POV-Ray : Newsgroups : povray.binaries.animations : Sierpinski Surprise (560 KB) Server Time
27 Nov 2026 14:32:09 EST (-0500)
  Sierpinski Surprise (560 KB) (Message 1 to 7 of 7)
Subject: Sierpinski Surprise (560 KB)
Date: 20 Feb 2004 16:55:20
Message: <40368248@news.povray.org>
Hi
This has probably been done at least 83 times before but I thought I'd share
anyway.
jim
p.s. blink and you'll miss it...
Download 'movie1000.mpg' (562 KB)
Subject: Re: Sierpinski Surprise (560 KB)
Date: 22 Feb 2004 06:09:04
Message: <40388dd0@news.povray.org>
> anyway.
Yeah, I did this too once - but not as good.
I really wanna try this with *lots* of different IFS's... I don't know
if you've seen it, but on my copy of RedHat there was an IFS
screensaver. Seems to be able to draw random IFS's in realtime => very
impressive! (That's gotta take some SERIOUS CPU time...)
Andrew @ home on Mozilla.
Date: 23 Feb 2004 11:49:27
Message: <403a2f17$1@news.povray.org>
Actually no. I'm sorry if I destroy an illusion, but apparently this
screensaver precalculates the IFS once, then draws it in various sizes
and rotations, and with varying angles for the branches. This can be
done very efficiently with matrices, and the drawing itself is just a a
matter of setting a few pixels to a color.
On the box where I'm sitting now (Fedora Core 1.0 on an Athlon 800) the
system load doesn't go up by more than perhaps 1% when this screensaver
is started.
(defun f(p x)(If(Eq x nil)nil(If(p(Car x))(Cons(Car x)(f p(Cdr x)))(f p
(Cdr x)))))(defun q(x)(Q nil x))(defun Q(a x)(If(Eq x nil)a(Q(Cons(Car
x)(Q a(f(Lt(Car x))(Cdr x))))(f(Gt(Car x))(Cdr x)))))
Date: 23 Feb 2004 19:09:06
Message: <403a9622$1@news.povray.org>
Hi. May I see the code for this effect? I suppose the process could be used
with a variety of "target shapes..."
Thanks much,
Dennis
"James Taylor" <jim### [at] blueyondercouk> wrote in message
news:40368248@news.povray.org...
> Hi
share
> anyway.
> jim
Date: 24 Feb 2004 13:03:56
Message: <403b920c$1@news.povray.org>
I just got myself the source of xscreensaver
(http://www.jwz.org/xscreensaver/) and looked into
xscreensaver-4.14/hacks/ifs.c. I don't claim I understand that code in
its entirety after the few minutes I spent reading it, but it appears to
me that this mess of a code does pretty much what I suspected:
precalculate once, then just repeatedly transform and draw. But I could
err, of course. Anyway, with this code being such a mess I doubt you
could easily adapt it to other shapes. IMHO it would be better to write
a new program from scratch...
Date: 24 Feb 2004 18:22:26
Message: <403bdcb2@news.povray.org>
"Dennis Miller" <dhm### [at] comcastnet> wrote in message
news:403a9622$1@news.povray.org...
used
Hi Dennis,
I've posted the scene files to p.b.scene-files for you to take a gander at
The way the code is setup should make it extremely easy to use other target
shapes. The target shape is simply held in the "seirp_array" array in the
code so just replace that part of the code which calculates the shape.
jim
Date: 25 Feb 2004 17:24:22
Message: <403d2096$1@news.povray.org>
Thanks much. Will take a look.
Best,
Dennis
news:403bdcb2@news.povray.org...
> used
> Hi Dennis,
target
> jim
