POV-Ray : Newsgroups : povray.binaries.animations : Alternate River Flow Server Time
6 Feb 2026 00:31:22 EST (-0500)
  Alternate River Flow (Message 1 to 6 of 6)
Subject: Alternate River Flow
Date: 9 Jun 2003 19:16:13
Message: <3ee5153d@news.povray.org>
Here's a different method of simulating fluid flow in rivers, inspired by
Tim Nikias' videos. The algorithm I'm using here is the one described in my
reply to his most recent post.
The algorithm is a simulation of fluid movements that go through the whole
depth of the fluid, as opposed to surface ripples. Perhaps for this reason,
the waves in this simulation are quite large, and my experiments with
putting ripples from rain here didn't work - the ripples didn't propagate
properly.
I suspect the best results may be achieved by combining the large-scale
waves around objects of this simulation with the results of another
simulation of small ripples, caused by rain/splashing etc. I haven't yet
tried this, and I'm not sure how well the two simulations could be layered:
ideally the ripples could be distorted by the velocity field of the
large-scale simulation, which should avoid the wave stacking problem that
Tim had.
As the large-scale flow quickly settles down into a fairly stable state, it
might be possible to render one large-scale height-field computation and
only animate the small scale details. Currently, the fluid dynamics is
implemented in C++: if only one of the complex fluid dynamics calculations
is needed for a whole animation, it may be possible to implement this in
Pov-Ray to calculate once before the start of the whole animation render and
save the height-field for use in every frame.
Please excuse the fact that the camera obviously rotates around the wrong
point (:  Also, for the eagle-eyed, there is a slight discontinuity at the
joins between the copies of the water height-field - I think this is a bug
in the boundary conditions of my simulation which should be quite easy to
fix.
Download 'water.avi.dat' (243 KB)
Subject: Re: Alternate River Flow
Date: 9 Jun 2003 19:43:44
Message: <3ee51ba8.143492371@news.povray.org>
Sorry to nit pick but I can't see anything due to the rotation of the camera.
Regards
Date: 10 Jun 2003 03:06:34
Message: <3ee5837a$1@news.povray.org>
Although one can observe a little bit of how
it looks, the rotation is far too much (and as you
noted about the wrong point), and perhaps even
the resolution of the image is a little too small.
Perhaps one or two larger still images in
binaries.images would be sufficient.
Another thing of interest is the resolution of the
water-mesh and the parsing time.
Aside of that, it does look promising, but you
could showcase it better.
As for saving the mesh to disk: I don't know
how you're saving the data, but you could easily
use my I/O Scripts to save an array to disk
and load it for every frame.
Additionally, if the nodes of mesh are structured
in a 2D-Array, you may even use my Mesh-Modifying-
Macros to save the mesh to disk and load that
for every frame...
Tim
Tim Nikias v2.0
Email: Tim### [at] gmxde
my
reason,
> properly.
layered:
> Tim had.
it
and
> fix.
Date: 10 Jun 2003 09:29:21
Message: <3ee5dd31@news.povray.org>
camera.
ditto
Date: 10 Jun 2003 16:21:26
Message: <3ee63dc6$1@news.povray.org>
Can't see anything due to spinning camera. In such studies, a spinning or a
rotating camera brings nothing to the visualization and in fact does nothing
more than distracting.
Date: 10 Jun 2003 19:48:22
Message: <3ee66e46$1@news.povray.org>
Heh... seems like moving cameras aren't a good idea then...
Though this animation gives the right idea, I'm not convinced with the
algorithm yet. Water doesn't seem to stack up in front of objects to the
extent that it should. I'll post some higher res pictures once I've got the
maths sorted.
