Once again, I've used my Physics-Room as
background for the example.
Excuse the grainy-look on the medias, but
the Betas traced severe bugs (yup, posted
already), so I've switched to 3.1 for this
animation.
Comments, suggestions, all as usual... ;-)
Tim Nikias
Download 'inertia3.mpg' (321 KB)
Very nice demonstration!
I'll have to do something similar... :)
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Feb 16)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring: http://webring.povray.co.uk
Thanks!
Hey, that's my room! ;-)
Tim Nikias
Nice! A good demonstration of the effect, even without the camera following behind
that
glow :-)
MJL
prism{0,.1,30#local I=1;#while(I<30)#local B=asc(substr(// Mark James Lewin
"#K?U_u`V[RG>3<9DGPL.0EObkcPF'",I,1))-33;<div(B,10)-4mod(B,10)+5*div(I,21)-
6>#local I=I+1;#end,-4pigment{rgb 9}rotate-x*90translate 15*z}//POV-Ray 3.5
I see a welding animation WIP.
Looks really good!
-Law
> animation.
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
> inertia3.mpg Type: Wmplayer File (video/x-mpeg)
> Encoding: base64
"> Comments, suggestions, all as usual... ;-)
Watched it lots of times... it is mesmerising. Then got frustrated at my
inability to do similar :-(
I would be extremely grateful for a look at your code, as I need all the
help I can get.
All the best,
Andy Cocker
What does "welding animation" imply? What's
"welding" anyway?
And the particle system is definetely a WIP,
but I hope not much longer than it already
took.
Nontheless, thanks!
> Looks really good!
> -Law
Tim Nikias
You can adapt to frustration by trial and error,
thinking thoughts and asking. It took me over
a year to get the system to the point where
it is now (though I'm not constantly working
at it, ideas are still a must for programming).
You'll be able to have a look at my code
when it's finished, because its undergoing
major changes from this day to the next,
and you'd get more confused with it at
this moment, than acquire any knowledge.
But I am thinking on doing a little section
on my homepage to describe the algorithms,
sort of a "Behind the scenes" look. Though this
may take still a while, if you've got questions,
you can also email me if you'd want to.
> help I can get.
> All the best,
> Andy Cocker
Tim Nikias
On Tue, 19 Mar 2002 17:19:32 +0100, Tim Nikias wrote...
> "welding" anyway?
<relatively crappy explanation follows>
The process of joining two metal plates by melting and fusing the edges
to be joined and filling the gap with metal i.e. Arc welding, MIG
welding, Oxy-acetylene welding etc. etc.
Bye for now,
Jamie.
Thanks for the insight.
Now back to Lawrence:
What do you actually mean now? I don't get it.
(Probably I'm too stupid and straightforward thinking,
should implement Runge-Kutta or such)
Jamie Davison explained:
Tim Nikias
