POV-Ray : Newsgroups : povray.binaries.animations : Particles in space - collision.mpg (0/3) Server Time
23 Jan 2025 09:27:20 EST (-0500)
  Particles in space - collision.mpg (0/3) (Message 1 to 6 of 6)
Subject: Particles in space - collision.mpg (0/3)
Date: 23 Feb 2004 13:40:03
Message: <s0hk30tjvnb2ig37u4hqmtt4ukgcma8jtq@4ax.com>
Particles again :)
I use  a external particle system Part3d
(http://mark.technolope.org/part3d/) to generate data files of 2
masses of particles colliding. I have modified this program in order
to handle multiple colors, so I can separate out the various bodies.
Enclosed is the raw data: particle spheres  colliding with each other,
acting on speed, energy & self gravitation.
Question:
In the end I want to make a animation of two planets colliding,
so I converted the particles to blobs. That went ok. Then I put a
image map of the earth on the blob.....what a mess....distortion all
over. No matter how much I translate and scale, i cannot get a proper
planet.
Has anyone done such a thing ?
Willem
Subject: Re: Particles in space - collision.mpg (0/3)
Date: 23 Feb 2004 19:10:42
Message: <403a9682$1@news.povray.org>
<WillemW> wrote in message
news:s0hk30tjvnb2ig37u4hqmtt4ukgcma8jtq@4ax.com...
> Question:
> planet.
Hello again. Can't say that I have, that I ever remember.
If you're using map_type 1 and applying the pigment to the entire blob (not
individual components) I don't see any reason for it not to work right. At
least until it begins to change away from a spherical shape. Once it begins
to distort away from a sphere the image can't map to individual parts
properly when using an ordinary image_map without uv mapping. I have no idea
if blob can ever be uv mapped. In any case, translate and scale shouldn't
matter for map_type 1.
Bob H.
http://www.3digitaleyes.com
Date: 24 Feb 2004 01:09:52
Message: <403aeab0$1@news.povray.org>
Wow... It looks pretty impressive :)
I like it! I just hope it was much longer.
Fernando
Date: 24 Feb 2004 04:05:11
Message: <pan.2004.02.24.09.03.32.233528@nomail.com>
He !, I am already crossing the boundaries here....
Check out following stuff on my home server (ADSL):
 http://dewilde.xs4all.nl/p3d/stats/Stats.htm
 http://dewilde.xs4all.nl/p3d/co2/
 http://dewilde.xs4all.nl/p3d/co/
By the way, thanks for your particle stuff, I am still working on it...
Willem de Wilde
Replace the DOT with dots: Willem DOT de DOT Wil### [at] Xs4allnl
Date: 24 Feb 2004 13:11:46
Message: <403b93e2@news.povray.org>
WillemW wrote:
> Hi,
> Particles again :)
Wow those are some amazing animations!! Good work!
Date: 25 Feb 2004 12:49:19
Message: <403ce01f$1@news.povray.org>
"Hughes, B." <omn### [at] charternet> wrote in message
news:403a9682$1@news.povray.org...
> > Question:
> > planet.
It should be more or less ok if you add the texture for every component, before
you translate the component away from it's initial position.  Hope this makes
sense :)
cu!
