No, the direction has to be the same. Think of your particle as a
sphere_sweep: you simply have to trace() from the centre and from some
points of the diameter normal to the velocity direction.
Jonathan.
"Tim Nikias" <Tim### [at] gmxde> ha scritto nel messaggio
news:3C129615.8BAE3640@gmx.de...
> > My particle system does indeed only do collision detection using the
center
> > point of the particle as reference. I don't think there's much I can do
> > about that unfortunately...
> Just a simple idea I had:
> If you have the direction the particle is heading, why don't you do a
> "axis-check"?
> Example:
> Particle flies in x-Direction.
> You also check some angles which differ from original angle up to
> 90 degrees or so.
> It's like creating a field-of-vision for the particles direction and
looking
> for intersections there.
> On the other hand, that might become pretty parsing-intensive...
> Perhaps the simple solution will work until someone has found some
ingenious
> way...
> By the way: I've just downloaded the POV-Ray3.5 Beta 8 and am making
> myself comfortable with it. Perhaps we'd see some "neat
awesome-action-packed-
> particle-animation" of *my taste* soon...
> No offense, just kidding.
> Tim
Rune wrote:
> "Tim Nikias" wrote:
> > If you shoot a particle in an angle, and the position
> > calculated for the particle does just not touch the
> > ceiling, but the radius of the particle does, how do
> > you do that?
> My particle system does indeed only do collision detection using the center
In ElastoLab, I actually test to see if the center of the particle comes within
the radius distance of any barrier. If anyone is interested in the math, I put
the following comment into the code:
// Derivation:
// We want to find time t where:
// (locationOfParticle(t) - barrierPoint) . n = r
// (lastLocation + (location - lastLocation) t - barrierPoint) . n = r
// (lastLocation - barrierPoint) . n + (location - lastLocation) t .n = r
// t = (r - (lastLocation - barrierPoint) . n) / ((location - lastLocation)
. n)
// t = (r - (lastLocation . n) + (barrierPoint . n)) / ((location -
lastLocation) . n)
// If
// barrierOffset = -(barrierPoint . n)
// Then we can write:
// t = (r - (lastLocation . n) - barrierOffset) / ((location - lastLocation)
. n)
// If dot1 = (location - lastLocation) . n,
// t = r/dot1 - ((lastLocation . n) + barrierOffset)/dot1
Another interesting case is when a particle hits a corner. The normal for the
"reflection" of the particle depends on the exact point of the particle that
hit the corner.
Yet another interesting case is when you have two barriers that form an X shape
and you drop the particle into the top of the X. It should come to rest just
above the center of the X. It's very hard to prevent the particle from falling
through.
(If anyone has a good solution for that, I'd love to see it. The only good
solution I've seen involves solving sets of linear equations inside a triple
nested loop).
David Buck
Simberon Inc.
dav### [at] simberoncom
"David Buck" <dav### [at] simberoncom> wrote in message
news:3C12D101.861968FA@simberon.com...
> > > you do that?
center
within
I put
> // Derivation:
r
lastLocation)
> . n)
> lastLocation) . n)
> // If
lastLocation)
> . n)
the
that
> hit the corner.
shape
just
falling
> through.
good
triple
> nested loop).
> David Buck
> Simberon Inc.
I have been working on a simple particle (ball actually) simulator that
simulates balls bouncing, colliding, whatever within an area. I did have
problems with balls 'sinking' through floors and solid objects because of
gravity influence, but what I did to overcome that was add an extra property
(3 actually, x,y,z) to each ball that indicated a dead ball in each axis
direction. When a ball collides with a solid object, if it gains no
momentum in one given axis, this flag is set to true (deadball) and
gravitational acelleration has no influence on it in that direction (if
another ball hits it, though, it gains the momentum back and the flag is
reset). The problem I have is with balls themselves. When they start to
settle and are sitting three or four deep, they start sinking into each
other. I don't have any solution for this yet that (that doesn't compromise
the effieciency of the program). The only way I can think of is, as you
suggested, several nested loops but this adds considerably to the
calculation times. I also increase the number of iterations between drawing
cycles because (with VB anyways) the program calculates a lot faster than it
draws, so I will do perhaps five calculation cycles per drawing cycle.
-tgq
> shape
> just
> falling
> > through.
> good
> triple
> > nested loop).
> > David Buck
> > Simberon Inc.
> reset).
Won't this work only if your walls and floors are parallel to the X, Y,
or Z axes?
David Buck
Simberon Inc.
www.simberon.com
> the particle comes within the radius distance of any
In my particle system barriers can only be sensed using the trace function
in POV-Ray 3.5. Thus I have no way of knowing the distance from a particle
to a barrier.
> barriers that form an X shape and you drop the
> rest just above the center of the X. It's very
> hard to prevent the particle from falling through.
> to see it.
Though I'm not 100% sure, I think my system can handle that, but again, I
think it works fundamentally different than yours.
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Nov 5)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
center
Couldn't you add the radius value in all directions (or at least some of
them) and see if any radii touch the obstacle?
> (or at least some of them) and see if any radii touch
> the obstacle?
If you're referring to the method JRG describes, then yes, I could do that,
but it would make the calculations at least 5 times slower and still not
produce very accurate results.
Rune
Rune wrote:
> > why don't you do a "axis-check"?
> Yes, and even so, it's not very precise. That's why I don't like it.
> And in most of the simulations I do, it won't make a difference anyway.
> Remember that solid objects is just one out of many uses. For liquids, fire,
> smoke, sparks etc. it doesn't matter at all.
Sigh. I bit the bullet too, and decided that precise testing involved too much
trace testing, and was probably not worth the effort. The centre is all that
matters in my system :-(
MJL
light_source{12*(y-z)rgb 2fade_distance 9fade_power 2area_light x,z,5,5}#macro A
(H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local I=1;#while(I<H)#local V=asc(substr(B,I,1
))-33;<div(V,10)mod(V,10)>#local I=I+1;#end pigment{red 1}rotate-<90,R>translate
-T}#end A(16"/.@VZno=<PLA89/"0,5*x)A(14",6;MWmhryXN3,"60<15,0,8>)camera{location
25*(y-z)look_at 0}A(8"6hiAG=6"-60,-10*x)box{-99(x+z)*99 pigment{rgb 1}} // MJL
> through.
> nested loop).
Yep, ran into that problem myself. My solution was to avoid it completely. Maybe
everyone trying to get a particle system running should post examples like this,
that is, difficult situations, so that we can work together on solutions.
MJL
Perhaps it would be a good idea to send at least one extra trace() which
is just slightly off the original direction. You can do this one only if the probable
rebounce position is already in direct vicinity. If the two gathered normals
differ too much, perhaps you have an idea on what's going on?
It's just an idea. Not too parsing intensive, I guess, but perhaps some more thinking
would do a better trick.
Tim
