POV-Ray : Newsgroups : povray.binaries.animations : Particle problem solved (mpeg1 340k) Server Time
7 Mar 2026 00:27:04 EST (-0500)
  Particle problem solved (mpeg1 340k) (Message 1 to 6 of 6)
Subject: Particle problem solved (mpeg1 340k)
Date: 10 Sep 2002 04:29:31
Message: <3d7dad6b@news.povray.org>
For your weekly animation fix.
I tried to make it look real, although it's a strange thingy. The animation
is only 67 frames because there was a power failure here after 17 hours of
rendering. It seems Rune's particle system can't resume after a break; I
would have to start POV again from frame zero.. Anyway.. I solved the
problem with the bubbles, thanks to Rune.
There is a artifact on the torus in the middle, and radiosity causes those
"ants" under the yellow and red cords. Higher rad settings would solve that.
By the way, the slow rendering is not caused by the smoke, it's simply
because I wanted a fairly realistic rendering. The smoke is made of
transparant discs. I'll try to make a more realistic smoke later on.
Hugo
Download 'RustyMotor.mpg' (341 KB)
Subject: Re: Particle problem solved (mpeg1 340k)
Date: 10 Sep 2002 07:00:47
Message: <3d7dd0df@news.povray.org>
Nice modelling and texturing!!
Give the floor a more realistic texture, and it would be perfect!
cu!
Date: 10 Sep 2002 09:32:04
Message: <3d7df454@news.povray.org>
> a break; I would have to start POV again from
> frame zero..
It's supposed to work fine to start from any frame, using the +sf
command line setting. When you tried that, what happened?
By the way, are the smoke emitters "engines" that spew the smoke
backwards, or do they simply "smoke"? It's a bit difficult to tell from
the animation.
Very nice animation by the way. It looks very realistic! :)
Rune
rune|vision:  http://runevision.com (updated Sep 8)
POV-Ray Ring: http://webring.povray.co.uk
Date: 10 Sep 2002 09:51:51
Message: <3d7df8f7$1@news.povray.org>
> > frame zero..
> +sf command line setting. When you tried that, what happened?
Oops I used +kf  (Initial_Frame) and I should stop blaming your macros for
these mistakes!
> smoke backwards, or do they simply "smoke"?
They simply smoke. I was interested in how the rotation would affect the
particles. My original idea was to have balls that smash into walls, due to
high speed rotation.
Thanks.  :o)  The radiosity seems to be calculated with some randomness, so
reducing the artifacts will be expensive. It's good I can break and resume
animations, then!
Hugo
Date: 10 Sep 2002 09:55:50
Message: <3d7df9e6@news.povray.org>
Thank you!  I did use some time on both...
I could try. I suppose you refer to something more dirty.
Hugo
Date: 16 Sep 2002 09:17:03
Message: <3d85d9cf$1@news.povray.org>
Nice degree of realism.  I think the smoke particles disappear too quickly,
though.
