POV-Ray : Newsgroups : povray.binaries.images : Cloth Textures v0.11 Server Time
4 Jun 2026 23:12:33 EDT (-0400)
  Cloth Textures v0.11 (Message 11 to 20 of 29)
<<< Previous 10 Messages Goto Latest 10 Messages Next 9 Messages >>>
Subject: Re: Cloth Textures v0.11 (on Table Cloth)
Date: 16 Sep 2002 12:51:04
Message: <20020916221843.6752733b.kedarDELETE_THIS@patilkedar.com>
Similar red-white texture on a table cloth.  Cloth mesh is from
the balcony scene, as suggested by ABX.
+A0.3 +W800 +H600 on P-III 997 Mhz 128MB RAM.  It was 4 minutes
with 3.5 MB peak memory usage.  Not bad, I guess.
Thanks to Aaron, ABX, Christoph and Hugo.  I will see what I can
do with your sugggestions.  But that will be tomorrow; I've got
to sleep now.
-Kedar
Download 'clothdemo2.jpg' (77 KB)
Preview of image 'clothdemo2.jpg'
Date: 16 Sep 2002 12:57:29
Message: <3d860d79@news.povray.org>
Congratulations ...
Amazing.  I take back what I said before about needing something
else.  This looks great when applied to the right object.
Aaron
Aaron Gillies
New York City
x3rxes[%]yahoo.com
Date: 16 Sep 2002 16:07:22
Message: <3d8639fa$1@news.povray.org>
That is downright wicked. I applaud your efforts!
-Jide
Date: 17 Sep 2002 03:07:43
Message: <20020917123528.3a2e8038.kedarDELETE_THIS@patilkedar.com>
On Mon, 16 Sep 2002 12:57:27 -0400 "Aaron Gillies" <no### [at] spamcom>
wrote:
> Congratulations ...
Thank you.
> something else.  This looks great when applied to the right
> object.
Thanks again.  That's what I hoped and hence I had asked for a uv
mesh to test it :)
But no need to take your words back.  I gave it a thought last
night and I think some randomness should help when the textures
are used at larger scale.  As of now the slopes and normals are
crude and uniform.  Large scale textures (thick threads) would
look bad; for example an easy-chair which Batronyx wanted to do.
-Kedar
Date: 17 Sep 2002 03:14:34
Message: <20020917124227.53cf7969.kedarDELETE_THIS@patilkedar.com>
Thank you!
-Kedar
Date: 17 Sep 2002 03:18:31
Message: <3d86d747$1@news.povray.org>
You could try a rendering with:
+AM2 +A0.0 +R2 -J
Does the slopemap work alright when it's UV mapped?
It doesn't look wrong, I'm just curious..
Keep us posted,
Hugo
Date: 17 Sep 2002 03:36:29
Message: <20020917130422.0780bdd7.kedarDELETE_THIS@patilkedar.com>
> +AM2 +A0.0 +R2 -J
OK.  In a couple of hours, I will post it.  By the way, I can't
see the moire patterns you are talking about.  (Maybe I am not a
good obeserver.)
Yes, it works fine.  In fact I got this idea of making cloth
textures when I discovered that while playing around with slope
maps.
-Kedar
Date: 17 Sep 2002 03:59:45
Message: <3d86e0f1$1@news.povray.org>
> I am not a good obeserver.)
Thanks. Well, the moire is not too ugly in this case, but it's definitely
there (when something is small, like those threads) and it gives a bit of a
false impression of the texture. I'd like to see 'the real look' of the
texture by removing the moire. Probably it will look less random...
;o)
Hugo
Date: 17 Sep 2002 07:28:10
Message: <20020917165549.7ff76247.kedarDELETE_THIS@patilkedar.com>
> definitely there (when something is small, like those threads)
> and it gives a bit of a false impression of the texture. I'd
> like to see 'the real look' of the texture by removing the
> moire.
Now I understand your previous comments better :)
Yes, it looks less random and smoothed out with the settings you
suggested.  But with -J there is an ugly moire pattern visible on
top.  See the attached images (both 800 x 600) --
 cloth1.jpg with +AM2 +A0.0 +R2 -J
 cloth2.jpg with +AM2 +A0.0 +R2
Both took about 8 minutes each to render. (The second one took
about 20 seconds less than the first one)
-Kedar
Download 'cloth1.jpg' (67 KB) Download 'cloth2.jpg' (68 KB)
Preview of image 'cloth1.jpg'
Preview of image 'cloth2.jpg'
Date: 17 Sep 2002 07:51:43
Message: <ih5eousgu75gr6o820dmq4kepu6m6rskaa@4ax.com>
On Tue, 17 Sep 2002 16:55:49 +0530, Kedar Patil
have you tried higher recursion ?
btw: what is this strange artifact near center of image, on bend ?
ABX
