Subject: Re: Music sync test (mpeg, ~1MBbu, really poor quality)
Date: 26 Oct 2001 13:09:27
Message: <3BD9987D.803791C2@aol.com>
Pretty neat. Was it mere trial and error or did you figure out a was to "see the
beats?"
Date: 26 Oct 2001 13:21:11
Message: <3bd99b87@news.povray.org>
"Greg M. Johnson" <"gregj56590[:-0]"@aol.com> wrote in message
news:3BD9987D.803791C2@aol.com...
"see the
> beats?"
Bear in mind that I haven't actually seen Warp's anims (I don't have time to
download them right now), but my own experiments with syncing to music were
succesful, and there was no guess work involved. I made some music at 120
beats per minute. That's two beats every second, or 12.5 frames between
beats (assuming a frame rate of 25 fps). Worked perfectly for me.
All the best,
Andy Cocker
Date: 26 Oct 2001 13:26:52
Message: <3bd99cdb@news.povray.org>
Andy Cocker <big### [at] mariner9 fsnet co uk> wrote:
: Bear in mind that I haven't actually seen Warp's anims (I don't have time to
: download them right now), but my own experiments with syncing to music were
: succesful, and there was no guess work involved. I made some music at 120
: beats per minute. That's two beats every second, or 12.5 frames between
: beats (assuming a frame rate of 25 fps). Worked perfectly for me.
Yes, the synchronization was just pure math in my case as well. However,
in my case it wasn't that easy. The music is played at 150 bpm (32 seconds
in total) and the animation has 25 fps.
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
Date: 26 Oct 2001 13:29:26
Message: <3bd99d76@news.povray.org>
Greg M. Johnson <"gregj56590[:-0]"@aol.com> wrote:
: Pretty neat. Was it mere trial and error or did you figure out a was to "see the
: beats?"
Just simple math. The music has 20 measures, that is, 80 beats. I just had
to make the isosurface pulse 80 times during the animation and make the
animation exactly as long as the music (32 seconds at 25 fps = 800 frames).
in news:3bd989f4@news.povray.org Warp wrote:
> This mpeg has a really poor quality (both image and sound) so
> that it would be about 1Meg in size.
But it is in sinc and the other one's not. Probably my poor PII does
not have the power to show the divx one right.
Ingo
Pov-Ray : http://members.home.nl/seed7/
Date: 27 Oct 2001 04:19:11
Message: <3BDA6849.6EB29725@m.org>
Really Excellent !!!
Denis.
Warp wrote:
> I was just testing if I could synchronize a pov animation with music and
> thought that I could just share my first test.
> Yes, the music is made by me (with midi).
> This mpeg has a really poor quality (both image and sound) so that it would
> be about 1Meg in size. If you can view DivX avis, I recommend checking my
> other post (the quality is much better).
> IsoMusic.mpg Type: MPEG Video (video/mpeg)
> Encoding: x-uuencode
