![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ok, got a few questions folks here can likely help me with. First, I want
to post an animation, but I think it's too big. It's 846 K, for only 90
frames as a mpg. I know there are limits, and I'm getting an error message,
so I'm assuming that's what's up. It seems like a lot of memory for such a
short anim, though, so I'm wondering if anyone knows how to make it smaller,
and/or what to do.
Second, I want to have camera angles change, but there are a lot of
parameters. Anyone know of a good set of macros for keyframing the camera,
maybe spline based, or whatever? I can work something up on my own, if I
have to.
Geoff
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 9 Feb 2001 13:31:22 -0500, Geoff Wedig wrote...
> and/or what to do.
The file size limit for this NG after encoding is 1Mb, which in practice
means about 700k before encoding IIRC.
As far as size of file is concerned, what format and what codec are you
using? You could also try encoding at a lower quality setting, or doing
what other people here tend to do when they end up with an oversized
animation, and put it on a webpage somewhere and post a link.
Bye for now,
Jamie.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> have to.
Check out Chris Colefax's Clockmod.inc file. I am not sure it handles
keyframing directly but it has a nice set of options worth exploring
none the less.
http://www.geocities.com/SiliconValley/Lakes/1434/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> none the less.
The original Clock Modifier include file (created for and still compatible
with POV-Ray 3.0) doesn't handle keyframing directly. The Automatic Clock
Modifier macro (that comes with the packages) does, letting you adjust the
camera like this:
angle From (0, 60) To (0.3, 20) To (1, 50) // Zoom in, then out
At my page above you'll also find the Spline Macro File, which lets you
perform automatic animation of the camera (and other objects) along spline
paths.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > none the less.
> camera like this:
> camera {
> paths.
Can you send the Spline Macro File to the newsgroup? I can't download it from
your page, it says some error code I don't remember now.
thanx
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
