Subject: Re: i'm looking over a four leaf clover ..(615 kbu mpeg)
Date: 12 Feb 2001 00:35:36
Message: <3a877628$1@news.povray.org>
"Ben Paschke" <ben### [at] rspcomau> wrote in message
news:3A872B54.C79C32D6@rsp.com.au...
> is anyone able to view this? - i'm using an mpeg encoder that i've never
> used before.
I use Windows Media Player version 7 and it will display the mpg file but
there's a blinking purple line across the bottom of the animation. It looks
like it's about 1-2 pixels high and goes all the way across the frame during
the entire animation.
-Dave
Date: 12 Feb 2001 01:16:21
Message: <3A878002.40F7C060@rsp.com.au>
hmmmm, curious .. i'll look into it. thanks :)
> > used before.
> -Dave
Date: 12 Feb 2001 01:21:23
Message: <3A87812F.836B2048@rsp.com.au>
Dearmad wrote:
> MPG worked fine for me.
> Very pretty colors. Nice atmosphere to the
> scene. Now... add a little wind!
yes! wind! i need to standardise the way i work so that i don't have to
re-code things like wind.
i've created wind effects for only afew things now and i always seem to
have to start again each new time.
i'd like to eventually build up a library of atmospheric effects, like
wind types, assorted things floating thru the air etc..
thanks.
Date: 12 Feb 2001 04:50:00
Message: <3a87b1c8@news.povray.org>
Nice plants. Just clipped spheres? I like the colour scheme you used here.
The ground looks a bit flat at the end of the animation. Is it just a
textured plane? If so, may I suggest to use a heightfield for it?
Marc-Hendrik
Ben Paschke schrieb in Nachricht <3A872B54.C79C32D6@rsp.com.au>...
>Hi folks,
>this was made last friday, in about 3 hrs and took about 14 hrs to
>render 70 frames.
>The little plants are just clipped spheres, textured with a black and
>white image map used with the pigment_pattern pattern in mpov06. the
>black and white image map let me use the same image map on each clover
>but with slightly different colour_maps.
>used before.
Date: 12 Feb 2001 05:27:07
Message: <3a87ba7b@news.povray.org>
looks
during
save here, only noticed it when playing it full screen :)
could you continue the clovers on to the horizon? or patches of them.
POV-Ray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 12 Feb 2001 15:15:26
Message: <3a88445e@news.povray.org>
Windows NT 4 and MS Media Player (6.4.05.0809).
I'm suffering from the purple line in 1x, 2x and full screen, but not in
0.5x magnification. Otherwise looks great.
Can I ask, are the clover all slightly different shades of green, or is it
the specular making them appear to change colour slightly as the image
rotates ?
Duncan Gray
(warning: may contain traces of nut)
Date: 12 Feb 2001 18:22:02
Message: <3A887065.27571679@rsp.com.au>
yes, yes i could. i just layed out a suqare patch (translate
<(rand(sd1)*5)-2.5,0,(rand(sd2)*5)-2.5>) and then animated the camera and then
only realised the "patch" didin't fill the view once the anim was rendered ...
such is life whilst raytracing.
I guess i'd then instance the patch that i do have out to the horizon.
i think maybe a useful macro would be to create a view frustum that you could
call to define the bounds of object creation.
Date: 12 Feb 2001 18:30:52
Message: <3A887277.A248140B@rsp.com.au>
> rotates ?
The clovers are all slightly varied in colour. I textured with the black and
white image map and then in each loop creating each clover i added a
colour_map that was randomly varied by a very small factor. While the factor
is very small, i'd say that, within the reason of pov's random generator, each
clover's colour is unique.
it may have made more sense, in a economy of memory kinda way, to have made 3
or 4 descreet different textures, because at the moment there are as many
pigment definitions as there are individual clovers.
Date: 12 Feb 2001 18:36:52
Message: <3A8873E0.19A85DD9@rsp.com.au>
You are correct! The ground is textured plane. I wasn'tt expecting the angle
of the camera to get so low. Yes, a height field would be perfect. I could
then add some more interest with small hills and the like. I should be
returning to other projects, but with features like povray has, it's possible
to play with scenes forever!
Date: 14 Feb 2001 12:25:23
Message: <3a8abf83@news.povray.org>
"Duncan Gray" wrote in message news:3a88445e@news.povray.org...
Win 98, first edition, Media Player 6.4
No purple line, even full screen.
