POV-Ray : Newsgroups : povray.beta-test : Known Bugs - 31 Dec 2001 Server Time
23 Mar 2026 04:26:26 EDT (-0400)
  Known Bugs - 31 Dec 2001 (Message 21 to 30 of 35)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: Known Bugs - 31 Dec 2001
Date: 2 Jan 2002 18:53:37
Message: <3c339d81$1@news.povray.org>
In article <3c339434@news.povray.org> , "Gergely Vandor"
<ger### [at] vandordatanethu> wrote:
> I bet you are already fed up with plain users arguing with the real
> programmer, but this may be interesting :o)
Well, computer programs are no magic.  What you describe is an effect caused
by what I explained.  There is no check if there are more than two objects
to then let some specific ones disappear in POV-Ray, I am sure! :-)
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 3 Jan 2002 07:05:56
Message: <bjh83uoqe38ikbi4s2qbg43ik7ot2k1vhc@4ax.com>
On Mon, 31 Dec 2001 12:24:37 +0100, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> > crash during debugging of parsing
> > http://news.povray.org/332m2uspk9nfqfq6g7oc8qtmkcu5higjs7@4ax.com
> > crash with loop
> > http://news.povray.org/3c2cb9b7@news.povray.org
> Both logged as job000205.
You know sources however I want note (I played with those bugs a lot) they are
different.
First
- works only when #stream directive is used and works fine without it.
- not depend on length of loop
- crash in second run after stop of first parsing
Second
- it is not related with any #stream (or only input stream)
- depends on length of loop (infinite loop)
- crash in every run
There are probably more differences.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)&_((x+y)*.7,z,.1)&_((x+y+2)*.7,z,.1)&_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 3 Jan 2002 07:46:55
Message: <3c3452bf@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c339d81$1@news.povray.org...
caused
I understand this is like beating a dead horse, so I only have a last
question.
In the scene I quoted, it is clear to see that including certain objects
(objects far away from the camera, etc) make other objects vanish from the
resulting image. This happens with all the camera options unchanged. Does
this mean that in this case povray somehow takes the objects of the scene
into account when interpreting camera options?
So far you have only stated that certain combinations of camera options can
have unexpected results. In this case we are talking about combinations of
camera options and object placement.
Gergely
Date: 3 Jan 2002 08:28:53
Message: <3c345c95$1@news.povray.org>
In article <3c3452bf@news.povray.org> , "Gergely Vandor"
The camera could not care less for the objects in the scene.  There is no
interaction.  If you are lucky one of the advanced users will have the time
to look into your scene and find the problem in it.
    Thorsten
e-mail: tho### [at] trfde
Date: 3 Jan 2002 10:32:00
Message: <3c347970@news.povray.org>
It could perhaps be a bounding problem. Bounding is reliant on both the
camera and the objects in the scene and automatic bounding is indeed not
used when the amount of objects is below a certain number.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 2)
Date: 3 Jan 2002 10:58:56
Message: <3c347fc0@news.povray.org>
In article <3c347970@news.povray.org> , "Rune" <run### [at] mobilixnetdk>
True, bounding and buffers (are those used with orthographic cameras? - I
don't remember).  If the problem goes away with buffers off it is probably
that the code assumes a correct camera vector aspect ratio which gets
"damaged" by "angle".  But if the effect is the same with auto bounding and
buffers off, the problem is in the scene.
    Thorsten
Date: 3 Jan 2002 14:40:39
Message: <0QyarBA0ILN8EwWM@econym.demon.co.uk>
>caused
>question.
It has been previously determined, in another thread[1], that the bug is
only seen if vista buffers get used. By default, POV has vista buffers
switched off when there are less than three objects in a scene and
switched on when there are three or more objects in the scene.
Adding the third object invokes the vista buffer code and makes the
target object dissapear.
Behold: Use -UV in your scene to switch vista buffers off. The scene now
renders correctly however many objects are in your scene.
It might possibly be that the orthographic camera and the vista buffers
are interpreting the camera details differently when the camera keywords
are not in the order that they expect. (e.g. perhaps the vista buffers
are "correcting" for the fact that the angle keyword is in the "wrong"
place, and therefore buffering the scene incorrectly for a camera that
doesn't do so.) It's a bit like having a "bounded_by" in the wrong
place, so the rays never get tested for intersection with the object.
[1] http://news.povray.org/3c2fe9ec@news.povray.org
Mike Williams
Gentleman of Leisure
Date: 3 Jan 2002 17:29:35
Message: <3c34db4f$1@news.povray.org>
"Mike Williams" <mik### [at] nospamplease> wrote in message
news:0Qy### [at] econymdemoncouk...
Thanks. I'm sorry I brought this up again, I overlooked the message
concerned, and I was confused by Thorsten saying this was "not a bug".
Gergely
Date: 6 Jan 2002 17:51:44
Message: <3c38d500$1@news.povray.org>
From Known Bugs - 24 Dec 2001
>         BUGS FIXED IN BETA 9
> Slow render time after several runs
> http://news.povray.org/3c174fda$1@news.povray.org
At least in my beta 9 this isn't fixed..
Ari-Matti
Date: 6 Jan 2002 20:03:23
Message: <3c38f3db@news.povray.org>
In article <3c38d500$1@news.povray.org> , "Ari-Matti Leppanen"
It is fixed.  Please read what is wrong with your scene and how it needs to
be changed:
Date: Tue, 01 Jan 2002 11:55:56 +0100
Newsgroups: povray.beta-test
Subject: Re: Known Bugs 24 Dec 2001 (beta 9)
Message-ID: <3c3195be@news.povray.org>
Xref: news.povray.org povray.beta-test:3640
    Thorsten
Thorsten Froehlich
