Hi All,
Just a little aniation I made with Megapov mechsim feature. It took about 4
hours of rendering and I nicked the radiosity setting mostly from Andrew
Cocker ( There are a few artifacts still left, but I didn't want to rerun
it (besides I have no clue what to change anyway ) ).
If anyone wants the code let me know and I will post it.
Download 'stairs.m1v.mpg' (367 KB)
Subject: Re: mechsim: stairs and balls mpg1 367 KBU (1/2)
Date: 21 Jan 2003 10:24:05
Message: <3e2d6615$1@news.povray.org>
Needs a slight random variation in the bounce - there is no way in RL the
balls would all line up perfectly at the bottom
PGP Public Key
"Rick [Kitty5]" <ric### [at] kitty5 com> wrote in news:3e2d6615$1@news.povray.org:
Good point, maybe someting for a next version. Thanks
Date: 21 Jan 2003 12:26:41
Message: <3E2D82D0.88850594@gmx.de>
Thomas van der Veen wrote:
> Hi All,
As Rick noticed you should add a tiny amount of sideward motion to the
balls at the beginning. Apart from that it looks good.
But please don't post binaries split into several messages here, i was
only able to see the first part.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Christoph Hormann <chr### [at] gmx de> wrote in
news:3E2D82D0.88850594@gmx.de:
Thank you. I might try that sometime, I'm currently redering some falling
balls and they colide in the air which gives it some randomness.
If I knew how to change my news reader ( XNews ) I would do that, sorry.
in news:Xns### [at] 204 213 191 226 Thomas van der
> sorry.
In the message edit pane, under the tab "4. Attachments" you can set the
"Cut size" to 15000 lines. If you want to set an even higher value you'll
have to do it in xnews.ini (under the tab Attachments 8000 will be shown
then)
Ingo
Date: 21 Jan 2003 19:09:39
Message: <3e2de143@news.povray.org>
"Thomas van der Veen" <tho### [at] gmx net> wrote in message
news:Xns### [at] 204 213 191 226...
4
Don't know who wouldn't. Looks like fun.
Your newsreader seems to be breaking up posts. No idea what might have
gotten lost in the translation, the animation played without error.
Farewell,
