"Maetes" <nomail@nomail> wrote:
> Few ideas:
> let the robots sometimes think a while.
> or let them stop before grabbing, and choose another move.
> and move the camera, maybe slowly aroud the scene, but always a tiny bit.
> ma
I like that idea, moving the camera will be simple. Changing its mind will be
a bit more difficult.
> "Clarence1898" <dle### [at] comcast net> wrote:
> > Going through an old archive I found this animation I wrote 20 years ago.
> Looks really really cool :)
> Cant wait to see Version 2.0
> Ma
This is the reason I made the change, so I could run multiple games at the same
time. I think it is a bit amusing watching the robots bob up and down. I have
a question about how everyone else renders animations. I wrote the original
scene in 2003, probably on a pentium cpu using povray 3.5. It was terribly
slow. When I got another pc, I wrote a program to render frames on both pc's.
When I upgraded to pc's with multiple cpus I changed the program to use multiple
instances of povray on each pc. With 3.7 I changed the program to use the work
thread option, but I found that using multiple instances of povray still gave
me better throughput. Four years ago after recovering from covid, I splurged
and purchased an intel I9 10900k pc with 10 cores and 20 logical processors. I
know it sounds ridiculous but running 20 instances of povray was 4 times faster
than running 1 instance with 20 threads. Individual elapsed times were slower
but total throughput was 4 times as many frames per minute. I know that this is
low resolution (720x400) and a very simple scene so I tested several
resolutions: 1920x1080 was twice as fast, 3840x2160 was still 60% faster. I'm
sure more complicated scenes would decrease the difference. Still I would like
to know how everyone does their rendering.
Download 'robot4.mp4.dat' (4660 KB)
> Going through an old archive I found this animation I wrote 20 years ago. I
> wanted to make a few additions but couldn't believe the code I wrote. Decided I
> could do a better job 2nd time around. The rewrite isn't finished yet so still
> a work in progress.
I'm like you going though my old archives. Have you found any code that you say
to yourself 'Did I really write that!?'.
I like the animation after I got it to play. I down loaded it and tried window
media player, it came up with screen 'needs a new codex 99 cents'
Where did the game come from? A while back I was testing ways to position pieces
on the chess board and taken pieces placed around it. I got online and found a
lots of tournament games (which I didn't bookmark their locations)
Have Fun!
> > a work in progress.
> Have Fun!
I have looked at my old code so many times and thought what was I on when I
wrote that. Not only my personal code but code I got paid for. The games I
used came from chessgames.com 1000 Best Short Games here:
https://www.chessgames.com/perl/chesscollection?cid=1034766
I used the short games to keep the video size below 5000K.
I always have fun.
> Still I would like
I use Raspberry Pis for it.
One is my standard computer for all days work, and another I turn on when I have
long movies to render.
Connection via SSH or virtual desktop.
That they need 1 or 2 days for a 2000 frames HD Moon- or Mars-Video doesnt
matter to me.
Pis are cheap, small, silent, energy-efficient.
And when there is nothing to render, you can use it as Media-Server or anything
else.
ma
> Still I would like to know how everyone does their rendering.
[running Windows 10]
Hi!
I have been rendering POV-ray animations for many years, all the way back to
Windows 98 days, when machines had only single cores. Now I have a Corei7
machine with 8 cores/16 threads. (Quite an improvement, ha.)
To be honest, I was not even aware that multiple instances of the app could be
run *successfully*...that is, with an overall speed improvement for a scene or
an animation...since it has always been my understanding that even a single
instance of POV-ray uses most of the resources of the entire machine for
rendering. At least, that's the way it used to be on my various single-core
machines through the years. (And AFAIU, initially *parsing* a scene uses only
one thread, regardless of how many threads are available.)
But the faster results of your multi-instance use are a real surprise! I will
have to give that a try, to see what the speed improvement might be for my own
animations.
There remains a question, though: When running multiple instances of the app on
multi core/multi thread machines, does each instance's scene parsing use it's
*own* single thread to do so? I.e., with 3 instances running (for example), are
there now 3 threads dedicated to parsing the (3) scenes? Or just one thread as
is typical-- split up between the 3 instances?
> > Still I would like
> matter to me.
> else.
> ma
Yes the Pi is a very nice machine. I run Hercules, an IBM mainframe emulator on
a pi 5. More ram, aux storage, and faster than the 3081 I worked on in the
1980's.
> Hi!
> animations.
When I started using multiprocessors I noticed the performance advantage of
multiple instances, but it was on a much smaller scale. It was only with more
and faster processors that it became noticeable. With my first quad-core system
the difference was about 15% improvement. With a 20 cpu i9 the difference is up
to 60%. For more complex scenes the smaller the difference, but still
noticeable.
As I understand it, each instance is completely independent from the others.
Each instance will have its own threads.
hi,
> ... Still I would like to know how everyone does their rendering.
I have an "elderly" i5 dedicated to renders. I have not tried running multiple
instances[*] but like your time-savings observations.
[*] played briefly, some years ago, with multiple version 3.6, even tried to get
3.5 to build/run :-).
and thanks for including the ffmpeg command-line too when you posted robot1
(3.4M is small).
regards, jr.
>> Hi!
>> animations.
> noticeable.
When using POV-Ray version 3.6 and earlier, you couldn't use more than a
single core/thread. So, back then, using several instances was the only
way to use all of your cores on a multi-core system.
The main feature of version 3.7, and the reason it was developed, is the
ability to use all the cores of modern CPUs.
