POV-Ray : Newsgroups : povray.binaries.animations : Kochcurve3D(?) Server Time
26 Feb 2025 15:55:36 EST (-0500)
  Kochcurve3D(?) (Message 1 to 8 of 8)
Subject: Kochcurve3D(?)
Date: 2 Dec 2001 10:15:23
Message: <3c0a458b@news.povray.org>
Anders Haglund did some days ago something with a regular kochcurve in POV,
and as he said, he wanted to do it in 3d, but didn't know how ...
I got the idea, to apply the algorithm to a regular triangle, dividing it
into 6 triangles, greating one peak ...
it looked nice, so I did it with a tetraedron ...
the shape is no longer something lige a snowflake, but it converges against
the shape of a cube ...
it's a pity, that my simplest math left me, when I tried, to make the sides
of the trianles equal ...
Thats the reason(I think), why it looks like a distorted cube, and why it
doesn't loop correctly...
somewhere there must be some mistake...
Can anyone spot, where I got wrong ?
1)
the points of a regular tetraedron can have the following coordinates
#declare h=sqrt(3/4);
#declare p1=<   0,-1/3*h, 2/3>;
#declare p2=< 1/2,-1/3*h,-1/3>;
#declare p3=<-1/2,-1/3*h,-1/3>;
#declare p4=<   0, 2/3*h,   0>;
2)
to calculate the top of the new pyramid that I create on a triangle,
I use the following:
(I assume, if I'd use a "real" regular triangle, it could be simplified)
p1,p2,p3 are now the points of the triangle, to be subdivided...
p4 is the new point at the top of the pyramid..
#local a=vlength(p2-p1);
#local b=vlength(p3-p2);
#local c=vlength(p1-p3);
#local n=vnormalize(vcross(p2-p1,p3-p1))*sqrt(a^2-(sqrt(b^2-(c/2)^2)/3)^2);
#local p4=(p1+p2+p3)/3+n/3;
3)
if I rotate a regular tetraedron, resting on the floor, by
rotate <0,120*clock,360*clock>
Shouldn't it perfectly loop ?
Can anyone spot the mistakes I did ? ...
Any other comments ?
Jan Walzer <jan### [at] lzernet>
Download 'koch3.avi.dat' (495 KB)
Subject: Re: Kochcurve3D(?)
Date: 2 Dec 2001 10:40:50
Message: <3c0a4b82$1@news.povray.org>
YHYHBRTL if you type G instead of C ....
Date: 2 Dec 2001 11:09:31
Message: <021220011005457300%reu1000@chorus.net>
In article <3c0a4b82$1@news.povray.org>, Jan Walzer <jan### [at] lzernet>
Or if you type an H instead of a K.
 - Rico
Date: 2 Dec 2001 13:59:57
Message: <3c0a7a2d@news.povray.org>
but ... but... ehhmm ... but ... they look soooo similar ....
Date: 2 Dec 2001 17:01:59
Message: <3c0aa4d7$1@news.povray.org>
Jan Walzer wrote:
> 1)
p1, p2 and p3 are not the vertixes of an equilateral triangle. They are the
vertixes of an isosceles triangle with base = 1 and height =1.
Jonathan.
Date: 2 Dec 2001 17:38:08
Message: <3c0aad50@news.povray.org>
POV,
against
sides
> 1)
Your geometry is close, but not quite.  Try this:
#declare h1 = sqrt(1/2);
#declare h2 = sqrt(3/4);
#declare p1=<   0,-1/3*h1, 2/3*h2>;
#declare p2=< 1/2,-1/3*h1,-1/3*h2>;
#declare p3=<-1/2,-1/3*h1,-1/3*h2>;
#declare p4=<   0, 2/3*h1,   0>;
or, even simpler (although in a different orientation):
#declare p1=< 1, 1, 1>;
#declare p2=< 1,-1,-1>;
#declare p3=<-1, 1,-1>;
#declare p4=<-1,-1, 1>;
> 2)
> #local
Assuming that, now, you have a truly regular tetrahedron, then a=b=c.
But, in case we're off a bit, we could average them.
so,
#local h=(a+b+c)/3 * sqrt(1/2);
#local n=vnormalize(vcross(p2-p1,p3-p1));
#local p4=(p1+p2+p3)/3 + n*h;
> 3)
It should.  Try it again with the new geometry.
Tom Bates.
Date: 3 Dec 2001 00:55:59
Message: <3c0b13ef@news.povray.org>
"JRG" <jrg### [at] hotmailcom> schrieb im Newsbeitrag
news:3c0aa4d7$1@news.povray.org...
> Jan Walzer wrote:
> > 1)
damn ... you hit me ... Thanx ...
I'll post again later...
Date: 3 Dec 2001 00:59:37
Message: <3c0b14c9$1@news.povray.org>
"Tom Bates" <tho### [at] shawca> wrote:
> Jan Walzer wrote:
> > 1)
I believe not close enough ;) ....
> Try this:
In fact ... You're right ...
I think in THIS orientation, it can't be looped any longer with rotate y*120
> > 2)
> > #local
> so,
> > 3)
OK ... than this is a fault of the geometry ...
Thanx .. I'll try again later ... (have to leave now)
