POV-Ray : Newsgroups : povray.beta-test : Test of RC4 Windows installer Server Time
16 Dec 2025 23:24:15 EST (-0500)
  Test of RC4 Windows installer (Message 1 to 10 of 16)
Subject: Test of RC4 Windows installer
Date: 9 Feb 2012 11:25:13
Message: <4f33f369@news.povray.org>
Folks,
I would appreciate it if some of you could sanity-check the RC4
windows installer, which may be found here:
  http://www.povray.org/beta/povwin-3.7.RC4-setup.exe
This is a combined 32 and 64-bit setup which is the first we have done
using NSIS (previously we used InstallShield). Please advise if you
have any installation issues.
-- Chris
Subject: Re: Test of RC4 Windows installer
Date: 9 Feb 2012 12:25:18
Message: <4f34017e$1@news.povray.org>
Am 09.02.2012 17:25, schrieb Chris Cason:
> windows installer,
installed on Windows 7 64bit and XP 32 bit, both times within
C:\CGI\POV-Ray (and not "Program Files"), changed the master ini file
(to point to my own include directories and set output to OpenEXR), did
run a quick test with one of my more complex scenes and everything worked.
-Ive
Date: 9 Feb 2012 16:44:26
Message: <Xns9FF4E756E2327seed7@news.povray.org>
in news:4f33f369@news.povray.org Chris Cason wrote:
> Folks,
Worked fine on win7/64
Thanks,
Ingo
Date: 9 Feb 2012 18:23:47
Message: <4f345583$1@news.povray.org>
V3.7 RC4 installation appears to have worked perfectly on my Windows 7
(Ultimate, 64-bit, SP1) machine using all default options.
I'll do some customisation and test a few more things then report back.
Looking good so far!
Date: 9 Feb 2012 19:09:00
Message: <4f34601c$1@news.povray.org>
> windows installer
Works fine on XP 32-bit, unfortunately I'm not currently
in the same country as my Windows 7 64-bit machine, I'll try
that on the weekend.
So you went down this route after all ;)
A few suggestions:
I think there should be an uninstall link (short-cut to uninstall
exe) added to the start menu. Note the uninstaller doesn't have to
reside top-level, you could also write it to $INSTDIR\bin, although
you then need to set $INSTDIR to $INSTDIR\.. on execution (even
better would be to retrieve the installdir from registry when
starting the uninstaller, then the uninstaller also works if
it gets copied to a different location).
BTW how are you removing the files? There is some dangerous sample
code floating out there that recursively removes $INSTDIR in a way that
would clear the users drive should he accidentally install to c:\.
Also note there are some optional checkboxes that could be
activated for the Finish Page, to determine whether desktop
icons should be created, some readme or manual opened, the
application automatically started after installation, ...
Finally, note there is a BgImage Plugin included with the
standard NSIS distribution. If the final version has some sort
of official raytraced image to show off the release, it could
easily be added as a fullscreen background to the installer.
Date: 9 Feb 2012 20:12:08
Message: <4f346ee8$1@news.povray.org>
Yep, I just couldn't stand using IS anymore. I utterly loathe that
product :-/
The old installer did do this, however I chose not to replicate that
as I have seen it recommended that installers do not create such
shortcuts. Can't recall where I read this other than it was a
sufficiently authoritative location that I chose to follow the
recommendation.
I was fairly careful about the removal: the code does a recursive
remove of the specific named sub-directories of INSTDIR (bin, help
etc), and then does an rmdir (non-recursive so will fail if not empty)
of INSTDIR. Also, the installer code will not permit the user to
choose the root dir as a install target.
You're welcome to the installer source if you are familiar with NSIS
and want to try to improve it; it's my first NSIS script so there
would definitely be room for improvement.
The POVWIN program itself will auto-load the release notes and change
log when it is started for the first time after an install. I could
add a run checkbox I guess.
Thanks for the info, I'll have a look.
-- Chris
Date: 10 Feb 2012 02:52:02
Message: <4f34cca2$1@news.povray.org>
The installer correctly installed pvengine64.exe on my Win7 (Home
premium SP1)
But there was no option to install the 32 bit version which I need to
run Bishop3D. Could you add an option to install the 32 bit version as well.
Regards
Date: 10 Feb 2012 02:57:45
Message: <4f34cdf9$1@news.povray.org>
It's there (in the bin directory); just point Bishop3d at it.
-- Chris
Date: 10 Feb 2012 05:15:10
Message: <4f34ee2e$1@news.povray.org>
>Chris Cason  on date 09/02/2012 17:25 wrote:
> Folks,
> -- Chris
Fine on Windows XP 32 bit, even changing default documents path.
Paolo
Date: 10 Feb 2012 11:38:06
Message: <4f3547ee$1@news.povray.org>
> -- Chris
Oops! And here is me thinking that you were being really clever and
automatically installing the version belonging to the OS.
Thanks.
Regards
