POV-Ray : Newsgroups : povray.binaries.animations : Purple Cohesive Goo Server Time
17 May 2025 05:17:19 EDT (-0400)
  Purple Cohesive Goo (Message 1 to 7 of 7)
Subject: Purple Cohesive Goo
Date: 3 Dec 2001 16:30:31
Message: <3C0BEB6A.AD4AC797@yahoo.com.au>
The same animation as posted a few days ago, but this shows the particle cohesion
a little better. This time it's with purple blobs. The particles are smaller than
the previous attempt but this is only a display thing; I save particle data for
each frame so that re-renders are quicker and a re-render of any particular frame
on its own is possible. This is helpful when using particle interactions, as
these can be _very_ slow.
Comments, criticisms?
MJL
light_source{12*(y-z)rgb 2fade_distance 9fade_power 2area_light x,z,5,5}#macro A
(H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local I=1;#while(I<H)#local V=asc(substr(B,I,1
))-33;<div(V,10)mod(V,10)>#local I=I+1;#end pigment{red 1}rotate-<90,R>translate
-T}#end A(16"/.@VZno=<PLA89/"0,5*x)A(14",6;MWmhryXN3,"60<15,0,8>)camera{location
25*(y-z)look_at 0}A(8"6hiAG=6"-60,-10*x)box{-99(x+z)*99 pigment{rgb 1}}   // MJL
Download 'pgoo.mpg' (679 KB)
Subject: Re: Purple Cohesive Goo
Date: 3 Dec 2001 17:03:54
Message: <3C0BF6E6.7FE729B5@gmx.de>
I like it, but the inter particle forces seem to work on a quite long
distance which does not look very realistic.
Date: 3 Dec 2001 20:09:59
Message: <3c0c2267$1@news.povray.org>
cohesion
smaller than
data for
particular frame
as
you seem to end up with a lot less goo than you started with
PGP Public Key
Date: 4 Dec 2001 15:01:46
Message: <3c0d2baa@news.povray.org>
> shows the particle cohesion a little better.
It's much more visible now, and looks rather cool!
However, I think the repulsion is too weak compared to the attraction. The
result is that it looks like it is being compressed to a fraction of the
space it occupies in the start. I get the feeling "hey, where did all the
particles go?".
> I save particle data for each frame so that re-renders
How much disc space does that take in total?
(And how many particles and how many frames do you use?)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 4 Dec 2001 16:02:25
Message: <3C0D3673.41785654@yahoo.com.au>
I think this will be a matter of fine tuning.
MJL
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 4 Dec 2001 16:04:21
Message: <3C0D36E7.E9E6EC31@yahoo.com.au>
Yes, it appears so :-(. I have found the error (particle repulsion max is too
low).
MJL
> Rick
> Kitty5 WebDesign - http://Kitty5.com
> POV-Ray News & Resources - http://Povray.co.uk
> TEL : +44 (01270) 501101 - FAX : +44 (01270) 251105 - ICQ : 15776037
> PGP Public Key
Date: 4 Dec 2001 16:17:05
Message: <3C0D39E1.CE9E9670@yahoo.com.au>
Thank you!
> particles go?".
You are right. I set my max repulsion too low. When I get a better example, I'll
post it.
For that animation, there were 500 particles. Each frame of data took up ~ 32kb.
The animation I sent had 400 frames (from memory. I rendered 500, but the last
100 or so were uneventful), so that's about 12.5 Mb. The way I save my data could
be more efficient, but it works for now. I originally wrote this part of my
system to save time. Not having to recalculate particle interaction cut the
render time down by three quarters. I think this is a good trade-off.
MJL
