POV-Ray : Newsgroups : povray.binaries.animations : Music Video Project Server Time
31 Oct 2024 12:17:30 EDT (-0400)
  Music Video Project (Message 11 to 20 of 36)
Subject: Re: Music Video Project
Date: 12 Apr 2021 07:00:00
Message: <web.6074272e432b07e11f9dae3025979125@news.povray.org>
"Dave Blandston" <nomail@nomail> wrote:
> I am in luck regarding my hope of being able to see changes in the music better
> than just looking at the waveform. I got the spectral display up and running and
> it makes it pretty easy to spot acoustic "events." The screen shot of the first
> five seconds of music that I'm using clearly shows six quick bass notes then
> three slower ones then five quick ones etc. The time display is in milliseconds
> which is plenty accurate. Unfortunately there are many hundreds of musical
> events that I will have to log by hand. But the final product should be nearly
> perfect.
> Thanks for sharing your technique!
Silly cro-magnon idea here -
what about using sheet music and a ruler?
Date: 12 Apr 2021 08:30:01
Message: <web.60743c48432b07e179416a1f9334df62@news.povray.org>
Ha ha I wish!!!
Correction: 6 - 3 - 6 etc. bass notes...
Date: 12 Apr 2021 08:40:00
Message: <web.60743e37432b07e179819d986cde94f1@news.povray.org>
hi,
> ... The time display is in milliseconds
don't you own a computer?  :-)
anyway, reading this I (may have) got carried away and wrote a few lines of
script[*] over lunch (can't tell what OS you're running from the screenshot,
however, if you haven't Tcl/Tk installed, it is freely available on all
platforms).  run it, right-click to start, left-click or 'b' key each beat, then
right-click again to stop; 'q' at any time to abandon.  the only thing left to
do, as exercise for the interested reader ;-), is subtracting the initial mark
from all subsequent ones, and writing them to file.  hope you'll enjoy it, I
certainly did.
[*] hack. :-)
regards, jr.
#!/usr/bin/env wish
proc doStuff {} {
  global T
    set a [lsort -integer [array names T]]
    set from [lindex $a 0]
    set to [lindex $a end]
    set n [llength $a]
    set s [format {recorded %d beats, total ms: %d} $n [expr {$to - $from}]]
    tk_dialog .dlg foobar $s info 0 ok
  return
proc rightClick {} {
  global rt T
  if {!$rt(run)} {
    set rt(run) true
    set rt(begin) [clock milliseconds]
  else {
    unset rt(run)
    if {![array exists T]} {exit 99}
    doStuff
    destroy .
  return
proc leftClick {} {
  global rt T
  if {$rt(run)} {
    set T([clock milliseconds]) {}
  return
set rt(run) false
label .lbl -padx 2cm -pady 2cm
pack .lbl
bind . <KeyPress-q>  [list destroy .]
bind . <KeyPress-b> leftClick
bind . <ButtonRelease-1> leftClick
bind . <ButtonRelease-3> rightClick
Date: 12 Apr 2021 08:50:00
Message: <web.6074414a432b07e179819d986cde94f1@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
ouch, complete with bug even.  forgot to use 'rt(begin)' hence subtracting from
wrong value.  </hang-head-in-shame>
regards, jr.
Date: 12 Apr 2021 14:40:00
Message: <web.607492fb432b07e1d98418916e066e29@news.povray.org>
> Hey this is super interesting! We are doing some very similar things - I am also
> using local "Event clocks" that go from 0 to 1 at pre-determined intervals, and
> look how similar our "smoothing" functions are:
> #local ClockFactor = (sin (radians (EventClock [I] * 180 - 90)) + 1) / 2; //0 ..
> 1
> #local ClockFactor = pow (ClockFactor, 1); //Adjust for a faster or slower start
Just a suggestion:
Although clock, clock_delta and Final_Clock are great tools for creating
animations, and for causing 'events' to happen at certain times, I use
frame_number (or some fraction thereof) more often now. It's probably a personal
choice, of course; but frame_number seems more intuitive to me-- and I don't
have to think in 'clock division' terms for the timing of animation events.
