POV-Ray : Newsgroups : povray.binaries.animations : Pannellum Server Time
4 Feb 2026 21:27:10 EST (-0500)
  Pannellum (Message 1 to 10 of 23)
Subject: Pannellum
Date: 2 Apr 2017 20:51:55
Message: <58e19cab$1@news.povray.org>
I updated my spaceship scene and rendered new frames to be used with
Pannellum panorama viewer.
http://isometricland.net/panorama/pannellum.htm?config=pano-gh-scene-spinner.json
I still was not able to turn the interior atmosphere due to render
times. Even on the 16-core MS Azure server I am using for my renders
this month, things were taking too long.
Enjoy.
Mike
Subject: Re: Pannellum
Date: 2 Apr 2017 21:07:39
Message: <58e1a05b$1@news.povray.org>
> Enjoy.
> Mike
Forgot to mention there are strange square shaped artifacts in the blue
end caps of the scene. They exist in the source images as well. I don't
know what causes them.
Mike
Date: 3 Apr 2017 04:55:00
Message: <web.58e20cefd40b65bd9c5d6c810@news.povray.org>
Impressive scene. And maybe disorienting to some earthbound people. :)
If able to see it, is the atmosphere both ground-hugging and cloudlets floating
around?
Wild guess about the squares. Could it be something about the ends being
directly opposite and slightly reflective, max_trace_level?
Although I don't recall seeing unusual squared patterns from anything like that
before.
Date: 3 Apr 2017 05:40:02
Message: <58e21872$1@news.povray.org>
Yes it is impressive. :)
> around?
> before.
I would definitely check the max level first.
When you were making the trefoil, is there anything with an unusual
normal involved?
Regards
Date: 3 Apr 2017 08:14:00
Message: <58e23c88$1@news.povray.org>
Am 03.04.2017 um 03:08 schrieb Mike Horvath:
Looks like radiosity artifacts to me.
Your scene may need a more exhaustive radiosity pretrace.
Make sure you have `always_sample` set to `off` (or not set at all).
Date: 3 Apr 2017 12:35:20
Message: <58e279c8$1@news.povray.org>
Here are my global settings. Radiosity is disabled.
global_settings
	charset utf8
	assumed_gamma	1.0
	#if (!NoRadiosity)
		ambient_light	0
		radiosity
			pretrace_start	0.08
			pretrace_end	0.02
			count			20
			error_bound		1
			recursion_limit	1
			normal			on
			brightness		0.8
			always_sample	no
			gray_threshold	0.8
			media			on
	#switch (TexQual)
		#case (-1)
			max_trace_level 4
		#break
		#case (0)
			max_trace_level 4
		#break
		#case (1)
			max_trace_level 4
		#break
		#case (2)
			max_trace_level 4
		#break
Mike
Date: 3 Apr 2017 12:37:06
Message: <58e27a32$1@news.povray.org>
Thanks!
> around?
No, it is a constant density.
> before.
It could be, since I have it set very low.
Mike
Date: 3 Apr 2017 14:10:32
Message: <58e29018$1@news.povray.org>
Am 03.04.2017 um 18:36 schrieb Mike Horvath:
Then I have no idea what might cause the artifacts.
Date: 3 Apr 2017 15:50:01
Message: <web.58e2a6b4d40b65bd9c5d6c810@news.povray.org>
> > around?
Ah, okay, I was using my imagination anyway. No I'm wondering what that would do
in the spiral light... if that is a light.
> > before.
What is really strange about it, to me, is how one of the nearby artifacts
(after moving scene around) appears to have a 90 degree angle going on.
The square shapes form a sort of floor and wall, if thinking of it as partially
covering tiles without seams where they meet.
Hopefully you can see or find that too.
Date: 4 Apr 2017 06:00:01
Message: <web.58e36e8bd40b65bd883fb31c0@news.povray.org>
> global_settings
>  charset utf8
[snip]
Although I haven't seen your animation yet, the   charset utf  entry caught my
eye. Wasn't there another recent post about artefacts due to that? I think it
was in the post about the "Dokken" logo not rendering correctly.
