With sound :)
But not finished at all, of course :)
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x) // ZK http://www.povplace.be.tf
Download 'minigun.avi.dat' (224 KB)
In article <3b5c7cc7@news.povray.org>, Zeger Knaepen says...
> With sound :)
> cu!
No sound here :(( Nice gun, btw :)
Regards, Sander
Wow amazing how much some simple sound effects can bring life to something
like this. One thing I noticed, the glows, that is what you are using right,
are not synchronized with the barrels of the gun. That is, the flash happens
between two barrels and not at the tip of one as you would expect, pause the
play at the exact moment of one of the flashes and you will see what I mean.
"Zeger Knaepen" <zeg### [at] student kuleuven ac be> wrote in message
news:3b5c7cc7@news.povray.org...
> With sound :)
> cu!
> camera{location-z*3}#macro G(b,e)b+(e-b)*(C/50)#end#macro L(b,e,k,l)#local
C=0
> ;#while(C<50)sphere{G(b,e),.1pigment{rgb G(k,l)}finish{ambient 1}}#local
C=C+1
> ;#end#end
L(y-x,y,x,x+y)L(y,-x-y,x+y,y)L(-x-y,-y,y,y+z)L(-y,y,y+z,x+y)L(0,x+y,
Actually they are, but they fade out, so they're only aligned with the barrels
for a very short moment. Should they follow the barrels while fading out?
cu!
Good question. I think I could go either way. Without actually seeing
one in action, I wouldn't be sure. The explosion should stay in it's planes
but some of the burning gases should still be being expelled as the barrel
turns.
> turns.
Hmm, actually I should add a smoke-system too then...
Anyway, first I should finish the model.
cu!
After examining the ultimate authority on this subject (Terminator 2 -
Judgement Day) it appears that there is no indication of it following the
rotation of the barrel.
One thing that was visibly different was that the flame appears to begin
approximately a foot beyond the end of the barrel.
news:3b5cbacd@news.povray.org...
seeing
planes
barrel
> > turns.
> cu!
C=0
C=C+1
> ;#end#end
In article <MPG### [at] NEWS POVRAY ORG>, Sander says...
> > With sound :)
> > cu!
Today I *do* have sound: impressive, though short :)
Regards, Sander
Zeger Knaepen wrote:
> With sound :)
I didn not read the text before playing it and had the volume turned quite
high... ;-)
How about some smoke staying there after the single shots?
Christoph Hormann <chr### [at] gmx de>
> > With sound :)
> high... ;-)
uhm :)
How about giving me some time to finish the model? :)
But you're right actually... The glows were only temporary.
cu!
