![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Skiba <abx### [at] babilon org> wrote:
> I just found clear sentence within documentation "Calling a macro in another
> file therefore requires that the other file be opened and closed for each
call.
> Normally, this overhead is inconsequential; however, if you are calling the
> macro many thousands of times, it can cause significant delays. A future
version
> of the POV-Ray language will remove this problem."
> I hope "future" mean 3.5a ;-)
4.0 if you are lucky.
Thorsten
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 02 Nov 2001 18:02:07 +0100, "Thorsten Froehlich" <tho### [at] trf de>
then timidly I wait for next megapov
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Keep in mind that behind most not included features there are serious
technical or design problems. I am not saying anything about this
particular feature, but in general, you should not expect to find all "lost"
features in a future MegaPOV that is based on 3.5 - it might well be that
POV-Ray 3.5 breaks more than a few patches that are currently part of
MegaPOV 0.7...
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 02 Nov 2001 18:52:43 +0100, "Thorsten Froehlich" <tho### [at] trf de>
I thought about it this way. I found explanation for my problem and now I can
work with workarounds. Don't spent your time with such details. Go! Go to other
bugs :-) POV 3.5 is my favourite tool.
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp <war### [at] tag povray org> wrote:
: * When outputting to PNG, the wrong gamma correction value is written to it.
: The value 1.0 is always written as gamma to the PNG, which is wrong.
AFAIK this has been fixed (for next beta).
: * Focal blur aperture has no effect with camera types other than the
: persective one
And this is being taken care of (but not necessarily fixed for the next
beta).
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wasn't it W3odzimierz ABX Skiba who wrote:
>On Thu, 1 Nov 2001 07:29:29 +0000, Mike Williams <mik### [at] nospam please>
>wrote:
>> Since nobody else wanted to take this on, and since I've got a bit of
>> leisure time, I'll have a bit of a go. There may well be things that
>> have fallen through the gap between when Rune stopped and I started
>> collecting the info.
>you missed this
>Bug with declaration with no dimensions
>http://news.povray.org/scpitt851apfq5r6qtsoi1vpupt77g829s@4ax.com
>I don't know it is confirmed or not (Ron answered but no change within
>beta 7)
Is this a bug or a documentation error? Is there a case where we might
want to write "#local A=array;" and have it behave like this?
I'm not collecting documentation errors.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wasn't it Mike Williams who wrote:
>The "unconfirmed" section at the end is there for my convenience. It's
>easier for me to capture the information when I first see it rather than
>waiting for a confirmation to be posted.
I guess this turned out to be a bad move. I'll continue to capture
unconfirmed bug information, but I don't think I'll post it again.
Several people asked for unconfirmed bugs to be added to the list. I've
added the details to my database, but they won't appear in the known
bugs posts until they are confirmed.
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> you missed this
> beta 7)
It's confirmed. I even know what causes it, but I haven't had time to fix it
yet. I did take the minute or so it took to enter it in the Team's bug
database, though.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> you missed this
>> beta 7)
> database, though.
It should be fixed in the next beta (along with the related problem of being
able to specify a zero or negative dimension_size for one or more dimensions.)
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is anybody still updating this list?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
