"Sabrina Kilian" <"ykgp at vtSPAM.edu"> wrote in message
news:488a6e58@news.povray.org...
> StephenS wrote:
>> "Jim Holsenback" <jho### [at] hotmail com> wrote:
>>> I'm starting a new thread for the v3.7 example scenes project ...
>> Ok, I've reinstalled POV-Ray 3.7.0.beta27.
>> I'll go step by step in case my method needs fixing.
>> As my first victim, scenes\qtvr\qtvrpanorama.pov from 3.7
>> File states:
>> #version 3.5;
>> global_settings{ assumed_gamma 1.0}
>> //-w384 -h1284 (command line recomended)
>> 1)I run the scene with POV-Ray 3.5
>> 2)I run the scene with POV-Ray 3.7(new output file name)
>> 3)I run the scene with POV-Ray 3.7, removing version and gamma(new output
>> file
>> name)
>> I compare 1 and 2, PaintShopPro/Arithmetic/difference. The resulting
>> image is
>> not blank.
>> I compare 1 and 3, PaintShopPro/Arithmetic/difference. The resulting
>> image is
>> not blank.
>> qtvrpanorama.pov does not render the same.
>> Yikes, now what?
>> Include the updated scene anyways? If it needs fixing, this will be
>> beyond me.
> Next is talking about what changes are visible, and figuring out what to
> change to "fix" it. Some differences will be easy, others might not. As a
> group, though, we should be able to get a good many of them.
i think before we get to far ahead of ourselves we should divide up the
examples so we can work without stepping on each others toes. if there are
no objections i'll use the manifest list to evenly divide up those scenes
into managable chunks. i think a good first pass would be to try to render
the scenes and see what goes without any changes. fails/warnings/problems
lets just make notes and move on to the next scene. i think this will pare
down the list and help use identify the problem scenes. as for debugging i
agree with Sabrina that we should be able work through most problems amoung
ourselves. if not, i'm sure that others in the users community will be able
to bail us out. i'll wait a bit for any comments before proceeding in case
either of you have a better idea how to go forward.
Jim
>if there are
> into managable chunks...
Good idea. Use more chunks than people so new people can easly join, or another
chunk can be taken if one is easy(or time permits).
Just for my own curiosity:
~changing the noise generator had little effect
~The scene uses crackle, turbulence is already listed first.
The difference in the 3.7 and 3.5 pictures is from the use of crackle.
Any other suggestions?
>>> File states:
>>> #version 3.5;
>>> file
>>> name)
>>> image is
>>> not blank.
>>> image is
>>> not blank.
>>> Yikes, now what?
>>> beyond me.
I didn't mean it was the next immediate step, just the next thing to do
for that single image.
>if there are
That sounds like a good idea to me. I can think of one possible issue.
Certain files in the demo scenes tend to take a lot longer to render. If
memory serves me right, the radiosity ones take more time, in general,
and should be split over multiple chunks.
> Jim
The last thing we need to agree on might be an ideal image format to
test with. I'm not familiar with the technical differences between Targa
and PNG, could anyone else chime in if we might notice certain
differences that appear in one or the other, or at certain bit depths?
It doesn't need to be identical, however we need to evaluate for each image
the reason for the difference. If it's a bug or unimplemented feature, then
please let me know (even if it's a known issue - it will help to have a new
list based on all the sample scenes being tested). If it's simply due to a
difference in the way 3.7 works, we need to evaluate whether or not it
makes the scene no longer relevant.
NB the next beta (out in the next few days) has some improvements which you
may want to be using. I can upload a binary for you (EXE only, I am still
working on the installer) if you want to have access to it immediately.
Please email me if so.
-- Chris
Christoph Hormann wrote:
> For MegaPOV i made a script that builds such a page based on the header
> comments in the scene file - a somewhat extended version of what comes
> with the POV-Ray 3.6 Unix version. The result:
> http://megapov.inetart.net/samples.html
I think this is a very useful start.
-- Chris
> How about 1024x768 jpg?
