POV-Ray : Newsgroups : povray.binaries.animations : Particle System Explosion 4 (302kbu) Server Time
1 Aug 2025 00:17:56 EDT (-0400)
  Particle System Explosion 4 (302kbu) (Message 1 to 10 of 12)
Subject: Particle System Explosion 4 (302kbu)
Date: 19 May 2002 12:18:45
Message: <3ce7d065@news.povray.org>
It's a while ago I posted version 3 of this animation which I thought
would be the final one.
Version 3 of this animation was posted on February 15 this year:
http://news.povray.org/povray.binaries.animations/22273/
Now I've made a new one (it's attached here). It's changed very much. I
rewrote the textures
completely - the rest is the same. Please do compare this one with the
last to see the big difference. :)
What do you think? Better? Worse? What could be improved?
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated Apr 14)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Download 'newexplosion.mpg' (303 KB)
Subject: Re: Particle System Explosion 4 (302kbu)
Date: 19 May 2002 12:34:46
Message: <3ce7d426$1@news.povray.org>
Oh, the new one is much better! More particles? If not, you much be
introducing a new texture technique. The first second with yellow fire looks
a bit odd though, apart from that, it's great.. Also great, that I've got
your particle system. It's very well written, and I'll reply when I get to
make some tests on my own!
Hugo
Date: 19 May 2002 13:35:11
Message: <3ce7e24f$1@news.povray.org>
Can't think of any technical hints, but  "wow".
"Hugo" <hua### [at] post3teledk> wrote in message
news:3ce7d426$1@news.povray.org...
looks
> Regards,
> Hugo
Date: 19 May 2002 15:06:12
Message: <3ce7f7a4@news.povray.org>
Great work, but is the spinning necessary? I know it helps show that the
effect can be seen from any angle, but it's a bit dizzying.
Date: 19 May 2002 17:41:31
Message: <3ce81c0b@news.povray.org>
Thanks! I think so too. :)
Not any more particles than before, just a different texture. The
texture is actually a simple cylindrical pattern aligned so it faces the
camera. Just as it was before. The trick lies in the fine tuned
turbulence and color_map, and that was I have improved in this
animation.
> a bit odd though
Ok. In what way?
> that I've got your particle system. It's
> get to make some tests on my own!
Well written? I think it's rather messy. I can't even understand the
code myself! Every time I have to make some changes I first need to take
a few minutes to figure out what I was thinking when I originally wrote
the code...
Anyway, I'm really looking forward to seeing what things you and the
other beta testers can come up with. :)
Rune
Date: 19 May 2002 17:41:32
Message: <3ce81c0c$1@news.povray.org>
Hehe, thanks! :)
Rune
Date: 19 May 2002 17:41:34
Message: <3ce81c0e@news.povray.org>
> I know it helps show that the effect can be
Ok, I'll tone down the spinning then. :)
I'm also updating the blow-up animation. The one that use a picture of a
real building and - no spinning. :)
Rune
Date: 19 May 2002 18:17:10
Message: <3ce82466@news.povray.org>
Really good, but the fact that the dust doesn't settle, but just disapears
spoiled this one for me.
Date: 20 May 2002 05:15:25
Message: <3CE8BE90.3276922@gmx.de>
Hm. The texture doesn't fit into the spheres correctly,
I can clearly see some "edges" there...
But the colors and turbulences look way better now!
> Rune
> 3D images and anims, include files, tutorials and more:
>    newexplosion.mpg    Type: WMPLAYER Datei (video/mpg)
>                    Encoding: x-uuencode
Tim Nikias
Email: Tim### [at] gmxde
Date: 20 May 2002 09:13:49
Message: <3ce8f68d@news.povray.org>
> correctly, I can clearly see some "edges" there...
You're right, but it's barely noticeable IMO. The question is if the fix
is worth the extra render time.
Thanks! :)
Rune
