POV-Ray : Newsgroups : povray.binaries.animations : Crazy ovals... Server Time
12 Oct 2025 21:38:57 EDT (-0400)
  Crazy ovals... (Message 1 to 4 of 4)
Subject: Crazy ovals...
Date: 10 Mar 2004 05:10:26
Message: <404EE991.D8CFFA24@sympatico.ca>
Hello Folks
  I am in need of help in solving a three part problem. Hopefully some
patient soul out there will look upon this request as a challenge and
not the nightmare I do!
  First, how is an elliptical orbital path for an object created?
  Secondly, how can the speed of the orbit and the shape of the path be
graduated individually or interdependently over a set variable of time?
  And finally, could an elliptical orbital path be intersected at any
two points with a straight line and rotated on that axis?
  Thanx in advance to any that respond,
   TGL
Subject: Re: Crazy ovals...
Date: 10 Mar 2004 06:20:17
Message: <404ef9f1@news.povray.org>
>   Hello Folks
Hi there!
Well, it depends on what you want to do and how you want to achieve it. If
you're merely wanting to translate an object along an elliptical path, well
then use the following:
#declare Elliptical_Position = vrotate(<1,0,0>,y*360*clock)*<1,1,.5>;
That'd give you a path on the y-plane, turning clockwise, and it'd be
"squished" on the z-axis, but main radius is 1 unit (from the <1,0,0> at the
beginning).
How would you change that gradually you ask? Either add something to the
initial <1,0,0>, e.g. enlargening it to <2,0,0> would double the size of the
ellipse. To further rotate the ellipse about some axis, just do this
#declare New_Position = vrotate(Elliptical_Position,z*360*clock);
This would move the object along an elliptical path, which itself rotates
about the z-axis. Different transformations can be applied as well, you just
need to understand what's going on and how to model it.
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 17 Mar 2004 13:34:30
Message: <40589a36@news.povray.org>
Note that povray.binaries.animations is for posting binaries, not really
for discussions, but I get the feeling that posting binaries there is a
much greater offense.
> beginning).
There are two shortcomings with this simple approach when used in regard
to orbits:
1) The ellipse or the central body (ie: the sun) needs to be shifted so
that the body is at one of the focii.  If your major axis is on X, then
use this in SDL with "a" the larger and "b" the smaller dimensions:
     #declare shift = sqrt(a*a-b*b)
In Tim's example, the "a" and "b" are the x and z coordinates of the
scaling vector: <1,1,0.5>
Of course, if the mass of the two bodies do not differ by many orders of
magnitude then you'll need to change this.  See:
    http://encyclopedia.thefreedictionary.com/barycenter
2) The speed of the satellite varies dramatically, especially with
eccentric orbits.  See:
    http://encyclopedia.thefreedictionary.com/Orbital+speed
    http://www.physicsforums.com/archive/topic/11435-1.html
The former helps with the velocity, but to render you'd need the
position instead.  Note that the "velocity" is a scalar (I was taught
"speed" was a scalar, and "velocity" was a vector, but that's
semantics).  In either event, we can't simply integrate the scalar to
get a formula for position.
On the flip side, if you don't mind chewing up lots of CPU cycles in SDL
loops, you can simulate this.  It seems good for viewing, but the errors
get excessive if you want any true realism.
See my "Simulated orbits" post in povray.binaries.scene-files and also
Baxbaum's post in povray.general "Re: But *how* to do the constant
energy solution for particle physics?"
Date: 18 Mar 2004 13:41:03
Message: <4059ed3f@news.povray.org>
I will post a set of macros (and an example scene file) in
p.b.scene-files for doing orbits -- *without* cumulative errors and
since it finds the location directly it is much faster.   Note, that it
iterates for precision, so the answer still isn't perfect, but the error
is not *cumulative*.
See Tim's post for rotating the orbital path (although I didn't try it
with these macros).
The scene file posted in p.b.s-f has a sun, earth and moon (with the
dimensions completely off by lazy intent), whereas this has only a
sun/earth.
Marvin
BTW, the post in p.g was by Dr. Engelbert Buxbaum, not Baxbaum - sorry.
Download 'orbits.mpg' (112 KB)
