In message <web.42dcff7c811cc7c3d46eca60@news.povray.org>, PM 2Ring
<nomail@nomail.?.invalid> writes
>Alex <pov### [at] lazysodorguk> wrote:
>> In message <web.42d322fa811cc7c3ad93754b0@news.povray.org>, PM 2Ring
>> >> Currently unemployed, I decided to have another crack at doing Penrose
>> >> tiles, the hard way. After a week I gave up and did them the easy way :)
>What's the hard way? Placing them "by hand". I've done a few like that...
Projecting a specific subset of a 5 dimensional integer lattice onto a 2
dimensional plane to give the vertices of the rhombs. The principle is
very simple, and it's easy to do with a 3 dimensional lattice, but for
the life of me I can't work out the nitty gritty of the higher
dimensional cases. All the resources I can find just explain the
principle.
Method discovered by deBruijn.
See http://gregegan.customer.netspace.net.au/APPLETS/12/12.html for an
example, click the applet until you get Penrose tiling. Some of the
other applets on the site are well worth checking out, "Wythoff" is
another stunning one which gave my a couple of ideas for geomag.
>> >They can be tricky! :) What technique did you use? Here's one I posted back
>> >in April: <web.425b6e5da45a985aad93754b0@news.povray.org>
>> See other post. I'm afraid I must have missed your post, I've been
>> subscribed to the group for some time but skipped some posts recently in
>> order to catch up. I shall attempt to request it with my newsreader!
>And I missed this post (and the one from Thomas), but I just use the Web
>interface. If you want to see my earlier pic, the Web interface may be the
>easiest way, because from here, links like the one above are live.
>> >I first started using Penrose macros from Boxer by John VanSickle, but I
>> >ended up making up my own macros. I can post the sources if anyone's
>> >interested.
>> I remember seeing some of those animations. Some interesting patterns &
>> objects. Can't say I can remember any Penrose tiles, I may go look
>> later.
>I never actually saw the Boxer animations. I found it through Google,
>searching for "Penrose tiling". From the source code, the Boxer anim uses a
>simple flat Penrose tiling for the floor.
Just found it on my HDD. The tiling was quite subtle, I never noticed it
before!
>> >FWIW, you can get very
>> >powerful magnets out of dead hard drives.
>> I've taken 2 apart before. I have several other dead ones I could
>> dismantle. The magnets are very brittle, though.
>Very brittle, indeed. And they can attract each other with enough force to
>fracture them, so I have lots of small pieces of them. These magnets are
>*not* toys! Keep out of reach of children! Skin pinched between
>supermagnets is painful! :)
Glad I'm not the only stupid person :)
>> >Anyway, here's a close-up of an earlier Penrose tiling I did. We seem to
>> >have chosen similar colour schemes.
>> I chose my colours so they averaged to 50% grey, that was the first pair
>> I found that didn't look awful.
>:) Things start getting awfully muddy down at that greylevel.
I lied about my colour scheme, all the pairs of colours looked awful so
I used something different.
>>I thought it might help the appearance
>> of the blurred reflections of distant tiles.
>That makes sense. Still, the floor is a little too dark for my tastes.
Maybe. But make everything bright and the highlights don't show up as
much. It's a difficult one to judge.
>> And you've done proper
>> curved edges, I just did a flat bevel by intersection of planes.
>Those curved edges... They were a bit trickier than I thought they were
>going to be. I ended up making one macro for rounded isoceles triangle
>tiles, and another one for rounded polygonal prisms. I suppose I should
>tidy them up a bit and post them.
That's why I didn't bother. Achieving a constant width gap between
different shaped tiles was tricky enough.
>Here's a Penrose tiling, using rounded pentagonal prisms, in standard stone
>textures. The tiles were placed by simple #while loops, not recursive
>macros.
Similar to a "pentaflake" fractal, but with some pentagons filling the
larger gaps.
Alex
In message <web.42dd997f811cc7c3ad93754b0@news.povray.org>, PM 2Ring
>> principle.
>Of course, how could I forget. I thought of using deBruijn's method, but I
>couldn't figure out a way to do it in POV. Also, it's been a while since
>I've played with higher-dimensional geometry, but I think that simple
>orthographic projections are used to project from n dimensions to n-1
>dimensions.
Yes. Projecting from n to n-3 dimensions is more tricky. I thought I
sussed out how to do it (for the umpteenth time), but once I coded it it
didn't work and I couldn't be bothered to look at it any more. I had
originally hoped to be able to create a procedural texture!
>If I understand this stuff correctly, the deBruijn construction is a regular
>5D Voronoi diagram, so it should be easy to implement in POV by modifying
>the code for the crackle pattern.
I'm not messing with source code. I never did suss out c.
<snip>
>I suppose that this is where Jaime's Lightsys comes in very useful, although
>I've just started exploring Lightsys myself.
Just had a quick look at it, looks interesting. Lighting can be very
tricky.
>> >macros.
>> larger gaps.
>Yes. I few years back, I wrote a little C program for my Amiga to play with
>pentagonal tilings by hand. I spent many, many hours exploring these
>tilings.
I never knew about these tilings until relatively recently, although I
have programmed similar L-system fractal algorithms on my old CPC464.
Alex
In message <web.42dd8e85811cc7c3ad93754b0@news.povray.org>, PM 2Ring
>"PM 2Ring" <nomail@nomail> wrote:
>I don't know what's happened to my last 3 posts! I'm certainly not posting
>blank messages. And how come Alex could see one of them? Very strange!
I can see all of them. 5 in this thread so far.
Perhaps I'm just more perceptive :)
Alex
Download 'rprismh1.jpg' (4 KB)
Download 'achmeag5.jpg' (125 KB)
Preview of image 'achmeag5.jpg'
PM 2Ring wrote:
> I've rendered the demo files & am in the process of transforming one
> of Jaime's indoor scenes, rearranging and modifying the furniture &
> adding little things like a door handle. See below for an example.
Nice improvement! The arrangement seems more natural than on my poor
demo (but the patio image on the frame needs a gamma correction... :)
> Ah! The old Amstrad. Such a pleasant machine to program.
Yeah.. It was too my first computer. I programed there with BASIC
some prehistoric computer graphics...
Jaime
Download 'achmeag5.jpg' (2 KB)
Download 'achmeaa2.jpg' (113 KB)
Preview of image 'achmeaa2.jpg'
In message <web.42e0ac70811cc7c35464b3b50@news.povray.org>, PM 2Ring
>I've been programming in C for almost 25 years, but I wasn't suggesting that
>it would be a task for we lesser mortals. :) I was hoping that deBruijn's
>construction might be incorporated as a standard pattern into the official
>POV, some time in the future.
Can't see it myself, but if somebody can add quaternion fractals to
Povray then I suppose anything's possible.
>> tricky.
>I've rendered the demo files & am in the process of transforming one of
>Jaime's indoor scenes, rearranging and modifying the furniture & adding
Looks good. Why are you growing plants in a sports trophy?
>> >> >standard stone
>> >> >macros.
>> >> larger gaps.
>> >tilings.
It was a great machine, as was the ZX81. I just wish the IBM PC had been
based on the Z80 processor as well :)
Alex
