POV-Ray : Newsgroups : povray.beta-test : Gamma again Server Time
2 Apr 2026 02:41:30 EDT (-0400)
  Gamma again (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Gamma again
Date: 5 Dec 2008 16:44:14
Message: <4939a0ae@news.povray.org>
Le 04.12.2008 17:10, clipka nous fit lire :
> Just wanted to point out that the current approach is too limited in my opinion.
> There should be separate (!) options to gamma-correct (or reverse
> gamma-correction) for...
> - preview output window (to adjust for the PoV-ray user's display of course, if
> necessary)
I'm a strong believer that the combination of graphic cards and display
should provide a gamma of 1.0: linear curve;
CRT with 2.2 imply a correction at the graphic cards of 0.45; from there
  the system then has a 1.0 display subsystem and all should be linear.
Opposite of <1.0, 0.5, 0.0> should be <0.0, 0.5, 1.0>, whatever the
number of bits per channel (I like 8, but you need a CRT; LCD do not
have so much bits for all colour... and they might not be linear)
> - image output file (to adjust for the "end viewers'" displays, or
> post-processing steps that may expect a certain gamma correction)
And for image format which support exposing gamma, another one ?
Picture_gamma & Correction_gamma... well find a pair of better names.
> - image input file, on a per-image(!) basis (to compensate for input files that
> may (or may not!) be gamma-corrected for different viewing conditions)
That's a post load gamma correction (beware, PNG for instance already
have one factor from picture: do you want to be able to ignore it ?)
> - color literals, (a) on a scene-global scale and (b) on a per-color basis
> (maybe using macros; to compensate for colors "picked" in an image processing
> software from gamma-corrected pictures)
Global scene should remains linear.
A function/macro for gamma-correction of a colour might be interesting.
(given the computation, a function might be better, but I'm biaised)
> Also note that *all* these settings shold allow for *arbitrary* corrections, not
> just the choice of either "no gamma correction" or "corrected for a gamma of
> 2.2".
Of course!
And please, by default, have a 1.0 everywhere.
Date: 5 Dec 2008 17:03:14
Message: <4939a521@news.povray.org>
I thought that too, and tried configuring my graphics card that way.
Everything looked washed out. Because almost nobody who makes images or
chooses website colors or whatever has the gamma set that way.
Date: 5 Dec 2008 21:20:00
Message: <web.4939e0c884dfb9ccc40856790@news.povray.org>
I'm more of a realist than a believer in this, as unfortunately there is a
*significant* difference between "should" and "is".
If you want a raytracing software for an ideal world - fine. I want one I can
use in the real world.
No, why should there be another parameter for that? It's just another image
output format. If it records the gamma it is assumed to work on without
additional correction, then all the better.
Possibly. I'd expect reality to come up with PNGs which actually specify a wrong
factor.
One simple question: Why?
Some people may prefer to sacrifice the ability to do simple color additions,
and instead prefer to be able to pick all their colors from other programs (all
the more since PoV-ray doesn't come with a built-in picker).
Internal calculations should remain linear, but why scene? Why not allow people
the freedom to use a different gamma as default for all colors they enter?
Maybe one reason why so many people misused the gamma stuff is because PoV-ray
documentation makes a big fuss about it, saying "hey people, very important
thing: get your gamma things right!" - without PoV-ray providing enough options
to *really* get them right...?
A macro should definitely suffice - if you want to do calculations, even I agree
that they should be done in 1.0 gamma. So all that's needed should be a macro to
fix the input.
> > 2.2".
> Of course!
Personally I don't care about the defaults - as long as they work for people who
don't know what they're doing, and I can set them however I like.
Date: 5 Dec 2008 21:30:00
Message: <web.4939e31384dfb9ccc40856790@news.povray.org>
Yep. Which is because nobody who *views* websites has the gamma set that way.
Simple as that. There's a de-facto standard out there in real life. It's rather
vague, but it's definitely *not* 1.0.
One more reason why I'd like PoV-ray to support arbitrary gamma for output. It
may be wrong from a sort of religious point of view, but it works.
Date: 6 Dec 2008 06:53:22
Message: <493a67b2$1@news.povray.org>
That would probably not look good with just 8-bit per color. But I do
agree that would be the best. I don't think it would happen because in
the transition from today's default of 2.2 everything would look ugly.
Most people view with something close to 2.2 I guess.
The de-facto standard on the web seems to be sRGB with a gamma close to
2.2 (The true gamma is more complicated, see
http://en.wikipedia.org/wiki/SRGB).
Thats what my monitors are tuned to anyway.
Daniel Nilsson
Date: 6 Dec 2008 14:08:05
Message: <493acd94@news.povray.org>
> way.
Correct. Typical catch-22, particularly hard to get out of...
Date: 6 Dec 2008 14:25:02
Message: <web.493ad10a84dfb9cc6890bf690@news.povray.org>
> > way.
.... or, in this case, a catch-2.2, so to speak...
Date: 6 Dec 2008 21:44:42
Message: <2A0F10FD2E0E441587EF3D94A0AFA4CE@HomePC>
> -----Original Message-----
> From: Stephen [mailto:mcavoysAT@aolDOTcom]
> Not everyone can use a newsreader at work on a locked down company
> machine.
Do I really need to point out that usually companies who lock down their
machines like this also have policies about using the computer for
personal use?
If you're going to circumvent your company's policies, then be prepared
for trouble.
...Ben Chambers
www.pacificwebguy.com
Date: 7 Dec 2008 03:04:32
Message: <oh0nj4d1l14r3t7lb28s6uo2mfc4b1mpbg@4ax.com>
On Sat, 6 Dec 2008 18:44:11 -0800, "Chambers" <ben### [at] pacificwebguycom> wrote:
>> machine.
>personal use?
No, you don't need to point it out.
>for trouble.
Of course! My captain.
Regards
Date: 9 Dec 2008 04:08:47
Message: <493e359f$1@news.povray.org>
No, because it's better to have an 8bit number with bigger steps in
brightness at the higher end, because that's how your eyes work.  If the
difference in brightness between 4,4,4 and 5,5,5 were the same as
254,254,254 and 255,255,255 (ie gamma 1.0) then we would see even worse
"colour banding" for darker colours than we do currently with 8 bit
hardware, and at the top end there would be an even less visible change for
each step.
BTW inside most LCDs, the 8 bit input signal will be used to index a look up
table (which contains the gamma and LC response curves), where the entries
are 10 or 11 bit numbers that then drive the DACs that directly give the
voltage to each pixel.  Very cheap LCDs only use 6 bits to index the look up
table, and then have 8 or 9 bit DACs, but they are becoming rarer and rarer
nowadays.
