim Charter <jrc### [at] msncom>
>> wrote:
>>> You might try a 'splicing' border with fragments of the images
>>> interleaved to produce the transition.
>>> Or...rather than a graded transition, just some sort of framing.  I
>>> think the blunt edges abutted is part of the problem.
>> I'm not too sure what you mean, Jim.
>> I'm working on the sky first, rewriting the code for the stars. {I'm
>> using a
>> modeller and having 3000 stars as 3000 objects was slowing it down a
>> bit. (Beta
>> testing and you have to push the limits :)} After getting the day sky
>> to blend
>> in with the night sky I'll look at the plane.
>> So how would I splice the images on the floor? I'm thinking along the
>> lines of
>> your mosaic table and can't imagine how it could be done.
>> The framing is a good idea as well especially since the North - South
>> faces
>> don't match up.
> Sorry I never got back to this, finally forced myself to take a break
> from work and relax a bit.  I guess I didn't describe what I meant very
> well.
> Here are two examples of what I meant for posible transitions that are
> "spliced" as I tried to describe it rather than a smooth fade. (I think
> the smooth fade that Thomas suggested and you have managed so far is
> quite effective, btw.) Each of these examples is arrived at differently
> and probably rather crudely but my larger point is that there is not a
> single answer to either look or method to what I meant.  I am just
> popping an image_map in to stand for  the night v day backgrounds you
> have.  If you are rendering them directly of course, each of the methods
> I use here could be resolved into a pigment_pattern which could then be
> used with MegaPOV's camera pigment.
> I'll put the SDL on p.b.scene-files
> As for the floor I'll noodle on it a bit further
> -Jim
I prefer the top one. The bottom one looks to "geometric"...
Make yourself a better person and know who you are before you try and know
someone else and expect them to know you.
Subject: Re: Saturday night doodle. - Buddha01c1_.jpg (0/1)
Date: 6 Nov 2008 11:55:00
Message: <web.49132053390cc5e3d0bdfd6f0@news.povray.org>
Stephen <mcavoysAT@aolDOTcom> wrote:
> Just a doodle while thinking about changing an avatar.
>  Does anyone have any suggestions or comments?
> Regards
>      Stephen
Nice !
Would youo mind sharing where you got / or the source code of the budda?
Date: 7 Nov 2008 04:12:27
Message: <dj18h4923mgchj3uvvqjj8evnvtqq9oksm@4ax.com>
>> Regards
>>      Stephen
>Nice !
Sorry for the delay
http://www.3dvia.com/
Search for budda
Regards
Date: 17 Jan 2009 12:00:03
Message: <web.49720d68390cc5e3d0bdfd6f0@news.povray.org>
> >> Regards
> >>      Stephen
> >Nice !
> Sorry for the delay
> Search for budda
> Regards
>      Stephen
How were you able to convert from the 3dxml format?
Date: 17 Jan 2009 13:34:16
Message: <st84n41vm9udcvfs5dd6v3h39ielq6rplv@4ax.com>
>> Sorry for the delay
>> Search for budda
>> Regards
>>      Stephen
I didn't. I downloaded the 3ds format ;)
http://www.3dvia.com/MichelAngelo/models/F516D9EBFDCFE1F3
Click "download" and select.
Original 3ds File (1.17 MB)
Then register to download.
Regards
Date: 20 Jan 2009 07:20:01
Message: <web.4975c074390cc5e3aefa83390@news.povray.org>
> >> Sorry for the delay
> >> Search for budda
> >> Regards
> >>      Stephen
> Regards
>      Stephen
Forgive my ignorance, what program did you use to convert from 3ds. Is it
free/open source I currently only know of one shareware program, and I am not
particularly keen on using it since it goes against my hippie philosophy of
promoting open source.
Date: 20 Jan 2009 07:42:12
Message: <4975c6a4@news.povray.org>
"Woody" <nomail@nomail> schreef in bericht
news:web.4975c074390cc5e3aefa83390@news.povray.org...
> not
> of
Poseray does the job  :-)
Date: 20 Jan 2009 07:45:00
Message: <web.4975c627390cc5e3bdd9e4330@news.povray.org>
I guess you're not running Windows; otherwise I could recommend - without
thinking - two free tools that do both 3ds import and POV export: Wings 3D and
PoseRay.
For Linux, you may want to try the Wine / PoseRay combo. PoseRay claims to be
running perfectly fine on Wine. Cheers!
Date: 20 Jan 2009 08:32:57
Message: <d9kbn4ll0lb5964mjui56c9jdoe8qrka8e@4ax.com>
That is three of us voting for PoseRay, which can be run under Wine, if you are
using Linux. There is no mention of a licence that I can find.
http://mysite.verizon.net/sfg0000/
And this old hippy wants to know what's wrong with "open source"?
Regards
