I've improved the algorithm in my walking system a lot and have made a new
version of the animation that I think is much better than the previous.
I have also rendered it in 320x240 with AA, and the camera angle is a bit
more interesting.
It's up on my website:
http://rsj.mobilixnet.dk/3d/anims/anims.html
Hope you like it. :)
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Nov 5)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
> more interesting.
Where exactly?
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov
Ok I found it, but you forgot the link ;)
Lovely! And impressive.
"JRG" wrote:
> Where exactly?
Strange - I'm sure I uploaded the updated page...
Anyway, it's there now.
Rune
Thanks! :)
Rune
Amazing, Rune! The animation looks very realistic, and the attention to
detail is very impressive. The way the eyes and head rotate before Al turns
is great. Now, can Al walk and talk at the same time? How about chew gum?
-David
Amazing. The start after the stop was a bit jerky, though. I suspect because
you placed the next footstep so close. Still, this is much better than
anything I could ever do. Great job.
"Tony[B]" wrote:
> Amazing.
Thanks!
It's not because I don't want criticism, but I truly can't see this. It
looks pretty smooth to me. Could you explain more detailed what you're
referring to?
Rune
> and the attention to detail is very impressive.
Thank you! :)
> The way the eyes and head rotate before Al turns is
> How about chew gum?
That should not be too difficult.
But some other things like waving the arm are more difficult as it would
require some way to interpolate between the automatic arm movement and
custom arm movement, which is something I have yet not figured out how to
do.
Rune