Keep in mind all of the images need to go into the distro; it would depend
on the filesize of the combined images as to whether or not we could use
that size. we might want to include smaller images to start off with, and
have an alternate version of the HTML files that link to larger versions
online. Or just include the thumbnails (presuming we use a reasonable size
for these; e.g. 320 width) and always have the large version linked online.
One thing I think would be nice is if we use a smaller thumbnail (e.g. 160
width), and have a larger (e.g. 320 or even 512 pixel width) one become
visible upon mouse hover. Full-size images would all be online in that case.
(Also, if we have an online version, it might be nice to link to it from
the scene source file - if we do that I might add HTML link recognition to
the POVWIN editor).
-- Chris
Either is OK, as both are lossless formats (ie, they should result in
the exact same image).
...Chambers
Hola,
I've completed a review of the v3.7 example scenes. A picture is worth a
1000 words so I've attached a pie chart showing the breakdown.
I also wrote a quick shell script to help target potential resourse
bottlenecks. I just produced this stuff so I've not had much time to think
about how to divide it up yet. Any thoughts? Finally I'm wondering if there
is a need to restate what it is we are going to be doing, image file
formats, what AA to use, etc and include it in a single document that we can
all read comment on and agree to before digging in. I'd hate to be halfway
through and find out that "Hey!!!! that's not what we agreed on!"
If I'm not stepping on any toes I'll commit to pulling togeather a mission
statement. I think this is may be the final piece before proceeding. Shout
if you don't agree!
This are the strings I looked for:
isosurface {
scattering {
radiosity {
These files have isosurfaces:
./advanced/abyss.pov
./advanced/benchmark.pov
./advanced/biscuit.pov
./advanced/isocacti.pov
./advanced/landscape.pov
./advanced/optics.pov
./incdemo/i_internal.pov
./language/trace2.pov
./objects/isosurfaces.pov
./portfolio/allobjects.pov
./portfolio/allpat1iso.pov
./portfolio/allpat2iso.pov
./textures/patterns/crackle2.pov
./textures/patterns/crackle3.pov
./textures/patterns/crackle_form.pov
These files have scattering media:
./advanced/mediasky.pov
./interior/media/galaxy.pov
./interior/media/media1.pov
./interior/media/media2.pov
./interior/media/media3.pov
The files have radiosity:
./advanced/gaussianblob.pov
./advanced/object_pattern.pov
./animations/raddem/raddem.pov
./radiosity/patio-radio.pov
./radiosity/radiosity.pov
./radiosity/radiosity2.pov
./radiosity/radiosity3.pov
./radiosity/rad_def_test.pov
Cheers Jim
Download 'scene-files.jpg' (138 KB)
Preview of image 'scene-files.jpg'
> online.
> case.
Do the same as for the Insert menu. Put small images in the package and have
an automatic way to re-render them at a bigger size.
I could, but I suspect that 99% of people wouldn't bother (and/or wouldn't
know). Most would, I feel, rather just point and click, even if that
involves pulling down the images from the internet. (We could provide a
downloadable set of the large images at the same site).
-- Chris
Nice work!
> isosurface {
> scattering {
> radiosity {
I think you place too much trust in consistent coding
style here ;) e.g., in 3.6, the following scenes use
"radiosity{" without a space:
advanced\balcony\balcony.pov(67)
advanced\blocks\stackerday.pov(40)
advanced\blocks\stackernight.pov(41)
radiosity\cornell.pov
and there may be more using the prettier way (troll troll)
of opening the curly brace on the next line ;)
Chambers nous illumina en ce 2008-07-26 15:47 -->
>> Targa and PNG, could anyone else chime in if we might notice certain
> ...Chambers
The main difference between TGA and PNG, is that TGA is normaly not compressed
while PNG is a lossless compressed format.
I bet exercise equipment would be a lot more expensive if we had evolved from
starfish.
>> have an automatic way to re-render them at a bigger size.
What if it renders from the last in the list, downloads from the first in
the list, and calls it done when they meet in the middle? That way it'd
fully use both network and CPU resources :)
Bonus points for ordering the list by render time : file size ratio
(download the slowest to render, render the slow to download).
