Blocks of the surface are shifting along the space-filling curve on a
height_field.
What do you think about the effect?
atb,
gleb
Download 'pa03.m1v.mpg' (339 KB)
Hi Gleb,
i liked the pic with the peano-curve in p.b.i
but in this animation one can't really see
anything at all. The Animation is way too fast.
Try decreasing the timesteps between the frames.
The second thing is that the resolution is too
low to recognize anything. I can imagine that
the rendertime for the frames is probably quite
high but that would be worth it, i think.
Last thing is, the compression is too strong,
at least at this resolution.
Or in short words:
I would like to see your animation in highquality :)
Thies
Subject: Re: Boiling height_field (mpg1 ~340Kb)
Date: 23 Jan 2002 09:50:07
Message: <3c4ecd9f@news.povray.org>
> height_field.
its to fast and to badly compressed to make out
PGP Public Key
Date: 23 Jan 2002 10:33:34
Message: <3c4ed7ce@news.povray.org>
I liked very much your still image, but this animation is too small, too
fast and too compressed to be able to see something.
Anyway, as it is, it does give the impression of boiling water.
Good work,
Fernando.
"Gleb" <gk1### [at] sotonacuk> wrote in message news:3c4eb1f7@news.povray.org...
> height_field.
> atb,
> gleb
Thank you. I know, the quality is bad, but I tried to reduce the size.
I think it will be possible to use this kind of simple movements
to simulate the effect of something boiling. Usually people don't look
carefully
on the details of this kind of process, just a quick look at a surface with
this stuff
should left a feeling of that.
Gleb
"Thies Heidecke" <h3i### [at] gmxnet> wrote in message
news:3c4ecc94$1@news.povray.org...
> Thies
Thank you. The original file has too many details and was too big to post.
I think it will be better to change the base objects to something simple.
Gleb
news:3c4ed7ce@news.povray.org...
> Good work,
> Fernando.