I'm currently reworking an old and complex animation scene, which has various
#include files, where I used clock etc. exclusively throughout the scene. It
worked beautifully at the time-- but I'm thinking now of extending the length of
the entire animation with some new action at the end, maybe by 25%, but
without messing up all of the clock-specified events and timings that are
already there. I *could* simply change Final_clock to be 1.25, but I'm not yet
sure what that will do to some of the events which actually depend on the
(previous) clock-end of 1.0.  As a simple example,
#if(clock <= 0.3) --do this-- #else -- do that-- #end
.....but now I don't want the #else action to extend past a clock of,say, 1.15. I
could easily change the #if clause of course, but changing all such constructs
to use frame_number instead tells me exactly and visually when to expect the
action, or to easily change it.
I also like frame-number because, after a test animation, I can immediately see
where any animation glitches need correcting-- at which frame, in other words,
without having to make a clock-division computation to figure it out.
However, I haven't yet worked out how to 'start and end events slowly like an
S-curve' as was mentioned previously, when using frame_number instead of clock.
I'll have to explore that!
But your music video project uses a song length that is 'set in stone', so using
clock is a perfectly natural way to achieve the results.
[Btw, I just discovered that the Audacity app can show 'spectral timings' for a
song too, like the image you posted; I had never used that feature before.
Thanks for the suggestion!]
Date: 12 Apr 2021 18:10:00
Message: <web.6074c48f432b07e179416a1f9334df62@news.povray.org>
> hi,
This sounds intriguing - I've never heard of Tcl/Tk so I'm not sure what you
mean - should I run this script then play the song and press the "b" key every
time I hear a beat, and the script will record the timing of the keypresses? If
so then I must admit that I have no musical talent whatsoever of my own and my
ability to keep a beat is nearly non-existent. If you saw me TRY to dance you
would immediately agree that I would fail terribly at this!
Have a great day!
Kind regards,
Dave Blandston
Date: 12 Apr 2021 18:25:00
Message: <web.6074c777432b07e179416a1f9334df62@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> Just a suggestion:
That's interesting - I had forgotten that frame_number even existed because I
got used to using clock years ago, but I can see that frame_number would be more
appropriate under some circumstances, possibly including this one. I did in fact
have to include some code to convert number of frames generated to time elapsed
so using frame_number would be exact instead of within 1 / framerate / 2. The
beat markers will be in milliseconds which would have to be converted to
frame_numbers though so it's a trade-off either way. Thank you for the excellent
suggestion!
Have an awesome day Kenneth!
Kind regards,
Dave Blandston
Date: 12 Apr 2021 18:35:00
Message: <web.6074ca63432b07e179416a1f9334df62@news.povray.org>
Here's a short test to show the use of the "spectral" display to locate beat
times. It appears to be right on. (Note that not all beats are used, but when a
visual transition does occur it coincides with a beat.) It's great that Audacity
includes this functionality!
https://www.youtube.com/watch?v=RifdL-c0QMM
Kind regards,
Dave Blandston
Date: 12 Apr 2021 19:25:00
Message: <web.6074d6b8432b07e11f9dae3025979125@news.povray.org>
> already there.
Those ought to stay exactly the same.
If you're just increasing the number of frames, then everything should stay the
same as well.
If you are _appending_ more things to the animation, then maybe just declare a
Clock2 variable that is
#declare Clock2 = max (1, 2-clock);
Then when the 0-1 clock "runs out", you get a second 0-1 clock variable to use.
You can also just search-replace all of your "clock" instances with "Clock"
#declare Clock = min (1, clock);
so that it stops at 1.
"Smoothstep" in glsl, shadertoy, etc.
https://en.wikipedia.org/wiki/Smoothstep
https://www.youtube.com/watch?v=60VoL-F-jIQ
https://iquilezles.org/www/articles/ismoothstep/ismoothstep.htm
https://thebookofshaders.com/glossary/?search=smoothstep
Date: 13 Apr 2021 02:41:34
Message: <60753d1e$1@news.povray.org>
>> 1
> Just a suggestion:
Good points.
Further - frame numbers are better if you are including video frames in
an animation. Using clock derived functions results in dropped or
doubled frames from time to time.
You can't do it with frame numbers directly as each frame has a fixed time.
Presumably you could use the formulas as mentioned above and just
substitute Frame_A, Frame_B instead if Time_A, Time_B to make a local
clock? the start and end points would still be tied to frame numbers.