"Chris Cason" <del### [at] deletethistoo povray org> wrote in
message news:488f0949@news.povray.org...
> Nice work!
Thanks .....
I've also had a poke around some of the examples and I have some questions.
It seems the biggest issue is going to be the assumed_gamma handling change
in v3.7. If I'm understanding correctly if the parser sees the inclusion of
that keyword it basically spits out a warning and handles gamma correction
based on what you have in resolution.ini. Is that correct? So there's no way
to compare a before and after image. I used isocacti as a test case and saw
no visual difference in the image with assumed_gamma and with it commented
out.
Another thing I looked at was some of the animation examples. Some examples
had ini files and started clocking through and produced a series of images.
Do we want to run through the entire animation, and produce a mov. I have QT
pro to do that if that's the case. (I'm sure there are other apps for this)
but QT is what I'm comfortable with.
I've reread through this thread and it still seems that there is no
consensus on image file format and size. Whats the best approach here?
Produce a full sized image and just scale for the thumbnails, or two
separate runs.
What kind of timeframe are we working against here ..... by the end of the
beta cycle and before v3.7 final release?
I'm sure there are one or two more issues that I've not hit upon.
Stephen/Sabrina .... you guys have been mostly silent. What kind of initial
issues have you seen? I really think it's important to get as many of the
issues as we can out in the open before formulating a test plan. If I'm off
base on this please speak up. I'm flexible and have no problem being pointed
in the right direction.
Jim
"Christian Froeschlin" <chr### [at] chrfr de> wrote in message
news:488f283f@news.povray.org...
>> isosurface {
>> scattering {
>> radiosity {
oooo .... good point. perhaps just looking for the keyword (no brace) would
be better.
easy enough to change the script I used to hunt for these occurances. i'll
see if the count changes by much. maybe I should be looking for photons
keyword as well.
i think omitting the brace might give a better snapshot of whats out there
..... a ballpark estime anyway
Jim
My current understanding is:
~Stage one: Identify included content that no longer produces the same result in
3.7 as the version it was made for. Update files to reflect; removal of #version
if possible, and removal of version 3.5/3.6 in comments.
~Stage two: Update/remove/new content and the way it's presented to the end
user.
Stage one is the level I signed up for, Stage two is interesting but only as an
observer.
If you could group the files into managable chunks, I'll start reporting back my
findings;)
"StephenS" <nomail@nomail> wrote in message
news:web.4890749415676239b586e7830@news.povray.org...
> result in
> #version
> end
> user.
> as an
> observer.
> back my
> findings;)
Last evening I reviewed about two dozen files from various locations.
Without fail assumed_gamma was the prevailing issue. Several files had
version 3.1 brands. There was one or two files that had noticeable blocks of
code commented out. I also noticed that some but not all source files had
ini files. I think this a great feature that we might use in the process of
producing the final quality images for the distribution. Stephens comments
and one other limiting factor for me (dial-up) leads me to believe that
there may be a better way to approach this project. The whole thing depends
on Chris having a machine that has enough free cycles to crank out the final
product, so I will be brief.
Divide the source files into four chunks. Three for the review team, one
left over for whoever gets done first. While that's going on there needs to
be a decision made about final image quality, size, and format. Every source
final gets an ini file with the agreed upon render options. See if we might
be able to leverage off what Christoph did with the MegaPov examples. The
testing on our end will just involve branding a version if necessary, making
sure any parser warnings are resolved, and seeing that the image does indeed
render. No worries about quality and size as the images will just be
discarded. Upload the cleaned up source and ini files, and batch them up for
processing.
Jim
It's a little more complicated than that: best to read the release notes
regarding that (I'll paste the relevant section in a followup to this message).
I don't think this is necessary, just a single still would do.
> separate runs.
Scaling to thumbnails is fairly easy, so I'd recommend that. For full-size
images you could render at a width of, say, 768, with the height being
whatever that scales to with the aspect ratio taken into account.
No specific time other than that obviously we have to get it done before we
release :). It would be nice to have the updated scenes in the betas sooner
than later.
