Ooo. Cool- are you still sticking with red paint instead of blood?
Considering that Halloween's coming up, blood might not be a bad idea :-)
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3bcc6b2a@news.povray.org...
> See same thread in p.b-i.
> I know I can get better compression with divx, but the quality was
*really*
> poor. Is there anyone who can drive me through all those encoding options?
> TIA.
> Jonathan.
After staring at this animation for literally seconds, I finally realized
what was missing: surface tension. there must be some way for a partile to
know if it is connected to another one and if so, is attracted to it. This
would prevent the tiny droplets from escaping like they do now.
*really*
> TIA.
> Jonathan.
Do you know a *fast* way to do that in POV SDL? As I said elsewhere, it
would be really a simple implementation, but it would be *extremely* slow to
compute with so many particles. I could consider to implement non persistent
(sp?) particles to reduce the number of particles per frame though... any
help?
Jonathan.
"Chris Jeppesen" <chr### [at] digiquillcom> ha scritto nel messaggio
news:3bcdb821$1@news.povray.org...
> *really*
options?
> > TIA.
> > Jonathan.
If you look carefully at the few droplets that flow towards the camera,
you'll see that a few droplets actually divides in two.
Once they blob together, you should try to get them to stay together. Well,
except if they are falling off of something.
Otherwise, looks cool. :)
Hmm, I'm not familiar with Halloween.
And yes, this is still paint. (the title is just meant to be an interesting
one ;)
Jonathan.
"Mahalis" <don### [at] fakeycom> ha scritto nel messaggio
news:3bccbbe9$1@news.povray.org...
> //Mahalis
> *really*
options?
> > TIA.
> > Jonathan.
Well, the basic alogrithm is to find the closest neighboring particle, and
if it is within a certain distance, generate a force towards this nearest
neighbor. The slow O(N^2) part is finding the nearest particle.
What if you chopped up the space into cubes, and only looked for a nearest
neighbor in the same cube? I assume that somewhere deep down in your
simulation is a 1-dimensional array representing the particles.
Suppose you divided the space into 10x10x10 cubes, and had a 4-dimensional
array Neighbors[10][10][10][N_PARTICLES]. When the physics loop starts, the
array is cleared. When each particle position is updated, calculate which
cube it belongs in, say <4,5,6> and write that into Neighbors[4][5][6]. Now
when it comes time to calculate, for each particle only check for its
nearest neighbor in the same neighbor cube. This could reduce time to
O(1000*(N/1000)^2).
news:3bcdbc8c@news.povray.org...
to
persistent
> help?
> Jonathan.
realized
to
This
> > *really*
> options?
> > > TIA.
> > > Jonathan.
Hmmm, it sounds clever. This algorithm might be use for reciprocal repulsion
as well.
I'll give it a try and post the results.
Thank you,
Jonathan.
news:3bcdc15c$1@news.povray.org...
the
Now
> O(1000*(N/1000)^2).
slow
> to
> persistent
any
> > help?
> > Jonathan.
> realized
partile
> to
> This
> > > *really*
> > options?
> > > > TIA.
> > > > Jonathan.
Actually you should check the 26 cubes immediately surrounding the cube in
question as well, otherwise particles at the very edge of one cube wouldn't
be influenced by particles at the very edge of the next cube
-tgq
"Chris Jeppesen" <chr### [at] digiquillcom> wrote in message
the
Now
> O(1000*(N/1000)^2).
26?
Jonathan.
"Trevor Quayle" <Tin### [at] hotmailcom> ha scritto nel messaggio
news:3bcdc957$1@news.povray.org...
wouldn't
> -tgq
and
nearest
nearest
4-dimensional
> the
which
> Now
> > O(1000*(N/1000)^2).
3^3 -1 (cubes that share faces, edges and corners)
-tgq
news:3bcdcbde@news.povray.org...
> 26?
> Jonathan.
in
> wouldn't
> > -tgq
> and
> nearest
> nearest
> 4-dimensional
starts,
> > the
> which
Neighbors[4][5][6].
> > Now
> > > O(1000*(N/1000)^2).
