![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Great! Looks like just the thing I need... :)
Mark Hanford
http://www.mrhanford.com/povray
"Mark James Lewin" <m_j### [at] yahoo com au> wrote in message
news:3C6C26C7.7037F66C@yahoo.com.au...
> I have rehashed an old string system I had written ages ago, and here is a
render
> of stiff wire. I think I made the wire too stiff, but see what you think.
Anim
> inspired by Mark Hanford's robot hand (see p.b.i )
> MJL
> light_source{9*(y#macro A(H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local
I=1;#while(I<H)
> #local V=asc(substr(B,I,1))-33;<div(V,10)mod(V,10)>#local I=I+1;#end
pigment{rgb
> y}rotate-<90,R>translate-T}#end-z)rgb
9}A(14",6;MWmhryXN3,"60<15,0,8>)box{-99(x+
> z)*99pigment{rgb 1}}fog{distance 11}camera{location(y-z)*25look_at
0}A(8"6hiAG=6
> "-60x*-10)A(16"/.@VZno=<PLA89/"0x*5) // MJL
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, you've used spheres and mapped the textures on them, right?
It does look better, but if you look closely at the shadows,
you'll notice that there are "jumps": suddenly a spherical
shadow disappears as the object (already totally
transparent at the time) is taken out of the scene.
I know this kind of problem, I had it too sometimes.
Perhaps your spheres don't end up 100% transparent,
due to the image-map (as I think it is) you're using?
As suggested on the first animation, I think adding some
twisting and swirling would look a lot better, but as
also mentioned, using image-maps and not real 3D clouds
makes that impossible...
Tim Nikias
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Damn! Somehow... This Post belonged to Explode2 from Rune, not here...
Tim Nikias
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
it looks to stiff in some parts, and to quick to bend in others
otherwise great :)
PGP Public Key
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
When I fix some problems with the system (which could be some time), I'll post
the source.
MJL
text{ttf"timrom.ttf"concat(#local O=1;#while(O<7)chr(val(substr(concat(#local Q=
1;#while(Q<7)str(asc(substr("???<?>",Q,1))-56,0,0),#local Q=Q+1;#end""),O,2))),#
local O=O+2;#end"").1,0pigment{rgb 9}translate-<1,.3,-2>} // MJL
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
are you referring to the speed at which the loop forms? I think I made the spring
constants too large, and this quick loop formation was a result of relief of
quite a bit of strain.
> otherwise great :)
Thanks!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> otherwise great :)
My exact same thoughts. :)
Not just the forming of the loop, but all four motions: looping, bending
down, unlooping, bending up. It's like almost nothing happens between these
things, and then suddenly all the stress is relieved at once instead of
smoothly and gradually. But nice nonetheless!
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Jan 20)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you. For a prelimimary, I was satisfied. Now it's time for those long hours
tweaking one or two numbers to get the "perfect" result...
MJL
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
post
> the source.
Yes do post the source! Please. :o)) I don't have any critisism, it's
just great and useful.
Hugo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you, but sorry to say that until I get some bugs worked out, the source
will not be posted. I hope it will be released sometime in the first half of this
year though.
MJL
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