One other suggestion: when leaving a #version in the scene file, it might
be good to add a comment above it that says e.g. "minimum POV-Ray version
needed to render this scene", or something like that.
thanks,
-- Chris
Here's the relevant portions of the notes:
> The way POV-Ray 3.7 handles the 'assumed_gamma' keyword has changed.
> Previously the presence of this keyword in global_settings caused a
> 'possible error' warning and its presence was ignored. In addition
> no gamma correction was available in previous betas. Starting with
> beta.10 however, gamma correction is performed on both the display and
> file output, subject to the following criteria:
> o If the scene language version is set to 3.7 (or not set at all), then
> gamma correction will default to ON, with the value used being set by
> the 'display_gamma' INI file setting. Note that in previous versions of
> POV-Ray gamma correction was OFF by default but otherwise this is the
> same.
> o If the scene language version is set to earlier than 3.7, then gamma
> will be OFF by default.
> o Notwithstanding the above, if the keyword 'assumed_gamma' is present
> in the scene's global_settings, then POV will take one of the following
> actions:
> a) if "assumed_gamma 2.2" is present, gamma correction will be turned
> OFF and a warning issued. the same thing will happen if the value
> specified is not 2.2 but happens to be the default for the platform
> setting given to POV-Ray when it was compiled (e.g. Windows is 2.2).
> b) if "assumed_gamma 1.0" is present, gamma correction will be turned
> ON (if it's not already on) and in any case a warning will be issued.
> c) if a value other than the above is specified, it is ignored and a
> 'possible error' message is issued.
> You will note from the above that therefore it is no longer possible to
> adjust the amount of gamma correction from a scene file. This is as
> designed since scene files should be as much as possible be platform
> independent, and the gamma of particular display hardware does not belong
> in the scene file. If you really need to specify 'assumed_gamma' you can
> do so in an INI file or on the command-line; however in those cases you
> may as well just use 'display_gamma' in its place.
> When writing file formats that support gamma specification, the inverse
> of the assumed_gamma value will be embedded in the file headers, so that
> an appropriately equipped display program can 'undo' the gamma correction
> if it is so desired. This is as per previous versions of POV-Ray.
> Frontend and Backend
> Note that POV-Ray uses a logical separation of frontend and backend. The
> 'frontend' is that part which deals with the user-interface, locating files,
> parsing command-line options, reading INI files, and so forth. The 'backend'
> deals with parsing the scene file and doing the actual render. These two parts
> of POV-Ray communicate via a message-passing interface, even when linked into
> the one executable program.
> Whilst currently not supported, it is entirely possible to separate the front
> and back ends via for example a network interface, and have the render done
> on one machine while the user interface (and display) is on another. Knowing
> this may make it easier to understand why, for example, we are moving away
> from allowing things such as gamma correction to be specified in the scene
> file; there is no reason to assume the scene file is on the same machine as
> the image will be displayed upon, and as such the specification of gamma
> should be done in the frontend via INI or command-line options.
> There will be more changes along these lines as we prepare for the future
> transition to a fully network-capable renderer. The POV-Team will attempt
> to ease the change to the new system by doing things such as the assumed_gamma
> interpretation above, where it is possible to do so.
> gamma changes, revert to beta.10 behaviour with some tweaks for more
> extensive version checking.
> In particular, specifying -MV3.7 or later via an INI file or the
> command-line is taken at higher precedence than a #version 3.6 (or
> lower) in the scene file when it comes to assigning the default state of
> gamma correction (on/off, not its actual value if on). the value used
> when it is on is determined by either Display_Gamma (if given) or
> DEFAULT_DISPLAY_GAMMA otherwise. Similar steps are taken for the new
> File_Gamma option.
> The actual value of assumed_gamma is not passed on; this prevents its
> use for anything other than turning gamma on or off (which is what the
> majority of scenes did with it). Those scenes that (mis)used
> assumed_gamma to adjust the scene appearance outside of the needs of the
> user's actual display gamma will need to either be altered to suit, or
> to be run with an adjusted Display_Gamma and File_Gamma.
> NB users are warned that assumed_gamma support will be removed entirely
> in a later 3.7 revision.
message news:4891a171@news.povray.org...
