![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks. I re-rendering to remove the laser shadow. The laser is also stronger and
the resolution slightly higher (still mpg though). I'll post when finished.
Hugo wrote:
> That's pretty original, nice! Well, I had to view it several times to really
> catch the laser.. I'd like to see this animation on a darker background (the
> plane) and a stronger laser - that actually looks like 'light'.. And a bit
> bigger resolution.. But then I'll probably save the anim to my personal
> "hall of fame" ! ;o)
> Regards,
> Hugo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Peter Hertel wrote:
>>Enjoy.
> I sure did :) That was fun!
Glad you liked it!
MJL
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Rick [Kitty5] wrote:
> very nice, quite captivating :)
Cheers!
MJL
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sweet deal! How about with radiosity and a high ambient on those cylinders?
A setup like this with a story/concept behind it would have made a great
entry in the overly complicated machines IRTC round. Looking forward to the
updated version.
Skip
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks!
MJL
> updated version.
> Skip
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
POV-Physics 6.5.9.6 - Fake laser beams will cast shadows unless created with
no_shadow sources... doh. Thanks to everyone who pointed that out.
Here is an update, no shadows, slightly higher resolution.
MJL
Download 'laser3.mpg' (279 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I saved it. :o) It's better, but still doesn't really look like 'light'..
But how did you calculate the position of the mirrors?
Hugo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No. Light will not block the passage of light.
Cheers!
Chip Shults
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Neat animation. Did you use two trace statements to get the beam to
bounce off the mirrors and stop at the more diffuse objects?
I've got a couple suggestions, since the beam is a little hard to see:
-dim the lights in the room
-give the cylinders an emitting media with a cylindrical density. The
density pattern can be rotated using the Reorient_Trans macro, I think.
Now if you're a real glutton for punishment, you can introduce convex
mirrors and substitute some of the cylinders for cones :)
> with no_shadow sources... doh. Thanks to everyone who pointed that out.
> MJL
Samuel Benge
sbe### [at] caltel com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I know :-( This was meant to be a quick experiment, but maybe I'll try to improve
the laser beam.
Most were easy (90 degree deflections). The others used simple trig.
MJL
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
