Inspired by Tim's animation I made this one. Also a perfect occasion to test
bouncing and "floating" against a moving object. :)
Hope you like it.
BTW, I didn't do anything special to make the balls roll around there in the
edge; it's just a result of the movement of the pad...
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Nov 5)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
Download 'rainbow_r.mpg' (605 KB)
> Hope you like it.
The first part looks very good, but later the particles seem to stay too
fast. I suppose you don't simulate friction on the surface, doing this
could add much to realism IMO.
Christoph Hormann <chr### [at] gmxde>
"Christoph Hormann" <chr### [at] gmxde> wrote in message
news:3C0BDCEE.C040C872@gmx.de...
test
> > Hope you like it.
the
Though the movement of the pad could be adding energy to the particles.
Perhaps it's teflon? ;) Still looks good, anyway. And at first I thought I
saw three balls fall through, but watching, I can see they bounced over the
side
Cool. Ever thought of golf course? The typical rolling green hills with 1000
balls shot in general direction of hole from a tee a mile away.
Now simulate gold panning :-)
MJL
light_source{12*(y-z)rgb 2fade_distance 9fade_power 2area_light x,z,5,5}#macro A
(H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local I=1;#while(I<H)#local V=asc(substr(B,I,1
))-33;<div(V,10)mod(V,10)>#local I=I+1;#end pigment{red 1}rotate-<90,R>translate
-T}#end A(16"/.@VZno=<PLA89/"0,5*x)A(14",6;MWmhryXN3,"60<15,0,8>)camera{location
25*(y-z)look_at 0}A(8"6hiAG=6"-60,-10*x)box{-99(x+z)*99 pigment{rgb 1}} // MJL
> seem to stay too fast. I suppose you don't simulate friction
> on the surface, doing this could add much to realism IMO.
Correct, I don't simulate friction on the surface because I think it would
lead to uncontrollable results with the algorithms I'm using. I'll probably
investigate that further.
That said, the particles do gain energy from the motion of the pad.
Rune
"Greg M. Johnson" wrote:
> Cool.
Thanks!
> green hills with 1000 balls shot in general direction
Well, out of the many things I'd like to try out with my particle system,
that isn't one of the most interesting as I see it.
Rune
Hehe ;)
Rune
Is this scene generated in Mathematica like some of the other recent ones? I
wonder if anyone has any particle systems that "run" completely under POV..
There's Chris Colefax', of course..
D.
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3c0bcfe9@news.povray.org...
test
> Hope you like it.
the
> Rune
> 3D images and anims, include files, tutorials and more:
I don't think so. Most of these scenes are exclusively POV generated.
>I wonder if anyone has any particle systems that "run" completely under
POV..
> D.
But Chris Colefax' systems are not so up to date. They lack all the
possibilites offered by the trace () function.
Jonathan.