>> change
>> of
>> correction
>> way
> message).
thanks .... I'm squared away on that now.
>> separate runs.
ok that answers size .... what about format? png?
> thanks,
> -- Chris
I've seen what I think perhaps catches all the cases we are likley to
encounter that involve gamma correction and they are:
version <= 3.5 with assumed_gamma = 2.2, 1.8, 1, or 0.8 in 244 of the 365
scene files, or no version set at all for the rest.
It seems then that the 244 files with some mention of gamma correction have
the version reference removed, so that by default gamma correction is on.
the test file I was using sourced a couple of includes that had #version 3.5
keyword. Does the pov source file inherent the version from a sourced
include? If so I would be in favor of setting #version = 3.7 in those pov
files. Maybe we need to up version the includes as well. The remaining files
that have no mention of assumed_gamma should be set to 3.5 so to have gamma
correction off.
here's the header of the test file i've been using and a pretty free form of
what I'm thinking we ought to be doing:
// Persistence Of Vision raytracer version "what ever we decide" sample
file.
// -w320 -h240
// -w800 -h600 +a0.3
#include "stdinc.inc"
#include "arrays.inc"
/* The following has been obsoleted due to the way gamma correction is now
being handled.
Please refer to the release notes for additional information. Any version
references should
be considered as a minimum requirement to render this scene. */
//#version 3.5;
global_settings {
//assumed_gamma 1
Jim
news:web.488b08c815676239270b39b0@news.povray.org...
>>if there are
> another
i think we are getting close to starting to work, however there are some
pending issues to be nailed down yet.
here's a proposed breakdown:
advanced/animations (71)
camera/incdemo (74)
interior/language/lights/objectmods/qtvr/radiosity (69)
objects/portfolio (78)
textures (73)
Jim
Yes, I think so: it's lossless and easy to convert from that to another
format if it's needed.
> include?
I think you'll find that the includes set it back to the old value at the
end (please check to make sure).
There's probably no harm in doing so, and might even be a good idea overall.
> being handled.
> references should
> //#version 3.5;
> global_settings {
> //assumed_gamma 1
In the above example I'd rather have the assumed_gamma removed, along with
the #version; thus the comment isn't necessary.
OTOH if there is no #version at all, and the scene doesn't render "right"
(i.e. gamma turns out wrong) when rendered in version 3.6 due to the
removal of the assumed_gamma, then we probably ought to place a #version
3.7 in the scene.
if you wanted to get fancy, you could leave the #version out and put a #if
around the assumed_gamma statement, where you check the version and only
apply the assumed_gamma for version 3.6 and earlier.
regards,
-- Chris
> > being handled.
> > references should
> > //#version 3.5;
> > global_settings {
> > //assumed_gamma 1
If we go this route, then I would also use:
// Persistence Of Vision raytracer sample file.
in the top comments, with no mention of version.
Stephen S
news:web.48948ff5156762395d26830d0@news.povray.org...
>> > now
>> > being handled.
>> > version
>> > references should
>> > //#version 3.5;
>> > global_settings {
>> > //assumed_gamma 1
>> with
> Stephen S
good eye .... i noticed this but forgot to mention. In other words agreed!!
Jim
message news:48948066@news.povray.org...
>> include?
ok ... i'll look to make sure.
> overall.
good ... i'll have a look and see what's involved before I pull the trigger
and do it.
>> now
>> being handled.
>> references should
>> //#version 3.5;
>> global_settings {
>> //assumed_gamma 1
i threw that in just to see if i could get any outside ideas .....
> 3.7 in the scene.
another overlooked possibility ..... thanks!
this is way more elegant and easy enough to do.
>> include?
yes they do that ..... all but two of them
> overall.
with the code frag in the includes this could be considered a moot point. In
the name of housekeeping this may not be a bad idea to do this anyway. there
are only 35 include files .... 33 are branded version 3.5 and have the
switching mechinism, two files (stdcam.inc and stage1.inc) have 3.1 mention
in header comments and no switching code. easy enough to version them as 3.7
and housekeeping seems like a good reason to proceed, but won't do that
unless you (Chris) think I should do this.
