This is a project I started over 20 years ago by modeling an orrery. Then had
to figure out a scene to put it in. This is what I finally came up with. Turn
looping on in your player. I would get stuck on it, or real life interrupted,
put aside for a few years then repeat. I'm not very happy with the clouds the
camera flies through, not enough turbulence. There is also some flickering I
haven't been able to get rid of. The camera has a couple of abrupt moves I need
to smooth out. I do plan to add more objects to the scene. Any comments or
suggestions would be welcome.
And you're still at it! Good work.
It's been a long time since I've seen one of these classic animations.
>Then had
Clouds are notoriously difficult.
I didn't really notice anything, so it must be a very small problem.
> to smooth out.
When you're about to make a sharp turn, slow down the camera dramatically.
Look into "smoothing functions" to get the sort of thing you want.
I like the island a LOT.
The house, the working lighthouse (make the light MUCH brighter), the ceiling
fan, the periodic table, the stencil on the desk....
The orrery sun could be a bit brighter/yellower.
I like the checkered bed. Perhaps a silvery pillow would be a nice "easter egg"
nod to the RSOCP. It's always fun to sneak some classic POV-Ray / computer
graphics models, or someone else's POV-Ray model/effect into a scene.
If you hit any more stumbling blocks, don't be afraid to ask for ideas or
solutions. Set your goal on the finish line!
- BE
> >Then had
> > to smooth out.
> - BE
Thank you for the suggestions. I made a few changes and reposted a new
animation. The flickering is much more noticeable at higher resolutions, I
rendered the animation at 1280x720 then reduced it to 640x360 to get the size
down for posting. The planet maps came from a NASA web site, I picked a new sun
that is brighter and yellower. It does look better. The checkered bed was a
nod to the RSOCP, but the pillow reflects the creme colored walls not the bed
and it almost looks translucent not reflective. At the time I created the
lighthouse I didn't know the color rgb values could be greater than 1.0. I
increased the value and it looks much better. I wrote a program to generate the
island, started with a pyramid and recursively divided the faces into smaller
triangles and translating the vertices a random amount up or down and then
created a mesh2 object. I then populated the island with 24000 trees and 32000
bushes that were created by Arbaro 2.0. Now I need to work on the camera
transitions.
Download 'island640.mp4.dat' (3548 KB)
Very nice. I did an orrery some time ago:
<https://www.youtube.com/watch?v=GyqQolOK_qI>
I remember one of the first scenes I animated was a lighthouse (using Polyray)
way back when :-)
m@b
> way back when :-)
> m@b
Very nice. I particularly like the way you morphed the planets into the orrery.
Impressive.
> > way back when :-)
> > m@b
> Impressive.
