POV-Ray : Newsgroups : povray.binaries.animations : splinefollow.pov Server Time
7 Mar 2026 03:59:06 EST (-0500)
  splinefollow.pov (Message 1 to 10 of 15)
Subject: splinefollow.pov
Date: 5 Mar 2008 15:17:47
Message: <47ceffeb@news.povray.org>
I needed a simple scene with radiosity. So I tweaked splinefollow.pov
(available on povray/scenes/animations/splinefollow). I removed both
light sources and the sky sphere, added high ambient to the rings and
the vertical pole, and some high-quality radiosity. Animation frames
still took around two minutes each.
Video attached (XviD). Play it looped!
Yes, a first-person view follows :)
Download 'anim019.avi.dat' (487 KB)
Subject: Re: splinefollow.pov
Date: 5 Mar 2008 17:21:39
Message: <47cf1cf3@news.povray.org>
Too big to post here.
http://impfarm.imp.org/boinc/sample_results/anim021.avi
Date: 14 Mar 2008 13:54:54
Message: <47dac9fe$1@news.povray.org>
"Nicolas Alvarez" <nic### [at] gmailisthebestcom> wrote in message
news:47cf1cf3@news.povray.org...
    Excellent Nicolas! I haven't played with splines yet, but your anim
shows me what I need to do with my carousel animation. I'm nowhere near
finished with it, (it'll be a couple of years, I think), but I want to get
the carousel rotating, get the horses rotating and travelling up and down,
(all of those are now done), and then get the camera to whizz around amongst
the horses, up, down and around, avoiding the horses and riders obviously.
      Any pointers on how you get the spline to go where you want it go? Is
that side of it easy? I love PoV, but my worst problem with pure pov is
translating. It takes me *ages* to get any model where I want it to be. (No,
I haven't looked at splinefollow.pov just yet, but I will).
      How do you hook up one end of the spline to the other end? Is it as
simple as hooking up to the original start coordinates?
      Nice demonstration, thanks, it's just what I needed to spur me on with
my project.  :)
         ~Steve~
Date: 14 Mar 2008 14:15:44
Message: <47dacee0@news.povray.org>
I only changed lighting and textures. The follow-along-spline code comes
straight from the original sample scene, I didn't touch any of that.
Date: 14 Mar 2008 14:22:45
Message: <47dad085$1@news.povray.org>
news:47dacee0@news.povray.org...
>> Is that side of it easy? I love PoV, but my worst problem with pure pov
>> is translating. It takes me *ages* to get any model where I want it to
>> be. (No, I haven't looked at splinefollow.pov just yet, but I will).
       Yes, I know, but how do I change the trans coords to get the spline
where I want it to go when other things around the spline are moving up and
down and rotating? Guesswork? What's the efficient way of doing it?
         Any idea?
         ~Steve~
Date: 14 Mar 2008 14:24:25
Message: <35klt3du7s3k9csdqu48u7obj8a05js5b2@4ax.com>
On Wed, 05 Mar 2008 18:16:34 -0200, Nicolas Alvarez
Any chance of creating it as a mpeg? I cannot see it nor the big one. :(
Regards
Date: 14 Mar 2008 14:26:40
Message: <h7klt3l3g8p4mepbffn97ldkp3g21j94t6@4ax.com>
>         Any idea?
Use a modeller :)
I find that it is too hard otherwise.
Regards
Date: 14 Mar 2008 14:41:09
Message: <47dad4d5$1@news.povray.org>
"Stephen" <mcavoyATaolDOTcon> wrote in message
news:h7klt3l3g8p4mepbffn97ldkp3g21j94t6@4ax.com...
>>         Any idea?
> Use a modeller :)
   Thanks! I didn't know you could do that, I thought it was a pov only
thing! Cool, now the cookie's crumbled... ;)
       ~Steve~
> Regards
> Stephen
Date: 14 Mar 2008 15:02:43
Message: <47dad9e3@news.povray.org>
I had trouble getting ffmpeg to output a working mpeg2 (.mpg) file, but
let's see what I can do.
Date: 14 Mar 2008 15:14:47
Message: <jvmlt3t3a6mo5pkhuhihqgblqt4scmv712@4ax.com>
Bishop3D (in Beta but quite stable) can import your Pov file. You will have to
redo the animation but it shouldn't be hard. Like moray it does not support
everything.
http://www.bishop3d.com/
Regards