Jim
> camera/incdemo (74)
> textures (73)
> Jim
If there are no objections I'll start to familiarise myself with the
'camera/incdemo' group.
When we seem to have agreed upon the requested changes, I'll start a new thread
for this group of files, so I can list my progress or problems.
Stephen S
while having a look at the include files i think i may have come up with one
more housekeeping issue that may be worthy of consideration.
the issue of the I_Glass warning .....
there are 14 scenes that call glass.inc (which calls glass_old.inc). my
cleanup proposal involves making the textures in glass_old materials which
would have the required inclusion of interior {I_Glass} and removing the
I_Glass warning message in glass.inc .... oh and making a comment in
glass_old header to call materials instead of textures.
I found at least one scene that calls the texture {T_Glass1} which is a
glass_old texture, so it would appear there would be some changes to scene
files as well.
comments welcome!
Jim
news:web.489593a615676239d1f8364e0@news.povray.org...
> thread
> Stephen S
i'm cool wid dat
I think we are close to wrapping up the review of v3.7 example scene files
so I wanted to summarize and get our plan "blessed" before proceeding with
the actual work.
Division of work: This is how the scenes have been divided up.
camera/incdemo (74) (Stephen has already spoken up for this
group)
textures (73)
Image size and format: 768 x 576 (4:3 aspect ratio) PNG. Using the file
advanced/grenadine as a test case I noticed a difference in the preview
window image (to dark) and the final png image file (to light). This led me
to believe that I hadn't set display_gamma correctly. After some empirical
testing this is what I came up with for my quickres.ini file:
[768x576, AA 0.3]
Width=768
Height=576
Antialias=On
Antialias_Threshold=0.3
Display_Gamma=2.3
I'm going to post the image over in the images group. One last thing about
image quality. The rim of the glass had jagged edges until I used +a0.1
+r4 ... we DO want to resolve quality issues like that don't we?
Scene file edits: This is how assumed_gamma and source file versioning is
handled.
This example (below) has an assumed_gamma setting, so in order to leverage
off the 3.7 default behavior the #version 3.5 directive has been
conditionally excluded, as well as the assumed_gamma setting in the global
settings block. Additionally any mention of version in header comments have
been deleted , and a date stamp with initials was added. Example files that
don't have assumed_gamma in global settings block should be (if not already)
branded #version 3.5 as the default behavior is gamma correction off.
---begin scene file frag
// Persistence of Vision Ray Tracer Scene Description File
// File: grenadine.pov
// Desc: Glass with liquid
// Date: 1999/06/04
// Auth: Ingo Janssen
// -w320 -h240
// Updated: 04Aug2008(jh) for v3.7 distribution
#if (version < 3.6)
#version 3.5
#include "glass.inc"
#include "lemon.inc"
global_settings {
// conditionally comply with gamma correction handling
#if (version < 3.6)
assumed_gamma 1.0
max_trace_level 5
photons {
spacing 0.01 // higher value 'lower' quality, faster parsing.
autostop 0
jitter 0.5
max_trace_level 15
--- end scene file frag
Notice from the scene frag above that it calls and include "lemon.inc" which
is an include in scenes/advanced. It had the #version directive in the body
of that include. I used the following common version preservation method
used in the application includes.
--- begin code frag
// Added to comply with common version preservation scheme
// 04Aug2008 (jh)
#ifndef(Lemon_Inc_Temp)
#declare Lemon_Inc_Temp=version;
#version 3.5;
#ifdef(View_POV_Include_Stack)
#debug "including lemon.inc\n"
// code body goes here
// 04Aug2008 (jh)
#version Lemon_Inc_Temp;
--- end code frag
Include files review:
The include files have been reviewed and since they have a scheme that
keeps the calling source file from inheriting it's #version branding it's
been suggested that this is a moot point to change the #version branding for
now. In other words it's purely a housekeeping issue for now. Since we're on
the topic of includes, I've heard no reply on my proposal to change the
textures in glass_old.inc to materials, and remove the I_Glass warning in
glass.inc. The above scene file frag calls glass.inc so a minor mod to the
scene file was in order. The scene file rendered fine. I don't want to do
this because silence implies agreement. Someone yea or nay this change
please!
