POV-Ray : Newsgroups : povray.beta-test : Gamma again Server Time
2 Apr 2026 04:26:07 EDT (-0400)
  Gamma again (Message 21 to 24 of 24)
Subject: Re: Gamma again
Date: 9 Dec 2008 06:10:00
Message: <web.493e51d884dfb9ccbf0f3c840@news.povray.org>
"scott" <sco### [at] scottcom> wrote:
> No, because it's better to have an 8bit number with bigger steps in
> brightness at the higher end, because that's how your eyes work.  If the
> difference in brightness between 4,4,4 and 5,5,5 were the same as
> 254,254,254 and 255,255,255 (ie gamma 1.0) then we would see even worse
> "colour banding" for darker colours than we do currently with 8 bit
> hardware, and at the top end there would be an even less visible change for
> each step.
100% agree. That's one of the reasons I typically do only HDR output these days.
Did I mention that I like MegaPOV? :)
Date: 9 Dec 2008 20:55:00
Message: <web.493f20a584dfb9cc2c4b57320@news.povray.org>
In the latest beta I keep getting this error:
"Parse Warning: assumed_gamma is not supported in POV-Ray v3.7 and later SDL.
For compatibility purposes an assumed_gamma of 1.0 is taken to
mean gamma correction is on (which is also now the default setting). If you will
not be using this scene with older versions of POV-Ray it
is safe to remove the assumed_gamma statement. See the documentation for more
information regarding this change."
Where is the current methodology documented? I checked the help file and the
section on assumed_gamma seems to not have been changed.
-Mike
Date: 9 Dec 2008 22:20:01
Message: <web.493f347584dfb9cc354e5c630@news.povray.org>
It's a beta, so people using it are expected to read the release notes, readme
files and other stuff nobody would usually bother to read for a final release.
The documentation is in beta-stage as well, meaning it needs work, too.
(Although to me it actually seems closer to 3.6 gamma still than anything
else... I guess the PoV-ray developers are mainly programmers after all, so
end-user documentation will be the last thing on their to-do lists.)
Date: 9 Dec 2008 22:45:00
Message: <web.493f3a6384dfb9cc2c4b57320@news.povray.org>
OK, thanks.
-Mike
