"Chris Cason" <del### [at] deletethistoo povray org> wrote in
message news:48a7e19a@news.povray.org...
> Jim Holsenback wrote:
>> Stephen & Sabrina: I'm done with all my edits and have rendered all the
>> files in the textures directory.
>> Chris: do you have some disc space that we can start putting the scene
>> source files and images?
> Sorry, only just now catching up with group: yes, I'll set something up.
> -- Chris
I'm all done .... source, ini and png files have been uploaded to ftp site.
Jim
>> -- Chris
> Jim
This weekend has turned awful, and extended till midweek. I've got the
edits, just need to find time to upload them.
> while having a look at the include files i think i may have come up with one
> more housekeeping issue that may be worthy of consideration.
> the issue of the I_Glass warning .....
> there are 14 scenes that call glass.inc (which calls glass_old.inc). my
> cleanup proposal involves making the textures in glass_old materials which
> would have the required inclusion of interior {I_Glass} and removing the
> I_Glass warning message in glass.inc .... oh and making a comment in
> glass_old header to call materials instead of textures.
Jim,
About the change of glass textures to materials: we need some provision for
backward compatibility, otherwise lots of old scenes will be busted
(includes some in the distro; e.g. woodbox.pov).
Suggestions?
-- Chris
message news:48d60e3d@news.povray.org...
>> one
>> which
> Jim,
> for
> Suggestions?
> -- Chris
I did change ALL distro scenes that called any glass textures the old way.
Are you talking about a personal scene that someone created with application
version less than 3.7? I thought that the error that the parser would throw
would eventually lead them to the glass.inc file where a notation was made
about the change was enough to ween everyone off the old way. If that's not
the case, how about something like we did with the assumed_gamma handling in
the globals block? Personally anytime I called glass.inc definitions I found
the parser warning annoying and copied the definition (with appropriate
I_Glass) into my scene and didn't bother even sourcing the glass.inc file at
all. As I was looking at distro scenes that had glass.inc some of the
authors had already done that. At any rate if you feel the needs a closer
look I'll do that. At first glance I'm thinking something like:
if (version < 3.7)
make them textures
issue I_Glass warning
else
make them materials
end
but haven't explored the gotcha's of this yet.
Jim
I think you missed woodbox.pov then:] (either that or I didn't update
it for some reason).
Basically any pre-existing scene. With upgrades to POV-Ray we've
always had a policy of not breaking pre-existing scenes except where
absolutely necessary. So we ought to provide backwards compatibility.
Technically there's probably no reason why both schemes can't live
alongside each other.
> if (version < 3.7)
> make them textures
> else
> make them materials
> end
While I'd like to see a warning issued, the problem would be that
anyone with a pre-3.7 scene loading the include file (even if they
don't use the glass textures) would get the warning ... I expect some
scenes out there do include files that they don't use, and would thus
get this warning. Also, anyone running an old scene without a #version
set would get a parse failure on the missing textures.
I think we need to provide both for the meantime. Perhaps we also then
need something like the 'deprecated' warning that is available in
compilers; we can declare something deprecated (via SDL) and if it is
used in a scene the parser spits out a warning.
-- Chris
Doesn't that already happen if you include glass.inc in 3.6? I get a warning
even if the scene doesn't use the old glass textures.
Yes, and it's one of the things we are fixing in the updated files.
-- Chris
message news:48d700f7@news.povray.org...
>> way.
I still have modified scenes on my system and it (woodbox.pov) looks like
it's been done on my end. I connected to the ftp site and in
jim/scenes/advanced woodbox.pov has been changed as well.
> -- Chris
Perhaps I jumped the gun abit. Things were flying pretty fast and when I
floated the idea of addressing this issue it didn't seem that anyone had any
strong feelings one way or another, so I pulled the trigger. If I could have
a few days to think about how to address this to everyones satisfaction I'd
like to take ownership of putting this issue to rest. In the meantime if
there are anymore specific considerations I should be aware of ..... let 'em
fly!
another thought .... woodbox.pov will still issue the I_Glass warning if the
modified glass.inc and glass_old.inc files are not in place. Those file are
on the ftp site in the jim/include directory.
Ciao
You are correct; it appears the updated installer I made had the old
file in it for some reason. Apologies for getting it wrong.
