POV-Ray : Newsgroups : povray.binaries.animations : Re: New flood of paint (divx 870 kb) Server Time
17 Oct 2025 14:03:05 EDT (-0400)
  Re: New flood of paint (divx 870 kb) (Message 1 to 10 of 15)
Subject: Re: New flood of paint (divx 870 kb)
Date: 27 Oct 2001 18:07:43
Message: <3bdb302f@news.povray.org>
Hmm ... looks better every time ...
I'm wondering if there is a way to bring these small particles, that escaped
back to the mainstream ...
I think small groups of particles are OK but if these groups get to small
(maybe n<5) then they should tend to go back to the mainstream,
!OR maybe should create some new particles in THIS group with the current
speed of THIS group (+ a small amount of jittering)
dunno, if this can be implemented ... maybe its a bad idea at all, but that's
what I consider the most unrealistic
but a good work so far .... looking forward ..
Jan Walzer <jan### [at] lzernet>
Date: 27 Oct 2001 18:52:55
Message: <3bdb3ac7$1@news.povray.org>
here's a possible fix. How about this: when you're figuring out where a
particle should go, and you realize that it's about to hit the floor, and
its Y velocity is less than a certain threshold value, then you set its Y
velocity to zero. Then, whenever you find a particle that is both resting on
the floor and has a Y velocity of zero, you multiply its X and Z velocities
by some constant less than 1. That will simulate friction, and may prevent
droplets from rolling away really quickly.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
"Jan Walzer" <jan### [at] lzernet> wrote in message
news:3bdb302f@news.povray.org...
escaped
that's
Date: 27 Oct 2001 19:03:55
Message: <3bdb3d5b@news.povray.org>
Well, I'm already using a friction parameter, even if it's quite low. I made
experiments with bigger values and in fact it looked more viscous.
Jonathan.
"Slime" <noo### [at] hotmailcom> ha scritto nel messaggio
news:3bdb3ac7$1@news.povray.org...
on
velocities
> - Slime
> escaped
small
current
> that's
Date: 27 Oct 2001 22:13:30
Message: <3bdb69ca@news.povray.org>
> Now the flood's velocity is variable and the rounded box slowly rotates.
yuk!!
PGP Public Key
Date: 28 Oct 2001 00:32:06
Message: <3bdb8a46@news.povray.org>
Impressive! But feels kinda slow.
Date: 28 Oct 2001 05:56:11
Message: <3bdbe44b$1@news.povray.org>
rotates.
> Jonathan.
Very impressive! I watched it at least 30 times, than I had to force
me to quit - else I would still be watching.
Very cool!
cukk
Date: 28 Oct 2001 21:29:10
Message: <3bdcbef6$1@news.povray.org>
I couldn't see it.
> Jonathan.
>    green.avi    Type: Video for Windows (video/msvideo)
>             Encoding: x-uuencode
Date: 29 Oct 2001 12:25:19
Message: <3bdd90ff@news.povray.org>
> box slowly rotates.
This is impressive!
However, am I correct in the assumption that if the box rotates fast, then
some particles (possible many) will fall through the surface of the box?
(Though this effect can be decreased by using more calculation steps per
time unit.)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Date: 29 Oct 2001 14:46:21
Message: <3bddb20d$1@news.povray.org>
Holy divx...
I have the mpeg version, which also looks better, but it's 1.5 MB :-(. So
it's not likely to be posted here...
Jonathan.
"Greg M. Johnson" <"gregj;-)56590\""@aol.c;-)om> ha scritto nel messaggio
news:3bdcbef6$1@news.povray.org...
> I couldn't see it.
> > Jonathan.
Date: 29 Oct 2001 14:50:20
Message: <3bddb2fc@news.povray.org>
"Rune" <run### [at] mobilixnetdk> ha scritto nel messaggio
news:3bdd90ff@news.povray.org...
> > box slowly rotates.
> This is impressive!
> time unit.)
Not only, the effect will look unrealistic unless you take into account the
extra mechanical energy given by the rotating box (which now is irrelevant).
Jonathan.