Have I forgotten anything?
Jim
Please be aware that the PNG output images have the inverse gamma
written into the file header and will appear differently between
viewers that do and don't support using this value.
I suspect so, if it doesn't involve too much work.
> #if (version < 3.6)
Should that be < 3.6 or < 3.7 ?
> please!
I haven't read it in detail (during weekdays I don't get a lot of
time) but as long as it doesn't break any existing third-party scenes
I'm OK with the change.
thanks,
-- Chris
message news:489a8737$1@news.povray.org...
>> me
yes .... i was using GIMP
>> about
>> #if (version < 3.6)
i defer to you .... i'll reread the doc and see if i can figure out what led
me to believe that the default behavior for gamma correction has been around
since 3.6.1
>> the
>> please!
these scene files have glass.inc but MAY not call glass_old textures. i'll
take ownership for making those changes.
./advanced/desk.pov
./advanced/grenadine.pov
./advanced/wineglass.pov
./advanced/woodbox.pov
./advanced/blocks/stackertransp.pov
./advanced/fish13/fish13.pov
./animations/boing/glsbng.pov
./incdemo/glasses/glass.pov
./incdemo/glasses/samp_demo.pov
./interior/ballbox1.pov
./interior/iortest.pov
./interior/magglass.pov
./lights/glassthing.pov
./lights/phot_met_glass.pov
Stephen I owe you two files as you're already working on the incdemo files.
I'm going to speak up for the advanced/animations group of files. I will
deal with the remaining files when someone speaks up for the groups that
they are in. I will also post the revised glass/glass_old.inc files so both
of you (Stephen/Sabrina) can pick those up. Zip format OK? Give me a couple
of days to get this done as I'm juggling several things (feast or famine)
right now.
Jim
"Jim Holsenback" <jho### [at] hotmail com> wrote in message
news:489ac9a9@news.povray.org...
> ./advanced/desk.pov
i posted these scene files as well as glass.inc and glass_old.inc are in a
zip file over in the text.scene-files group
jim
news:489d58bf$1@news.povray.org...
>> i'll take ownership for making those changes.
>> ./advanced/desk.pov
i discovered a typo in comments that's been corrected ..... NEW zip file
posted
Jim
i'm done with edits of this section, and i've taking a different approach on
my work flow. i'm going to just do edits for now as the render portion is
going to be a bottleneck on my machine. most images rendered fairly quickly
however some took > 1 hr at that rate i ought to finish up sometime before
next summer ;-)
i'm going to start edits on this group:
Jim
> next summer ;-)
> Jim
I'll jump in and take the objects/portfolio set to render. And I'll see
about getting/keeping access to an animation lab, and running it there
as well.
news:489dcf22@news.povray.org...
done with those .... i'll start on textures.
Stephen & Sabrina: I'm done with all my edits and have rendered all the
files in the textures directory.
Chris: do you have some disc space that we can start putting the scene
source files and images?
Jim
I've gotten the objects folder rendered, but the portfolio is taking
longer as I'm not too talented at scripting, so I am running each pass
by the GUI and Sel-Run.
The biggest issue I've seen so far is the wood include and
objects/pawns.pov. The wood textures look completely different without
the assumed gamma statements, and pawns seems to have some graphical
issue. I'm thinking it might be coincident surfaces, but I've not looked
at it too close yet.
news:48a3573c$1@news.povray.org...
> objects/pawns.pov. The wood textures look completely different without the
> assumed gamma statements, and pawns seems to have some graphical issue.
> I'm thinking it might be coincident surfaces, but I've not looked at it
> too close yet.
hmmmm .... the only thing that slowed me down was that some of the images in
advanced had different aspect ratio's (other than 4:3). The stuff in
textures went by super fast once I got past my "Doh" moment using the file
queue feature. The file queue feature was appealling to me because I wanted
to have the renders go unattended. I inspected the headers and camera
statements and found nothing unusual so I thought they looked like an ideal
candidate for batch processing.