Sure, feel free to think it over. I think we need to move forward on
stuff like this without the fear of being bound to the past, while at
the same time keeping in mind that one of the impediments to upgrading
any software is if a user's old files don't work (properly). Hence we
need to balance things and provide backwards compatibility where possible.
If (as it appears to be the case) the SDL as it stands doesn't provide
a clean way of deprecating existing constructs while still permitting
their use, then we need to enhance the SDL. I'm inclined to add such a
means. For example:
#declare I_Glass4=
deprecated once "... some message goes here ..."
interior {
ior 1.5
fade_distance 2.0
fade_power 1001
if we did it this way, for example, the #declared item is known by the
parser to be deprecated: this generates no warning during the parse of
the #declare itself (or even if the #declare is used in another
#declare), but if it is used in an actual object, the message
associated with it is displayed (if the 'once' keyword is present,
it's only displayed once per parse, otherwise it's displayed each time
it's used in an object).
I'm not saying it has to be done this way; it's just one thing that
comes to mind. It would require the parser to track the deprecated
status of each #declared item (passing up the state if a new declare
inherits a deprecated declare, and so forth), which isn't as clean as
I'd like it to be. The other option is to display the warning anytime
the declare is used (even if in another declare, which means we have
to ensure we don't use such declares as part of something else in the
same standard include file as this would trigger the warning even if
the end-user didn't use the #declared item).
-- Chris
> I'd like it to be.
If the SDL could be changed to allow calling parameterless macros
without parantheses, it might be possible to do something like
#declare I_Glass4_Deprecated =
interior {
ior 1.5
fade_distance 2.0
fade_power 1001
#macro I_Glass4()
#warning "I_Glass4 is deprecated"
I_Glass4_Deprecated
message news:48d874f9$1@news.povray.org...
cool .... we're on the same page then.
> means. For example:
> #declare I_Glass4=
> interior {
> ior 1.5
> fade_distance 2.0
> fade_power 1001
How big of a deal to do this? Giving the parser the means to do this could
be useful for furture change issues as well right? This issue (I_Glass)
isn't the first time and I'm sure it wouldn't be the last, so I kind of like
this idea at first glance.
> -- Chris
I've pseudo coded an idea but haven't had the time to see if it might lead
anywhere. Basically the idea would use a function to return the state of a
toggle so we could conditionally provide a warning, but your suggestion has
me thinking that my idea is more of a patch than a solution.
Jim
Yes, it would be: this is the primary reason why I'm considering it.
I've prototyped this in the parser and it seems to be working OK so
most likely I'll include it in the next beta. I'll get an early copy
to you so you can add support for the keyword in the include files if
you like.
-- Chris
"Jim Holsenback" <jho### [at] hotmail com> wrote in message
news:48a98a0d@news.povray.org...
you guys have been silent for awhile ..... any status update?
message news:48db069d$1@news.povray.org...
>> could
>> like
> you like.
> -- Chris
thanks that would be great!
Ok, it's in the FTP dir (pvengine.zip). Note that this has some other
changes related to paths: you may need to copy your standard scenes,
include, ini, and insert menu files to 'My Documents\POV-Ray\v3.7'.
Syntax is as follows:
#declare deprecated Col_Glass_Old=color rgbf <0.8, 0.9, 0.85, 0.85>;
#declare deprecated once Col_Glass_Old=... etc
#declare deprecated "Some message" Col_Glass_Old=... etc
A deprecated identifier generates no message at the time it is declared: a
warning is only issued if it is used.
If the optional 'once' keyword is present it must immediately follow the
'deprecated' keyword and indicates that the warning should only be
displayed once per parse.
If the optional message string is present, it will be used as the warning
to be displayed if the identifier is used. Otherwise, a message of the form
"Identifier 'Col_Glass_Old' was declared deprecated." is used.
An identifier is considered 'used' if it is referenced anywhere (even if in
another #declare).
-- Chris
NB I have files from all three of you now: I think the set is basically
complete.
thanks for the help folks!
-- Chris
message news:48db9305@news.povray.org...
Thanks Chris! I'm all set .... still have my old notes so I know what files
need to be looked at (14 scene files and 1 include). Barring diversions on
my end I should be able to wrap this up before the end of this weekend.
I've uploaded the files to the FTP dir (glass/include & glass/scenes) not
all the scene files needed additional changes.
Basically I deprecated the textures in glass_old.inc and added appropriate
comments to the file header.
Jim
thanks for that, looks good.
-- Chris
