POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.10008988 Server Time
28 Jun 2026 08:37:24 EDT (-0400)
  POV-Ray v3.8.0-alpha.10008988 (Message 1 to 10 of 10)
Subject: POV-Ray v3.8.0-alpha.10008988
Date: 11 Jan 2019 12:24:18
Message: <5c38d142$1@news.povray.org>
I've decided that the new tokenizer is here to stay and reasonably
mature, so I thought I might just as well make it part of the official
development branch:
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-alpha.10008988
There's still quite a lot of work I intend to be doing on the main
parser to take advantage of the new tokenizer, but for now I'll focus on
some changes to TrueType font handling, which needs some TLC after the
new tokenizer has shaken up charcter set handling.
Subject: Re: POV-Ray v3.8.0-alpha.10008988
Date: 12 Jan 2019 07:40:00
Message: <web.5c39df5ba3acffd948892b50@news.povray.org>
hi,
> development branch:
the code below gives me a "Segmentation fault".
regards, jr.
(from the newsgoups last year but didn't keep the reference to the author)
// Hintergrund
plane { z,0.441
 pigment { checker color rgb 0.7 color rgb 0.3 }
light_source {
 <-33,66,-99> color 1
 area_light <16,0,0>, <0,16,0> , 5, 5 jitter
 orthographic
 right <8,0,0>*0.875
 up <0,6,0>*0.875
 location <0,0,-10>
 look_at <0,0,0>
#declare P3 = array[8] {0, 1, 1, 1, 3,  4,  12, 9999};
#declare P4 = array[8] {0, 1, 1, 2, 5, 12,  35, 9999};
#declare P6 = array[8] {0, 1, 1, 3, 7, 22, 999, 9999};
#declare N=1;
#declare T=6;
#declare P=1;
#declare SCL = 0.2;
#declare Y=-2;
#while(Y<=+2)
 #declare X=-3;
 #while(X<=+3)
// #declare S = concat("N", str(N,2,0), ", T", str(T,2,0), ", P", str(P,2,0) );
 #declare S = concat("T", str(T,2,0), ", P", str(P,2,0) );
 #if(T<7)
// sphere { <0,0,0> , 0.45
 cylinder { <0,0,-0.45>, <0,0,+0.45>, 0.45
  pigment { pavement
    number_of_sides 4
    number_of_tiles T
    pattern P
   color_map {
    [0.0 color rgb<1.0,1.0,1.0> ]
    [1.0 color rgb<0.2,0.1,0.6> ]
  rotate x*-90
  scale 0.08
  finish { phong 0.5 }
  translate <X,-Y,0>
 text { ttf "arialbd.ttf"
  S
  0.001 0
  pigment { color rgb<1.0, 0.6, 0.2>*1.25 }
  no_shadow
  scale SCL
  translate <X-0.4, -Y-0.45, -0.55>
  S
  0.001 0
  pigment { color rgb 0.1 }
  no_shadow
  scale SCL
  translate <X-0.4, -Y-0.45, -0.55> + 0.0081*<1,-1,1>
 #declare X=X+1;
 #declare N=N+1;
 #declare P=P+1;
 #if(P>P4[T])
  #declare T=T+1;
  #declare P=1;
#declare Y=Y+1;
Date: 12 Jan 2019 08:41:57
Message: <5c39eea5$1@news.povray.org>
Am 12.01.2019 um 13:36 schrieb jr:
Oops, sorry about that. Until I've released a fix, you should be able to
work around it (to some degree anyway) by using `global_setting {
charset ascii }` (or any other value).
(Yes, I know that'll give you a deprecation warning.)
Date: 12 Jan 2019 08:46:25
Message: <5c39efb1$1@news.povray.org>
Known issue:
Using the `text` primitive without a `charset` global setting will cause
a hard crash. I'll release a fix as soon as I can get around to it.
Date: 12 Jan 2019 11:05:00
Message: <web.5c3a0efda3acffd948892b50@news.povray.org>
hi,
nope.  with global_settings, and even #version for good measure, no change.
regards, jr.
Date: 12 Jan 2019 20:23:56
Message: <5c3a932c@news.povray.org>
Am 12.01.2019 um 16:59 schrieb jr:
> hi,
It might now be segfaulting for some other entirely unrelated reason. Do
you happen to have an end-of-file right after the `#end` (without a
newline)?
That's another crash cause I saw on my machine after fixing the
absence-of-charset issue; I thought the mechanism could only trigger in
my private debug builds, but maybe I'm mistaken.
Date: 13 Jan 2019 04:45:00
Message: <web.5c3b087fa3acffd948892b50@news.povray.org>
hi,
> newline)?
no.  (my editor ((g)vim) shows '[noeol]' in the status line for such files)
regards, jr.
Date: 13 Jan 2019 07:41:20
Message: <5c3b31f0$1@news.povray.org>
Am 13.01.2019 um 10:44 schrieb jr:
> hi,
>> newline)?
Then the bad news is that I don't know why it crashes; on my machine,
the scene clearly bombed due to an uninitialized-variable situation in
the `text` primitive, which shouldn't occur if you use `global_settings
{ charset WHATEVER }` (or `#version 3.8`, actually).
The latest alpha fixes that situation. Let's see whether it also fixes
your crashes.
If it doesn't, I'll be clinging to the straw that the crash might be
specific to the `arialbd.ttf` font, and that I'm not seeing it because I
might have a different version of that font on my machine; in that case
I'd like to ask you to try with one of the distributed fonts, e.g.
`crystal.ttf`.
Date: 13 Jan 2019 08:30:01
Message: <web.5c3b3c03a3acffd948892b50@news.povray.org>
hi,
> your crashes.
no crash so far, just the error (see v3.8 character set handling).
(I've already "de-commissioned" 10008988)
> might have a different version of that font on my machine; ...
not that it matters but mine is (Redmond) time-stamped "140418183001Z0", and the
file size is 750216 bytes.
regards, jr.
Date: 13 Jan 2019 08:38:23
Message: <5c3b3f4f$1@news.povray.org>
Am 13.01.2019 um 14:25 schrieb jr:
> hi,
>> your crashes.
That's good news then...
... and that's an excellent decision.