I'm wondering if you had a particular file in mind that you were seeing the
wood.inc problem, or should I just have a look at anything that sources
wood.inc ..... mind you it's not that I don't believe you, I'm just curious
and want to have a look. I'm going to slow things down abit until I hear
back from Chris on disc space.
Jim
> The wood textures look completely different without the assumed gamma
> statements, and pawns seems to have some graphical issue. I'm thinking it
> might be coincident surfaces, but I've not looked at it too close yet.
pawns problem is indeed coincident surfaces ..... checkout where the author
finally builds the chessboard. The calls to the object "Eights" could use a
bit of +y ..... i used 0.000001 and it looks fine now. BTW: the wood
textures in this file look ok to me.
Jim
>> too close yet.
> Jim
Yeah, the file queue worked great for objects, I set it to run in both
3.6 and 3.7, turned on an MMO, and by the time the evening was over they
were both done. The portfolio requires rendering with an .ini unique to
each .pov file, and so eats up a bit more time as I'm not comfortable
with scripting windows to do it for me.
On to wood.inc: In the display window while it's running and rendering,
the images looked a lot different for the same file. Brighter or darker,
the colors seemed more saturated. Checking the image after it's been
saved to disk, I don't see the huge difference any longer.
I looked at t_woods6.png, it looks like it has some minor color
differences in the dark area, but that could just be me. I'll check it
in Gimp and difference the two images to see if it's just where I have
the pictures on the screen.
news:48a4db21$1@news.povray.org...
> the colors seemed more saturated. Checking the image after it's been saved
i saw this too and thought that tweeking the Display_Gamma entries in
quickres.ini would help ...... it did.
Jim
> Jim
I've gone thought my first edits with v3.7, some things i've seen:
Two files have warnings, this is just the way the file is constructed, I see no
problem with leaving them as is.
String.pov, warning no objects
Screen.pov, warning more than one camera
Web link, and still working, will it always?
Sundial.pov
Some files are set up to use animations, I_internal.pov, but some need to be
manualy edited to get the full benefit, Transform.pov. I'll leave this for
posible future edits. I prefer the animation setup.
I like the idea of using the comments to add the assumed_gamma settings
// -w768 -h576 +a0.3 display_gamma=1.8
or what ever is needed for the file.
comments welcome.
Stephen S
Sorry, only just now catching up with group: yes, I'll set something up.
-- Chris
news:48a2b9c9@news.povray.org...
I'm all done with these sections (edits & renders) ....
textures (73)
1. there were less than half dozen files that required differnt aspect ratio
other than 4:3
2. a couple of files were order dependant (error because it was looking for
a image file that hadn't been rendered yet)
3. advanced/fish13/fish.inc and stem1.inc had #version 1.0 set. I left
fih.inc at #version 1.0 (comma's between vector coords?) upgraded stem1.inc
to #version 3.5 and replaced alpha with filter. left world12.inc alone as it
had no #version.
4. modified glass.inc and glass_old.inc (textures-> materials)
5. assumed_gamma handling was by far the dominate issue.
Jim
Stephen,
I've set up a FTP account for the scenes but don't have your email
address handy ATM. Please drop me an email and I'll pass on the login
details.
-- Chris
Sorry for taking so long, I have been struggling a bit, but seem to be going
fine now. This post by Jim has helped.
> [768x576, AA 0.3]
> Width=768
> Height=576
> Antialias=On
> Display_Gamma=2.3
I'm using this in quickres.ini to help:
[768x576, AA 0.3, png]
Width=768
Height=576
Antialias=On
Output_File_Type = n
> #if (version < 3.6)
> #version 3.5
> #end
> global_settings {
> #if (version < 3.6)
> assumed_gamma 1.0
> #end
I'm using a version of this in the scene file:
// Updated: Aug2008(sjs) for version and gamma
// -w768 -h576 +a0.3 Output_File_Type=n Display_Gamma=1
#if (version < 3.7)
#version 3.6;
global_settings { assumed_gamma 2.2 }
Stephen S
