![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3C447B93.CC3C8553@gmx.de> , Christoph Hormann
<chr### [at] gmx de> wrote:
>> It is by design for _this_ beta and part of the changes to the output that
>> have been in progress for several weeks now until a final solution can be
>> found. The previous beta versions' output was incorrect, the current change
>> only disables the incorrect output without providing the correct output yet.
> I suppose this means that part is still subject to change and i should
> wait with writing the announced doc part.
Only the "evaluate" part, that ios the "dynamic method" part, is subject to
change. Using the method with the constant max_gradient I expect no need
for changes.
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"R. Suzuki" <r-s### [at] aist go jp> wrote in message
> That is useful in some cases. For example, try the following JRG's
> code with "evaluate 1.2, 1.1, 0.98" instead of "evaluate 1, 10, 0.99".
> http://news.povray.org/3bdf2d82%40news.povray.org
> The rendering speed would be faster than the fixed max_gradient.
> Those parameters of the recent beta work as designed.
> The description of those parameters can be seen at
> http://news.povray.org/3be10cf9@news.povray.org
Both of these messages are in the same thread and I had read it at least twice.
But reading it a third time in the context of your explanation of the useful
cases, seems to have helped. I wasn't clear until now exactly what the 'user
error' was. Thanks for helping to clarify.
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>) // Batronyx ^"^
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wasn't it Coridon Henshaw who wrote:
>Incidentally, do you have a current list of unconfirmed bugs? I'd like to
>go through it and look for confirmable problems.
This isn't completely up to date. I've been a bit busy recently.
max_trace_level affects radiosity recursion_limit
(Setting max_trace_level 1 disables radiosity and max_trace_level 2 sets
recursion_limit to 1)
http://news.povray.org/3BE40295.6C3D54DE@engineer.com
Bugs with string/macro handling
http://news.povray.org/3be76148$1@news.povray.org
Philosophical objection to fog distance=0
(Fog colour is then ignored)
http://news.povray.org/3BE7E897.FEC8EF6@aol.com
Animated textures
(memory usage goes quite high)
http://news.povray.org/3bea26bf@news.povray.org
Isosurface *disappears* at high resolution (fwd)
http://news.povray.org/3bb0b351@news.povray.org
Media visible container line in front of object
(a visible whitish line appears at the edge of a transparent container
box for media)
http://news.povray.org/3bf45a3d@news.povray.org
Priority troubles
(higher priorities cause slower render)
[win gui] line with error highlighted but render finished succesfully
http://news.povray.org/va2tvt4tuitd67ik5t9ps334sbg6205bt3@4ax.com
var_refl.pov (\scenes\textues\finishes) Beta 8
(should #include "functions.inc")
http://news.povray.org/3C0A9650.6B98925@compuserve.com
transform syntax
(transform {test_trans} sometimes requires {} and sometimes doesn't)
http://news.povray.org/3C09EE1B.A38DC91A@gmx.de
Win Beta 8: Message window/parse hang error?
(hangs after "Degenerate Blob" warning)
http://news.povray.org/3c0bdc77@news.povray.org
another bug I haven't seen mentioned
(Yellow band around sky_sphere equator)
http://news.povray.org/3c10ef62$1@news.povray.org
media & fog bug?
http://news.povray.org/3c1379e0$1@news.povray.org
bug in sphere_sweep for removing parts of an object
(parameterised sphere_sweeps are very slow. May or may not be related to
job000176)
http://news.povray.org/3C1A5D47.EA38F6E5@amc.uva.nl
Re: Mosaic... some clarifications
(#local A2=P(1,2,3).hf; fails)
http://news.povray.org/9n9j1uo0mdlrs4i5toupujr0pqrj4vvb8d@4ax.com
Re: hollow in light groups
http://news.povray.org/3c21172d$1@news.povray.org
Is there a problem with area light
http://news.povray.org/3c22f013@news.povray.org
Bug with transform syntax
http://news.povray.org/chrishuff-5FC1B7.19310427122001@netplex.aussie.or
g
Minor Windows annoyance
http://news.povray.org/3c2bec89@news.povray.org
[linux] Rendering without display on the console.
http://news.povray.org/3c3f0a80@news.povray.org
Beta 10 bugs
(Demo scenes in scenes\camera\ will not parse)
http://news.povray.org/Xns9197A5B08390CCQ@204.213.191.226
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>to go through it and look for confirmable problems.
Fixed in Beta 10.
-Mark Gordon
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mike Williams <mik### [at] nospam please> wrote in
news:4gz### [at] econym demon co uk:
> sets recursion_limit to 1)
I can confirm portions of this report. While reducing max_trace_level to 1
does not disable radiosity under beta 10, max_trace_level does appear to
impose an upper bound on recursion_limit. recursion_limit settings in
excess of the max_trace_level appear to be ignored.
Partial confirmation. I can get error cases #1 (Too many nested symbol
tables) and #2 ("BCFGHJKLMQSUVWXY") but none of the others.
At first glance that the original poster is trying to do with the scene
description language is somewhat akin to driving nails with a shoe. As
such I am unsure if this problem should be fixed or if the workaround
should be 'reimplement your code in perl, Python, rexx, or C.'
Confirmed that the code provided works as the original poster stated.
> Animated textures
Not tested. I suspect this bug might be another incarnation of one of the
various memory leaks reported elsewhere.
Cannot duplicate.
> box for media)
Confirmed. This problem can be masked--but not eliminated--with
antialiasing.
> Priority troubles
Uhhh, message-id? ;-)
Not tested specifically, but I've run into this problem before with
ordinary parsing errors (e.g. undeclared identifiers) not related to
#fopen.
Cannot duplicate.
> transform syntax
Confirmed.
Insufficient data to make a determination.
A generic scene containing a single degenerate blob did not cause pov to
lock up.
Cannot duplicate with the following scene:
sky_sphere {pigment {gradient y triangle_wave color_map {[0 rgb 0] [1 rgb
1]}}}
If the original poster can provide a sample scene I will try again.
> media & fog bug?
Confirmed.
> to job000176)
Confirmed.
Confirmed.
Confirmed.
Cannot duplicate. area_light settings which produce smooth shadows under
3.1 also produce smooth shadows under 3.5.
> g
Confirmed.
Chris Cason said (in <3c2c6b4a@news.povray.org>) that he's looking into
this one.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
che### [at] sympatico ca (Coridon Henshaw) wrote in
news:Xns### [at] 204 213 191 226:
> Cannot duplicate.
Correction. Confirmed.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <Xns### [at] 204 213 191 226> ,
>> Cannot duplicate.
This "bug" never was one as explained in the same thread.
I am surprised it is still in the unconfirmed list at all...
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>output that have been in progress for several weeks now until a
>final solution can be found. The previous beta versions' output
>was incorrect, the current change only disables the incorrect
If you want to change the output of 'evaluate' more helpful,
please add "maximum gradient variation" between neighboring rays.
[grad_var = abs(max_grad(Nth ray)-max_grad((N-1)th ray) ) ]
Then, the parameters of 'evaluate' for dynamic max_gradient estimation
should be as follows,
1st parameter < max_grad
1 < 2nd parameter < max_grad/(max_grad - max_grad_var)
1 > 3rd parameter > 1/(2nd parameter)
R. Suzuki
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Coridon Henshaw wrote in message ...
I'm doing this in SDL for much the same reason that Warp wrote the SDL
raytracer and I wrote my POV-Ray Scene Virus -- to show that it can be done.
Mark
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks. Added to known bugs.
I think I'll move that into the "not a bug" box, unless anyone has
serious objections.
I knew that, the question is whether the code should behave that way or
not.
>> Animated textures
>Cannot duplicate.
I can duplicate this (although the quick version that I wrote now runs
to completion). The point at which the quick version collapsed into
blankness has varied from beta to beta, and now manages to go all the
way through. The original scene file posted by Warp still fails when
rendered with the specified size and antialliassing.
The question is whether this is a bug, or whether isosurfaces that use
crackle can legitimately be expected to disappear.
>> box for media)
>antialiasing.
>> Priority troubles
3BF4B750.39EA34A7@joplin.com
>#fopen.
Thanks. I'll add that to known bugs.
>Cannot duplicate.
>> transform syntax
>Confirmed.
>lock up.
>1]}}}
>> media & fog bug?
>Confirmed.
>> to job000176)
>Confirmed.
>Confirmed.
>Confirmed.
>> g
>Confirmed.
>this one.
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
